Can someone help me connect my air horns to my alarm.
Old Apr 11, 2002 | 11:05 AM
00MAXIMA00's Avatar
I have it set up but the horn doesn't "flash" It is just a solid blast. I hooked up a flasher but I don't understand what is wrong. Please look at the picture and tell me what I did wrong and how I can fix it. Or just tell me how to do it or provide a link to a how to.
http://www.geocities.com/dman950/airhorn.jpg
If you can't see the picture it is basically my air horn is hooked up with a relay and I split the power from the siren and put a flasher with 2 diods on it and put it into the turn on wire of the horn.
Old Apr 11, 2002 | 02:48 PM
Chunger's Avatar
My other car is a Hybrid
Can't see the pic or really understand you explanation but...
splice off the + of the siren and send it to the flasher -> trigger (85 or 86) on relay to airhorn. You shouldn't need diodes.
Old Apr 12, 2002 | 06:58 AM
00MAXIMA00's Avatar
Thats what I did
+ from siren --> flasher --> trigger on relay
(I even flipped the flasher but that didn't work either)
but if you dont put diods the siren will go off when you honk the horn.
Old Apr 12, 2002 | 09:12 AM
Chunger's Avatar
Originally posted by 00MAXIMA00
Thats what I did
Then you will need the diode if you have it hooked up to the horn as well. I'm not too sure about the flasher hookup, then... I'll try to find out some more but that was the way I thought they were supposed to be wired.
I'm wondering if you might need some resistor for the flasher...
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
