Warning to all SC owners
Old Apr 11, 2002 | 04:27 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Last night while swapping pulleys, I noticed a pretty large amount of oil on the underbody liner after jacking up the car. After closer inspection, I noticed there was oil all over the side of the engine bay (opposite side of the crank pulley). The trail of oil lead to the supercharger itself!
After taking off the pulley, I noticed there were a few hex screws that were VERY loose... loose enough to be hand turned. So the next time any of you pull off your SC, make sure all the screws are tight!
I've included a picture of which ones were loose:
Old Apr 11, 2002 | 04:29 PM
mzmtg's Avatar
Minister of Silly Walks
Wow!
I'm no expert, but it looks like those are the screws that hold the turbine itself together.
That cant be good...
Old Apr 11, 2002 | 04:30 PM
Y2KevSE's Avatar
... or you can go here if the picture doesn't load:
http://boostedmaximas.com/y2kevse/im...harger3/17.jpg
Old Apr 11, 2002 | 04:37 PM
Jeff92se's Avatar
I'm needing a caw
Hmm how about some locktite?
Old Apr 11, 2002 | 04:51 PM
DanNY's Avatar
Ad·min·is·tra·tor
i agree with Jeff...
just don't use the super strong one.
Kev - don't lose those washers
Old Apr 11, 2002 | 05:04 PM
Y2KevSE's Avatar
That would work.
Old Apr 11, 2002 | 05:07 PM
The New CLIMAX's Avatar
Originally posted by Y2KevSE
That would work.
Old Apr 11, 2002 | 05:18 PM
Chunger's Avatar
My other car is a Hybrid
Hmmm... I wonder if that is where my mysterious (although slight) oil leak is from... My V2S is still too young dangit!
Old Apr 11, 2002 | 06:39 PM
JAY25's Avatar
I have to remove my S/C, to get some seals replaced and Ill have the S/C for about 2 days and see if the screws are tight or not if not Ill just use loctite and tigten them up. Good post and thanks for watching out for all of us, with V2.
Old Apr 11, 2002 | 10:20 PM
i30krab's Avatar
[QUOTE]Originally posted by Y2KevSE
[B]
That would work.
Yep,
The same thing happened to me!!
Old Apr 12, 2002 | 05:28 AM
Albertt's Avatar
This may sound like overkill >>
But you could drill the heads of the screws, and lockwire them.
Old Apr 12, 2002 | 05:31 AM
Albertt's Avatar
Sorry, forgot to post the link too >>
Lockwire link
Like I said, it may be overkill...
Old Apr 12, 2002 | 05:49 AM
JJW95SC's Avatar
Yikes! That could be my oil leak!
Jim
Old Apr 12, 2002 | 06:16 AM
Y2KevSE's Avatar
Re: Sorry, forgot to post the link too >>
Lockwire link
That's a neat little thingy-ma-jig.
Old Apr 12, 2002 | 06:30 AM
SighMax's Avatar
Maxima Enthusiast
It took me over a year to find an oil leak on my car and it wasn't SC at all. It was the power steering hose that loops towards the front of the car for cooling purposes? Anyway, the hose was looped 180 deg and tiewrapped. Where the hose had started to crack and was seeping pwr steering fluid. Oviously it was by small drops initially, but I didn't find out about it till my steering fluid level drop to the level where I can hear the steering when I turn.
I ended up cutting the hose and inserting a looped brake line. No more oil leaks!!
I am just glad that it wasn't the bolt that kev was describing. Our SC's are such a pain in the butt to take out. Why couldn't Stillen design is so that we don't have to take the whole thing off in order to just change the belt???
Jim
Jim
Old Apr 12, 2002 | 03:14 PM
Frank Fontaine's Avatar
Lockwire link
True. I would think that with such a critical component one would torque it to the correct amount, and then recheck it again after running for a while. The white knuckles camp is the old school, ie tighter the better.
Old Apr 12, 2002 | 03:28 PM
Jeff92se's Avatar
I'm needing a caw
Lock wire is probably overkill. I "think" it's traditionally used to prevent LOOSING a bolt/nut. Not necessarily to keep that particular bolt/nut TIGHT. Plus every time you did something, you would have to cut and rewind the wire. Cool idea though.
I still think using one of the Locktite brands would be the best. It seems like the bolts are coming loose due to vibration. The Locktite would help prevent it and dampen the vibrations on the bolts. But as DanNY said, I wouldn't recommend the strongest one or else you will have a hell of a time getting it back off. Also be carefull when using the Loctite, you don't want to contaminate the oil by getting Locitite in the SC. ie.. dab some on there and maybe wait about a min or so before screwing the bolt in.
litch
123
Jan 4, 2024 07:01 PM
doctorpullit
Oct 28, 2019 10:58 PM
mkaresh
Mar 12, 2018 06:48 PM
D Mason
Jun 21, 2016 04:43 AM
bernyp
Oct 2, 2015 10:10 AM
