Will a 5th gen pressure plate fit a 4th gen?
Old Apr 16, 2002 | 01:20 PM
Maxwell's Avatar
Yes, I did a search, and will do another after posting this. I'm very tight on time and was hoping someone here may have done this.
Dave Burnette said he thought he saw mention of someone putting a 5th gen pressure plate on a 4th gen, but couldn't be sure. They have the same diameter, and the flywheels are the same part number.
The 5th gen has 1400lbs (6354kg) of force, which Dave said is quite strong compared to 4th gen OEM (the numbers for which he did not give me).
Anyone know for sure?
I'm gonna keep searching in the meantime...
Old Apr 16, 2002 | 08:05 PM
The New CLIMAX's Avatar
Re: Will a 5th gen pressure plate fit a 4th gen?
After sending my OEM clutch to ACT they said that a 5th gen press plate could fit a 4th gen, but not a 4th gen on a 5th. Hope that helps.
Old Apr 17, 2002 | 04:47 AM
Maxwell's Avatar
Re: Re: Will a 5th gen pressure plate fit a 4th gen?
Are you sure it wasn't the other way around?
I saw this post yesterday, but didn't know that the ACT was actually using OEM parts. Isn't it aftermarket?
Old Apr 17, 2002 | 12:01 PM
Re: Re: Re: Will a 5th gen pressure plate fit a 4th gen?
I am about 95% sure.
Well ACT is aftermarket, but I sent them a OEM clutch so they could produce a 5th gen clutch, but it turns out its the same as the 4th gen. ACT clutch
Old Apr 17, 2002 | 02:58 PM
MardiGrasMax's Avatar
Re: Re: Re: Re: Will a 5th gen pressure plate fit a 4th gen?
ALL Maxima aftermarket pressure plates start off as OEM. They modify them to clamp more.
maxima-junky
Oct 21, 2015 05:17 PM
Finkle
Sep 27, 2015 09:53 PM
maxima-junky
Aug 13, 2015 09:59 AM
sc10692
Aug 9, 2015 09:37 AM
