Painting Valve Cover
Old Apr 17, 2002 | 02:01 PM
BBaker025's Avatar
I just painted my valve cover and it is a UGLY blue. How can i get the paint of? Should i sand it off or what? What temp engine paint should i get?
Old Apr 17, 2002 | 02:09 PM
1MAX2NV's Avatar
Re: Painting Valve Cover
The plastic piece or the aluminum piece?
Old Apr 17, 2002 | 02:17 PM
BBaker025's Avatar
The plastic piece
Old Apr 17, 2002 | 03:47 PM
1MAX2NV's Avatar
only thing you can do is paint over it.
The plastic piece
Old Apr 17, 2002 | 03:48 PM
Vyrus's Avatar
The plastic piece
Use paint thinner (or acentone) and a TON of elbow grease. If you want you can try sanding but it will be too hard to get into some of those cracks. As for the paint, go to a local auto parts shop and they will have "high temp engine enamel". That will be fine.
-Cyrus
Old Apr 17, 2002 | 04:12 PM
DCmax's Avatar
Hi Temp Clearcoat
Is there such thing as a hi temp clearcoat? For instance, I wanted to paint my valve cover body color which is a metallic green. I have the spray can for it, which I will be using on my door handles but Im wondering about it's reliability under the heat. Is there such thing as a hi-temp sealant of some sort that will protect the paint if I dont use a hi temp basecoat?
Old Apr 17, 2002 | 04:19 PM
deezo's Avatar
Sand it. I wouldn't put thinner on plastics. I've seen some bad things happen to plastic because of using thinners.
Old Apr 17, 2002 | 04:35 PM
Vyrus's Avatar
I have also heard the same but I took a chance and used it on my valve cover and it worked perfectly. Very clean, where I know sanding could not be.
-Cyrus
Old Apr 17, 2002 | 04:38 PM
deezo's Avatar
-Cyrus
Cool. I should have thought about the fact that that plastic cover needs to be able to deal with the underhood elements like oil spills and a lot of heat.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
jonreidhead
Jan 6, 2016 09:38 AM
tseng1023
Oct 15, 2015 08:30 AM
