Kyb-agx
Old Apr 19, 2002 | 06:15 AM
SLC I30t's Avatar
Kyb-agx
What setting do most drivers use for everyday driving?
Old Apr 19, 2002 | 07:02 AM
speedtrip's Avatar
Re: Kyb-agx
I started with setting 1 on the front and 2 on the rear. These settings soaked up the bumps fine with little harshness but felt a bit floaty in hard turns and multiple bumps in a quick succession.
Then I changed to setting 2 on the front and 4 on the rear. The floating sensation went away all together but the rear rides a little harsh. The rear rides decent with a full to half tank, but when I get to 1/4 tank or less is when the rear stiffens up. I just changed the rear setting to 3 the other day to try something different.
Old Apr 19, 2002 | 08:22 AM
BlancMax's Avatar
I've only had mine for a couple of weeks (set on 2 & 4) with H&Rs, but the ride is very comfortable. The bumps aren't harse and the handling is outstanding. Getting around corners at 60 mph is much safer now. I have a 96 GLE and the stock struts/shocks were in poor condition, and had some strut chatter (my mechanics term for the noise I would hear going over bumps). I might play around with the settings to see how it effects the ride.
Old Apr 19, 2002 | 09:24 AM
SLC I30t's Avatar
i have intrax and kyb's. over all the ride is good, but i'm worried about going to 18's
Old Apr 19, 2002 | 09:33 AM
BriGuyMax's Avatar
i have Sprints/AGXs....I have them set on 2 in the front and 4 in the rear for daily driving...I'm VERY impressed...
Old Apr 19, 2002 | 09:37 AM
Chunger's Avatar
My other car is a Hybrid
You shouldn't have problems. I was using 245/40s though. As long as you don't hit "huge" potholes, you should be fine... I had them on my car for about 2 years without problems before I increased my suspension travel just recently.
Old Apr 19, 2002 | 10:24 AM
OriginalMadMax's Avatar
Re: Kyb-agx
I run 2 in front, 5 in the rear. It's a bit on the firm side, but soft enough to handle harsh bumps and still handles well. If I want to burn up the twisties, I'd probably go 3/6. I'd only go higher on a really smooth road or track.
Here's suspension tuning info from Roger Kraus Racing. Click "Oversteer/Understeer Correction Sheet" under Tech Sheets.
Old Apr 19, 2002 | 10:34 AM
Supa Lao's Avatar
I have mine set at 3/6 and I on sprints w/ 18's
Old Apr 19, 2002 | 03:44 PM
max'n out's Avatar
With my coilovers(cattmans) I run them with the 19x8.5 with 245-35 rubber either at 2 front 4 rear or 3 front 5 rear, just depends on that day.
busterdawg22
Jul 20, 2006 05:35 AM
busterdawg22
May 4, 2005 09:32 AM
topspeedmaxima
Feb 10, 2003 01:33 AM
ben99sel
18
Nov 11, 2002 05:30 AM
MaxEffect414
Jun 6, 2002 07:54 PM
