Intercooler installed!!!!!!!!!
Old Nov 26, 2000 | 05:47 PM
SteveChicagoSC's Avatar
A 15X7 3" Front Mount intercooler was installed over the weekend by http://www.chargedair.com. Air intake temperature before FMIC under boost was 133 degrees(F).
After the intercooler, the temps were 60 degrees(F) under boost with the outside air temperature at 40 degrees(F) in both before and after tests. It appears that I lost about a half a pound of boost but with the 73 degree drop in air temperature the overall mass with be greatly improved with the increased density. Just remember it's not the quantity of air you want it's the quality!!!!!! Next stop the dyno with an air fuel meter.
Old Nov 26, 2000 | 05:50 PM
vapors smx
hey steve. could you post a pic. also how much did it cost? we live in phoenix arizona, so heat is a problem with us. we would be highly interested in doing this upgrade.
Old Nov 26, 2000 | 06:05 PM
It costed me $1100 installed...
It ended up taking him about twice as long as he had anticipated to do the install. I asked him about pricing for future customers and he stated about $1500.00 to $1600.00.
I'll post some pics on my homepage sometime this week.
Old Nov 26, 2000 | 06:13 PM
vapors smx
thanks for letting me know. sounds a little high depending on the dyno. if it shows notable gains, we will do it. how much modification of the car needs to be done to get it to work. also where is it located? is it in the scoop of the mouth of the car(at the bottom of the front so it is exposed to frontal air) or is it just mounted in the engine bay. i saw someone with an intercooler in the engine bay. couldnt understand how it could cool anything. who should i ask for when i call that place?
Old Nov 26, 2000 | 06:45 PM
The dyno wont do it justice
as the air wont be blowing at the intercooler like at the track. It's located in the scoop of the mouth of the car(at the bottom of the front so it is exposed to frontal air). It's a front mount.
Ask for Tony(the owner). He estimates 30 hp at the wheels.
The track will be the true test. If it stays dry this week a track might be open but I'll probably have to wait until next year to run it.
Old Nov 26, 2000 | 06:49 PM
vapors smx
cool thanks. how much modification of the front end did it take?
Old Nov 26, 2000 | 07:01 PM
The black tube from stillen that goes across the
engine bay is removed. His tubing takes over from there to the MAF. Their is really no modification to the car. The trans cooler and steering cooler got relocated.
Old Nov 26, 2000 | 07:32 PM
got rice?'s Avatar
what type of brand core?
tube/fin design?
delta fin?
bar/fin?
Old Nov 26, 2000 | 08:33 PM
madmax2k's Avatar
Re: The dyno wont do it justice
Bring a strong squirrel cage type fan to the dyno and youll be fine. Some water spray on the IC before you do each run will also help. But, with discharge temps as low as yours (133 F), alot of the heat rejection will be brought about by the sheer thermal mass of the IC which is idependent of airflow across it (until it heat soaks of course). Ive seen 200F+ temp drops across my IC on the GLH with 80F ambient temps...Its amazing what a good IC can do!
Good luck! Im curious to see how it works out!
Old Nov 27, 2000 | 06:29 AM
details
tube/fin design?
delta fin?
bar/fin?
The core manufacturing is in house.
It's a tube/fin core with nockolok brazing. An extruded tube/fin core is the most effective core matrix available.
It's a tube-fin core. Bar-plate is old school.
Old Nov 27, 2000 | 06:41 AM
Wizeguy's Avatar
I've been reading up on turbo's over at miataforums.com It seems pretty typical for the boost to drop after putting in an intercooler. The sollution turn up the boost ie... smaller pulley.
Regards
Wizeguy
Old Nov 27, 2000 | 07:42 AM
Keven97SE
Yep, it's normal for boost to go down when you cool the intake air. Temp/pressure are related, remember, so if you drop temperature, pressure falls accordingly. That DOESN'T mean that FLOW is reduced, though; conversely, flow will go up due to the increased density of the air.
Remember, the SC is still spinning at the same speed with or without the intercooler. If the post-SC pressure has actually dropped, then there's less resistance to the air exiting the SC, hence the flow through the SC will actually increase.
Too many people get caught up with the notion that more boost is better. Not the case. You realize that all I'd need to do is install a small orifice reducer somewhere downstream of your pressure transducer and I could "boost" pressure 5/10/15 psi. All the while flow from the SC decreases. "Boost" pressure is as much an indicator of improperly sized flow paths as it is big/bad compressor.
Old Nov 27, 2000 | 07:50 AM
Keven97SE
As far as HP increase goes, 30 HP gain is far optimistic. Think things out logically: every 10 deg intake temp drop equates to roughly a 1% density increase, hence a 1% HP increase. For a 72 deg drop, that 7% HP increase. For a 250 HP (at the wheels) engine, that's a ~18 HP increase, NOT including the power drop due to the flow restriction of the intercooler core. If you account for that significant restriction, which I'll guess is 40% of your cooling gainm that's a net HP increase of ~10-12 HP at the wheels.
The REAL benefit of the IC is that it allows you to reduce the pulley size on the SC to crank the boost back up. You can go above the original boost pressures now with the IC. Now the combination of the smaller, higher-boost SC pulley and the IC may give you 30+ HP at the wheels, but not the IC alone. At least on the Maxima.
Old Nov 27, 2000 | 07:53 AM
madmax2k's Avatar
Yep. Boost pressure as measured at the intake manifold is just a resistance to flow. High boost means there is alot of restriction present in the flow path to that particular mass flow of air. What is important is not the actual boost pressure, but the MASS of air associated with that flow. A given turbo or supercharger may move lets say, 400 lb/min of air at, say, 25 psi of "boost" on an engine like my GLH (4 cylinder, 8 V head). That same turbo on a larger displacement engine, or one with a better flowing head, might only show 18 psi of "boost" at the same mass air flow rate, and would make similar power as the more restrictive engine at a higher "boost" level.
Old Nov 30, 2001 | 01:18 PM
Nismo87SE's Avatar
TTT because I'm an archiver hehe .
Old Nov 30, 2001 | 01:24 PM
Sprint's Avatar
Dirty A and the Post
Old Nov 30, 2001 | 01:28 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
I remember this thread.
Old Nov 30, 2001 | 01:30 PM
Sprint's Avatar
Ari must be bored with all that snow around him
Old Nov 30, 2001 | 01:31 PM
Y2KevSE's Avatar
I hope you don't go doing the same thing.
Old Nov 30, 2001 | 01:34 PM
Sprint's Avatar
no snow here.. and i am not bored
Old Nov 30, 2001 | 01:35 PM
Keven97SE
Just for nostalgic purposes, I'll even chime in here and say howdy. Howdy, pawd-nuh!
Old Nov 30, 2001 | 01:36 PM
Sprint's Avatar
you know Ari brought up a post a couple days ago and your name popped up.. and i said.. must be old post because Keven doesn't post anymore..
Old Nov 30, 2001 | 01:56 PM
Whitemax's Avatar
Disco Biscuit
Steve, congrats. I would love to see some pics. And Vapors, Long time no see! Glad to see ya posting, and that the SMX is still around......
max'n out's Avatar
mmm intercooler, can't wait to do mine. Man it's gonna be awhile till march.
Old Nov 30, 2001 | 01:58 PM
Sprint's Avatar
read the original post date
Old Nov 30, 2001 | 02:04 PM
Y2KevSE's Avatar
Shhhhh........
Old Nov 30, 2001 | 02:14 PM
Keven97SE
Nope, I really don't post, but then again why would I? No interesting upgrades or discussions, and I can't afford a new Altima or Maxima so why would I want to read about how much better those cars are than mine...boo hoo poor me. Although it's nice to see that some things never change...such as people buying a new car every 6-12 months, trying desperately to get attention on this forum, etc.
I've been drawn into the forum recently by the revelation of subframe connectors. Dammit, I might have to buy another mod.
Old Nov 30, 2001 | 02:16 PM
Jambo's Avatar
Glad to see you stil drop by now and then! I thought you and Wizeguy both had fallen off the Earth.
Old Nov 30, 2001 | 02:18 PM
Sprint's Avatar
yes.. Engineering right?
give me your tranny
Old Nov 30, 2001 | 03:47 PM
Lordrandall's Avatar
give me your tranny
VLSD envy.
Old Nov 30, 2001 | 03:54 PM
Sprint's Avatar
Originally posted by Lordrandall
VLSD envy.
VQVLSD envy..
Old Nov 30, 2001 | 04:10 PM
VQVLSD envy..
VLSDIRS envy.....
Old Nov 30, 2001 | 04:14 PM
Sprint's Avatar
VLSDIRS envy.....
VLSDBALANCEDTRUCKSUSPENSIONNOCAMBERADJUSTMENTBETTE RCORNERONFLATROADS Evny
Old Nov 30, 2001 | 11:18 PM
Whitemax's Avatar
Disco Biscuit
I AM SUCH AN IDIOT!!!!!!!!!!!!!!!!!!!!!!!!!!!!
t6378tp
Sep 29, 2018 04:27 PM
BkGreen97
Apr 2, 2016 05:47 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
