I wonder how many HP the a/c uses?
Re: I wonder how many HP the a/c uses?
Originally posted by Frank Fontaine
Wonder if anyone for the heck of it tested their car on the dyno with and w/o a/c? I've always felt as if the a/c took a noticable amount of hp at low speeds.
Re: Re: I wonder how many HP the a/c uses?
Originally posted by wdave
Probably less than 2 hp. My room unit is 7.5a max at 120v - that's 900 watts (and a lot bigger space to cool). 1hp = 746 watts. Most automotive ac systems disengage the compressor clutch at WOT, bet the Max does too.
Re: Re: Re: I wonder how many HP the a/c uses?
Originally posted by Soon2BMaxed
wow, do u think its only 2hp? it weird that you can really tell the power loss when you turn it on and its an amount that little.
2hp is a lot at idle - how much hp is the engine making at that speed?
Notice that you don't feel it at highway speeds where the engine is making some hp at 2500 or so revs. Look at the power curve and think what even 5hp would do to you when not in the power band.
Originally posted by Yellowbrother
i think when i read the haynes manual it said at wot the compressor is turned off...
-hype
Originally posted by xHypex
The compressor does shut off at WOT, but I think you have to keep it at WOT for a little while. You'll really notice it on the highway in 5th while accelerating It gets warm really fast.
-hype
-hype
Yup, I don't think the compressor shuts off immediately at WOT. You have to keep at it for awhile. I just shut the a/c off when I'm racing someone to make things easier.
Turbonut
46
10-21-2015 08:28 PM
