Nos switch question
Old Apr 29, 2002 | 08:26 AM
SMX's Avatar
SMX
Nos switch question
Ok I was talking this over with JAIMECBR900 & bosco500. Tell me what you guys think. I wanted to hook up a switch but not just any switch, but one with a key. What I want this switch to do is, if the key is not turned on the arming switch is dead. In order to use the system you have to have the key in the arm poisons and then use the arming switch. Any thoughts on if this is possible & how I can hook it up.
Old Apr 29, 2002 | 09:10 AM
Jime's Avatar
Re: Nos switch question
Just hook it up in place of the present switch or put it in series with it so both have to be on to arm it.
You could also hook it in series with the throttle switch but the present arming switch is already in the interior of the car so it would be easier than running another pair of wires in.
Not sure where you would get a key switch but I'm sure they are available.
Old Apr 29, 2002 | 09:12 AM
Sprint's Avatar
yeah.. its pretty simple.. the key switch has the same inputs as the regular toggle switch..
Power / Activated / Negative
just hook up the wires the same way..
personally i think a key is very tacky
Old Apr 29, 2002 | 09:26 AM
SMX's Avatar
SMX
Tacky? I have run into problems in the past...like the one where I purposely turn my system off and get the car back half block away turn on the radio and there is a CD playing that not mine, bass turn up!
Old Apr 29, 2002 | 09:28 AM
Ramius83
It sounds good in theory, but if you think about it hard enough, the only key switches out there are very big and ugly. There are no clean ones that would go good, yet alone something you want to show off. If you want a unique switch, just find a regular single throw, single pull switch that looks different from the rest. Just make sure it has "three prongs" (like Sprint said) b/c two will NOT work. Good luck.
Old Apr 29, 2002 | 09:58 AM
Jime's Avatar
Actually a two pin switch will work just fine. The only reason the cheezy switch that comes with the kit has three is to provide a ground to light up the switch. They are a cheap $.95 cent switch and should be replaced with a quality one anyway.
Old Apr 29, 2002 | 10:15 AM
Sprint's Avatar
you want a nice safe switch.. use the one that 1MAX2NV has.. its clean and it looks nice..
let me go look for it
Old Apr 29, 2002 | 10:25 AM
Sprint's Avatar
the top red one with the cover..
http://www.nosnitrous.com/HiOctn/Pro...ectrical2.html
Old Apr 29, 2002 | 10:36 AM
SMX's Avatar
SMX
I order the 15606 last week from Zex.
James92SE
Oct 8, 2015 04:57 PM
rnb754
Sep 14, 2015 11:39 PM
Maxie40
Sep 14, 2015 11:28 AM
