URGENT: What am I supposed to torque my valve cover back to?
Old May 3, 2002 | 09:51 AM
ohboiya's Avatar
I took it off and simply hand tightened ... must have been a mistake because oil must now be leaking b/c the oil light has been flickering on & off since I changed my valve cover.
Thanks!!!
Old May 3, 2002 | 10:26 AM
njmaxseltd's Avatar
I'll take an educated guess here at between 10 - 15 ft lbs.
Old May 3, 2002 | 10:51 AM
PCGuRu2K's Avatar
I replaced my valve cover with a polished one too.. I just use my hand to torque it down. Mines leakin too. That's cuz I noticed that the gasket wasn't alighned right. I order a new gasket from DaveB. Should be here today.
Old May 3, 2002 | 11:04 AM
Jime's Avatar
Re: URGENT: What am I supposed to torque my valve cover back to?
Thanks!!!
Note that the LH and the RH are different torque values.
Old May 3, 2002 | 12:14 PM
sinewave's Avatar
I would seriously doubt that it could leak enough to lose oil pressure but you not notice a HUGE puddle under the car. Check your oil level, you are probably 2 quarts low. If the level is o.k., check your oil pressure sending unit.
Old May 3, 2002 | 12:38 PM
1MAX2NV's Avatar
Re: Re: URGENT: What am I supposed to torque my valve cover back to?
Notice..it's IN-LB. DO NOT TRY USE FT-LB torque wrech.
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
Apr 8, 2018 09:23 AM
FlaMark
Aug 20, 2015 12:17 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Nintensity
Aug 13, 2015 05:41 PM
