uhh...houston, we have a problem
Old Nov 28, 2000 | 04:33 PM
sx7r's Avatar
my car won't start. when i turn the key, it goes click,click,click,click,click,click real fast. i know the battery is good... so, bad starter??
Old Nov 28, 2000 | 05:04 PM
MardiGrasMax's Avatar
Sounds like the Batt, r u sure its good? If so, then yep its da starter
Old Nov 28, 2000 | 05:23 PM
WoodEar's Avatar
had the same problem 3 times with my '98.
it cranks but won't start, battery good, starter good, have lots of gas too.
1st time got it towed to dealer, they couldn't work on it until the next day, and the next day they started it on 1st try, they still charged me $65 labor.
2nd and 3rd time, i know nothing is wrong, so i just leave it, and it always starts few hours later or the next day.
i think it's got some funny thing to do with alarm system.
Old Nov 28, 2000 | 05:24 PM
sx7r's Avatar
man, i tried whacking the starter too, that didn't work either. i'm just gonna let it sit for a few hours.
Old Nov 28, 2000 | 05:45 PM
yongjun's Avatar
maybe too much NOS
just let it sit
my friends max does that when its cold
Old Nov 28, 2000 | 05:57 PM
Synki's Avatar
Dont bother whacking at the starter, that is what is clicking. The starter still works but it may not be aligned. It could be a bad alternator, but your battery is holding charge like it should.
Old Nov 28, 2000 | 08:30 PM
nismomaxse97's Avatar
Have you messed with the battery cables lately. Sometimes there is not enough contact. This happened in my Rx7 once, and I thought it was everything but the battery. I removed the positive cable and tightened it down in a different position and the rotary turned right over.
Also once I replaced my alternator, but it turned out to be a dead battery. I was returning home in the dark and my headlights were slowly fading so I immediately thought my alternator was not recharging my battery. YOu know what happened next.
good luck
Old Nov 28, 2000 | 11:30 PM
sx7r's Avatar
well, i just let it sit for a few hours and then it started right up... weird
Old Nov 29, 2000 | 06:30 AM
AntGVR4's Avatar
that click click click sound you hear is the relay's
happened on my 92 a lot of times.. not on my 95
What happens is if there isn't enuff power to start the car the electronics won't even attempt to spin the starter ..
the safety relays just click .. this is caused by either dead battery , loose battery terminals or a bad connections somewhere..
in your case it may have been a bad connection somewhere or a fault in the electronics somewhere that self resolved..
Ant
Old Nov 29, 2000 | 08:16 AM
Kenneth's Avatar
OG :)
yup, add some water if needed.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
