18 x 8" wheels with 235/40 tires and 45mm offset: will I have rubbing problems
SubscribeSenior Member
Quote:
Originally posted by seven
anybody have this setup?
you'll be ok.Originally posted by seven
I've got 18x8 w/ 37 off set. No prob. It's only 8mm more.
I think MaxBandit has 245s and he said it rubbed slightly at full turn.Originally posted by seven
Quote:
Yup, I'm running 18x8 with a 45 offset with 245/40/18's and it does rub when the steering wheel is fully engaged.Originally posted by Chunger
Quote:
so if I run 235 i shouldn't have any rubbing problems right?Originally posted by MaxedBandit
thanks guys
thanks guys
There's no way for us to know unless you try it (unless someone else has and post re: it)... I'm sure it will be more than liveable if it even rubs at all.Originally posted by seven
thanks guys
