Help Supercharger belt is sqeeling when cold out ->
Old Nov 30, 2000 | 09:23 AM
Matt_P
Now that it is getting cold out, my sc belt is squeling louding upon startup. Anyone else have this problem. It lasts for a 5-10 minutes(or until the engine bay is warmed up). The belt is probably loose.
What is the planned method of attack for tightning this thing up?
Also, how often do these belts need to be replaced?
Thanks,
Matt P
Old Nov 30, 2000 | 12:24 PM
Phil02E46's Avatar
my guess would be the idler adjuster pulley.. but then what would i know i have that happen too.. but as soon as i start driving it goes away.. idler pulley is down same side as intake looks bronze just get an extender and go for it
Old Dec 2, 2000 | 02:43 PM
SteveChicagoSC's Avatar
Don't forget to loosen the idler adjuster first then tighten the bronze adjuster. Obviously tighening the idler pulley when finished.
Old Dec 2, 2000 | 03:50 PM
Vic's Avatar
Vic
this is something i need help with.
in the cold mine squeals as well. but goes away after warming up.
still sounds like a rusty cricket though
and sometimes my fuel pump doesn't pump gas while starting? my max has a hardtime starting once in awhile in the cold
Vic
Old Dec 3, 2000 | 10:56 PM
Matt_P
Question about that
Where is the idler adjuster located at?
Old Dec 3, 2000 | 11:11 PM
JJW95SC's Avatar
Yea, mine's been doing that also. Lasts for 5-10 seconds like you say...but also stops immediately upon shifting into Reverse. The belt will also squeal between shifts at WOT which obviously results in a loss of boost/power.
I usually take it to Autogear for regular 'check ups' and I'm probably due to have the belt inspected also. I'm thinking that the belt should be replaced every 1-2 years depending on how far you drive and how hard you push it.
Jim
Old Dec 4, 2000 | 07:04 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Question about that
if look from the top you'll see a small pulled on the left side of the SC pulley...a little farther down. the belt is prob blocking it. but you'll prob see the top of the adjustor. the lock nut on the side of the puller you'll have to get under the car to loosen.
good luck trying to get the 14mm socket out after you made the adjustment on the belt. best way is to get a long screwdriver and pop/pry it up from the bottom of the car.
Dan
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
