H4 Wiring
Old May 19, 2002 | 09:25 AM
SLC I30t's Avatar
H4 Wiring
Ok for anyone who knows and especially those with the Cefiro 1 piece. Where do I get this wiring harness? Do I use the APC H4? The wiring diagram looked like I needed to use a rocker switch. Will our stock wires handle that extra wattage that the H4 uses?
Old May 19, 2002 | 03:40 PM
maxxed's Avatar
The H4 wattage is about the same 55/60 VS. 45/65 for the 9004's so you shouldn't need to upgrade the stock wiring harness.
I would solder the H4 plug to the existing harness, so yoiu get a good connection. As for the wiring harness, a plain sealed beam harness from any auto store should fit. ALso I think Nissan dealers can sell you a "repair harness" ( a plug with a short wire )for about $10.
The APC H4 would certainly work, but you shouldn't need it unless you are trying to run higher wattage bulbs.
Old May 19, 2002 | 03:43 PM
SLC I30t's Avatar
The APC harness looked like I would have to run a second switch just for my lights... I want use of my stock light switch.
Old May 19, 2002 | 04:13 PM
maxxed's Avatar
I wouldn't go with the APC harness then. I think some aftermarket harness plug into the factory 9004 sockets, of course you need to wire into the battery connections, but at least you wouldn't need an additional switch. I don't blame you for not wanting another switch
Old May 19, 2002 | 04:28 PM
I30CeFiRo's Avatar
Re: H4 Wiring
The stock wiring will be fine. Just go to a local junkyard and find a couple of H-4 sockets, that's all you need to get.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
