New Tranny Pics and a couple ?'s...
'Trynna' is not a word
Picked up my new tranny tonight. $700 shipped, VLSD with 7k miles.
First pic is of the whole tranny, as you can see, I got the manual motor mount I needed,the slave cylinder and one clutch line, and all the wiring:
Second pic is of the right (inside) side:
Third pic is of a slight damage to the right seal It is just a little tear, I will just replace the seal for a piece of mind:
Question is, how easy is it to replace the right seal? Do you have to disassemble the tranny, or pull the case apart? The tranny appears to have no damage, other than the slight tear to the seal, and still looks really new...
Ya I know, but thanks anyway.
Originally posted by RussMaxManiac
Remember to get some VLSD Drive shafts as well from a I30 or AE Maxima. The regular ones will not work on a VLSD system.
The seals will be one larger then the other. Replacing it is very easy, DO IT WHILE THE TRANNY IS NOT ON THE CAR! Take a large screwdriver and pry out the old seal. It may destroy it but who cares. Anyway, to put the new one in, put thick grease around the outside lip of it. I used a hammer and gently tapped around the permeter of the seal to wedge it in. DO NOT DRIVE IT IN TOO FAR TO THE POINT THE SEALS MOVE OR YOU WILL GET A HUGE LEAK AND CRY lIKE I DID. The seals should be snug and sit flush with the tranny case. Don't mix left and right up.
Originally posted by mtrai760
Thanks. Ive replaced seals on hydralic systems and helicopter tranny's before, so it should be a piece of cake.
Helicoptors have transmissions????? I though they were direct drive....like airplanes.....
Nope, helicopters have transmissions, some even have clutches! Helicopters I work on have two transmissions, one in the rear, which gets power from the engines (2) and sends it to the rear rotor disc and the foward transmission via a drivshaft, the turns the foward transmission... They have to have clutches so that the engine can turn free of the tranny, and vice versa, they are not normal clutches though, they have teeth that stand up when they are put under torque...
damn I wish I coulda got a tranny that cheap a month ago. blew mine up and had to take what I could find ASAP. cost me $2000... but it's brand new and has VLSD too.
That's how I ended up with an Automagic, Some idiot made an illegal U-turn in front of my 96 5spd and wrecked it, and I HAD to have a new car ASAP, all I could find with low miles was my Auto, now I'm gonna fix it...
Originally posted by Matt93SE
my GF has those too.
James92SE
142
01-02-2024 09:23 AM
catalinvint
09-16-2015 07:48 PM
pktaske
09-04-2015 08:40 AM
