Finally installed WSP Y-Pipe and Greddy Exhaust System
Old May 21, 2002 | 11:05 PM
JerzMax's Avatar
WOW What a difference. It has a nice deep tone, no bee's in the can noise. Its a bit loud, getting used to it, but I love it though. I feel the gain at the top end. I'm pleased with the setup
Old May 22, 2002 | 01:45 AM
CIRCO's Avatar
Re: Finally installed WSP Y-Pipe and Greddy Exhaust System
Which one did you get? SS, mandrel bent?
Old May 22, 2002 | 01:57 AM
James92SE's Avatar
2 VE's are better than one!
I've got the S/S Mandrel Bent Y, Catco Cat, and GReddy catback.....it's quieter than a mother
Old May 22, 2002 | 08:47 AM
y2kse's Avatar
Its a bit loud . . .
A bit loud? That's putting it mildly. My Y-pipe with a straight-through muffler was so loud you could hear my car coming from a couple of blocks away. And the drone inside the cabin nearly drove me insane. That's why I went from a Magnaflow muffler back to an OEM rear section . . . with no perceptible loss in power, I might add.
Oh well. To each his own.
Enjoy the ride!
Old May 22, 2002 | 08:49 AM
y2kse's Avatar
Re: Re: Finally installed WSP Y-Pipe and Greddy Exhaust System
Whoa, James92SE. My guess is you've attended way too many really loud rock concerts. If you consider a Y-pipe and a Greddy exhaust "quieter than a mother", you need to have your hearing checked!
Old May 22, 2002 | 09:54 AM
JerzMax's Avatar
I have the Aluminized mandrel bent...
Old May 22, 2002 | 10:00 AM
JerzMax's Avatar
Enjoy the ride!
Ok maybe not a bit loud. The drone inside is getting to my ears, hope I get used to it. The drone is louder at lower rpm's that at higher....
Old May 22, 2002 | 10:12 AM
y2kse's Avatar
Re: Re: Re: Finally installed WSP Y-Pipe and Greddy Exhaust System
Right. The drone is at its worst between 2500 to 3500 rpm, the normal range for freeway driving in 5th gear!
I'll tell you what, JerzMax. 5th Gen guys are installing catback systems and they're selling their OEM mufflers dirt cheap. Believe it or not, I've seen 5th Gen mufflers go for as little as $50.00. The 5th Gen muffler is based on a Skyline design, so you know it's efficient. And I can tell you from personal experience that a Y-pipe, aftermarket cat and 5th Gen muffler is about the perfect combination from a noise vs performance standpoint.
HIGHLY RECOMMENDED!
Old May 22, 2002 | 10:19 AM
James92SE's Avatar
I dunno, all other 3rd gen guys I've talked to with the same setup all consider it pretty darn quiet. At idle all I can hear is the CAI sucking in air, and it's pretty darn quiet anywhere under about 4K RPM.
Old May 23, 2002 | 03:42 PM
krbga's Avatar
When the DRONE starts to annoy you (and your passengers) I have found a solution (I wanted to keep my greddy muffler look + good shop talk)
1. Have your muffler shop install a long resonator right after the cat
2. still loud...have them install another short 9 inch resonator after the first turn on your piping.
I have done both, it is no longer loud.
Sounds very very deep. Highway it sounds very very deep.
Drone is now a deep PURRRR. No longer RICEY.
Still a BEAST at WOT.
JRod28
Dec 29, 2023 09:56 PM
rbuswell
Nov 12, 2016 04:11 PM
stromm
Aug 27, 2015 04:13 PM
maxinout93
Aug 20, 2015 02:17 AM
wyobbagy
Aug 15, 2015 02:28 PM
