tried replacing cloth door inserts with vinyl but.....
Old May 25, 2002 | 11:22 PM
Nismo's Avatar
I read on here that the leather door insert piece was held in with clips or something thats on the back of the door panel so I said no problem, Ill just remove it from the door panel and put vinyl over my cloth insert but I found out that the cloth insert is just a piece of cloth glued on to the door panel itself instead of a seperate piece that is clipped on to the doors like I read about Anyone have any ideas of how to replace the cloth on my doors?
Old May 25, 2002 | 11:56 PM
Shadow's Avatar
Re: tried replacing cloth door inserts with vinyl but.....
You have to use some really good spray adhesive. that's what the interior shop did when they did my doors.
Old May 26, 2002 | 12:02 AM
Nismo's Avatar
Re: Re: tried replacing cloth door inserts with vinyl but.....
did you have cloth inserts? did they put the vinyl over the cloth or did they remove that? also, Im planning to vinyl my rear deck so do you have any tips for that? thanks
Old May 26, 2002 | 08:49 PM
Shadow's Avatar
Re: Re: Re: tried replacing cloth door inserts with vinyl but.....
I had the cloth inserts. You have to remove that. And the rear deck is the same, pull the factory cloth/felt cover and revinyl it.
Old Jun 2, 2002 | 04:34 PM
FJC's Avatar
FJC
Re: Re: Re: Re: tried replacing cloth door inserts with vinyl but.....
Shadow, leatherseats.com recommends to leave the factory fabric on... Is it better to remove it?
Old Jun 2, 2002 | 04:43 PM
Maximan190's Avatar
Shadow the door inserts look good, how did they get it on nice and tight and smooth? You 4th gen guys have the same problem i do with the door panels, the 3rd gen cloth is also glued right onto the door and is not a seperate detachable piece. Ill be replacing my cloth panels with black leather to match the seats (im making this a DIY job, im practicing on a scrap door panel from the junk yard before i start butchering mine) You happen to know what type of adhesive was used on your inserts?
Old Jun 2, 2002 | 10:56 PM
Nismo's Avatar
the guy at the shop told me to use contact cement but Im not shure if there are different types of contact cement though
Old Jun 3, 2002 | 05:58 AM
AndyXXL's Avatar
Re: Re: Re: Re: Re: tried replacing cloth door inserts with vinyl but.....
No, do not remove the factory cloth in the door panels. Glue leather/vinyl over the cloth.
stevesmax
Dec 17, 2020 11:57 AM
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
homeyclaus
Sep 3, 2015 06:15 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
