The Poorman's HAI...
#41
Originally posted by Vyrus
It can be placed anywhere in the intake piping... just stick in between any seam where it can get air and you will be fine.
-Cyrus
-Cyrus
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
#42
Originally posted by costcowholesale
how is teh metal piece attach to the airbox if its not glue
is it screws
-Cyrus
#43
are all apc cone filter reusable? my friend got one APC cone & he said its not reusable
Also, that adapter plate is held on by a couple of rivets, from what I can remember. I spent some time prying the brass adapter out. I messed it up so bad that I had to pound it back straight with a hammer against the driveway. If you have a drill bit tiny enough, it's easier to drill a very tiny hole through the rivet and it will come out. It's been so long since I did tha job, that it's hard to remember. I hope this helps.
#45
Originally posted by KLoWnPR109
Would I need this brass piece if I was going from the HAI to a CAI? I did this mod a couple months ago.
-Cyrus
#46
I did the mod, and the sound is GREAT. Here is a question, I got the filter from AutoZone, the generic one for 19.99 (came in blue, red, silver...etc.) It has those thin wire on the filter, is this mean it reusable? and do I have to oil it before use?
#49
got any tips on taking that out?
#50
I did this exact thing a couple yrs ago before I went to CAI...
Not sure who actually "invented" this, but I know the 3rd gen guys have been doing this for a very long time.![Wink](https://maxima.org/forums/images/smilies/wink.gif)
My old setup.....Disregard all those wires. Was having a problem with my headlights back in the day, but it's all good now!![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
![](http://images.cardomain.com/installs/140000-140999/140687_9_full.jpg)
#51
did you break/bend that metal piece fro teh stock air box?
#55
heres some pics of it installed in my 4th gen if anyone was curious
http://members.***.net/wope/photo458.jpg
http://members.***.net/wope/photo459.jpg
http://members.***.net/wope/photo461.jpg
#56
just did this today. it is very loud but i cannot feel much of a change in performance, but maybe it is just me. i used the apc intimidator filter and made a gasket to make it sit flush. i have one question though, am i supposed to oil the filter or is it ok as it comes? also did you guys reset the ecu after the install?
#58
If that's the bottom of the airbox, I just drilled it out alittle bit and it came out. Looks like the 4th gen guys are catching onto a 3rd gen trend
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
#59
#60
its stuck no matter how hard I turned it, used a plyer, screw driver, wrench, wd-40
everything
everything
You can detatch it because there is a bolt underneath it and it is turning with the screw. Use a pair of needlenose pliers to secure the bolt and then unscrew it. As I recall that wasn't really tough though.
![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
-Cyrus
#61
Sorry I just got a chance to hop on the computer. Anyways...
You can detatch it because there is a bolt underneath it and it is turning with the screw. Use a pair of needlenose pliers to secure the bolt and then unscrew it. As I recall that wasn't really tough though.![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
-Cyrus
-Cyrus
#62
guys I couldn't get this screw out
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
![](http://images.cardomain.com/installs/210000-210999/210665_27_full.jpg)
-Cyrus
#65
CYRUS, did you oil your apc intimidator filter?
-Cyrus
#67
is there anyway to secure it without putting the bottom piece on?
I ddi mine today & its all wollowey
-Cyrus
#68
You might be able to rig up a stand or buy the Stillen stand. Most people with HAIs have this problem as well so try a search. I would just keep the bottom on, it gives you more air anyways.
-Cyrus
-Cyrus
#69
I'm gonna try zip ties tomororw or put the box back on... but leaving the box there it'll just rattle up & down inside the box, whats the difference?
-Cyrus
#70
It won't rattle in the box. The box supports it so much and fits so perfectly that it stays perfectly still. Believe me I have looked at idle and listened at WOT and there is no rattle.
-Cyrus
-Cyrus
#72
#75
This was my first mod, and its awesome. I would have been happy if I paid 3 times what i paid for this.
I paid $15 bucks for my filter and used some leftover K&N filter oil. I used some gasket maker and some silicone to seal the brass gasket to the MAF. Also, I put some washers in between the gasket and the MAF so I could tighten the bolts down without bending the gasket.
Click on my hompage if you want to see higher res pics
This thing sounds awesome; I find myself looking for an excuse to floor it. Not only that, but it doesn't sound bad or ricey and its only prevelant over 3,000 RPM so if you don't want to be heard you don't have to.
If you haven't already done it, do this!! You wont regret it.
Thanks Cyrus
![](http://images.cardomain.com/installs/214000-214999/214044_1.jpg)
![](http://images.cardomain.com/installs/214000-214999/214044_2.jpg)
![](http://images.cardomain.com/installs/214000-214999/214044_4.jpg)
Thanks Cyrus
#77
does this 'ghetto intake' add any power or is it just sound? does it take away low end like a popcharger? (on an auto 4th gen)
#78
I dont know about you 4th gen guys, but I know on 3rd gens (I can only speak of the VE's though) we have an intake resonator.
Remove the resonator, plug up the hole, and it makes the intake sound 10 times better. By no means does it add power, but it sounds way better.
I also did the "PCV Breather Mod" when I did this too. I didnt notice any of you guys doing it. I doubt it does much, but it sure looks cool.![Stick Out Tongue](https://maxima.org/forums/images/smilies/tongue.gif)
Hmm and about all this oiling the filter stuff, was I supposed to oil mine? I just bought the APC rice boy filter at Autozone back when I did the "pop-charger". I still have the same filter on my CAI now, never did anything to it, just took it out of the package and bolted it on. Was I supposed to oil it?
#79
The oil attracts the dirt and improves the filtering. Also, since the dirt is suspended in oil, when you use the soap to clean it, the dirt goes with it. I'd just use the K&N Filter Cleaner Kit. Mine was 9 bucks at Auto Zone
#80
