Sunroof leaking (not drain holes), because of sag on one edge! :(
Michigan just got peed on by the Gods and it finally pushed me to check if my drain holes were clogged since I was getting some water in to the cabin.
Turns out, the drain holes are clear BUT the sunroof sags at the rear left corner when it is fully closed. Water is entering there and dripping into BOTH the drain channel (not a problem since it drains out) and the guide rail path (which doesn't drain anywhere)
Anyway, the water that collects in the rail path eventually makes its way to the front and leaks through the two bolts that pass through to the cabin.
I've managed to kill the leak by tilting my sunroof slightly. I'm also going to put some silicone on the two bolts to prevent water entry.
However, here's my question: anyone know how I might adjust the left tilt arm so I can have my sunroof sit higher and seal the corner? It's annoying to have to "untilt" my sunroof just to open it every time and "retilt" it to seal it properly.
Re: Sunroof leaking (not drain holes), because of sag on one edge! :(
Federazione Italiana Giuoco Calcio
ITALIA!!!! Coca-Cola ranked #6 but we'll be #1 FIFA
Originally posted by lcf
where in michigan you at? im in the southwest... st joseph.
we didnt get much rain.
See this: http://www.clickondetroit.com/det/ne...30-200555.html
Hope it never happens to me
Re: Re: Sunroof leaking (not drain holes), because of sag on one edge! :(
Originally posted by Frank Fontaine
I would concentrate on the leaking not the operation.
Forge277
Jun 13, 2016 09:26 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
