Spring installation tools?
Old May 30, 2002 | 11:19 PM
1FSTMAX's Avatar
Do you guys know what are the size of the sockets, wrenches etc... Needed to do a spring installation?
Old May 31, 2002 | 12:43 AM
Nismo's Avatar
Re: Spring installation tools?
14mm for the top front strut mounts and I believe the bottoms are 17mm and the ones on the top rear struts are 12mm thats it I think. if u want torque specs I can give them if u need them too
Old May 31, 2002 | 01:38 AM
papasmurf's Avatar
Honda Convert!
Re: Re: Spring installation tools?
You will also need a 19mm open end and manual spring compressors, jack stands, vice grips and a few other things, where are you located, if you are near md i can give you a hand.
Bruce
ps ive done a few of these
Old May 31, 2002 | 08:38 AM
1FSTMAX's Avatar
Re: Re: Re: Spring installation tools?
Bruce
I'm in SoCal.
Old May 31, 2002 | 08:25 PM
1FSTMAX's Avatar
Thanks guys for the input. I'm going to install my sprints tommorrow.
Old May 31, 2002 | 09:01 PM
JAY25's Avatar
19MM for the front center, I forgot what size are the three top nuts, but for the bottom of the front strut that will be 17MM and a 19MM open wrench or adjustable wrench to hold the nut from spining. You will need a set of pliers to remove the clip that holds the brake line on your front strut.
The rears, you will need a 12MM deep socket and a 14 or 15MM open end wrench to remove the center nut. On the bottom you will need a 17MM socket to remove the bolt holding the shock in place. I highly recommend you get a breaker bar.
Old May 31, 2002 | 09:07 PM
Nismo's Avatar
dont forget a foot lb torque wrench
35- front upper strut mount
110- lower front strut mount
15- upper rear
85- lower rear
50- front top nut
15- rear top nut
Old May 31, 2002 | 09:23 PM
1FSTMAX's Avatar
I will be using a impact air gun.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Colossus
Sep 9, 2015 05:46 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
