Road Race Peeps- Brake Pads
I just ran 2 days at NHIS in hot weather with Carbotech Panther+ pads. I highly recommend these! There is still half the pad left and they never faded once. When I had Porterfield's I could chew thru them in a day under similar conditions and had to back off periodically to allow them to cool off.
The guy at Carbo-Tech can be grumpy, but these pads rock. Well worth the purchase price.
They were $149 for the front, I still have Porterfield's on the rear. At first I was wary because of the price, but they're probably cheaper in the long run since the last much longer. This is on stock brakes. He will line any backing plate you send him with the material of your choice, or he can get the plates for you and do it, but he'll charge you like $10 per plate.
Carbotech is very racing oriented, I found out about them through a local shop and also read a little about them in Grassroots Motorsports, so I imagine find pads for a Wilwood setup wouldn't be a problem.
Rotor wear seems neglible. I use the cheapie Autozone rotors and I have a seperate set for track and street. The current set only sees the CarboTech pads. I've run Limerock once, NHIS once in the rain, and NHIS in the dry for two days. The rotors still look like I could go double that easily. If I wiped the pad transfer off they'd look like new.
Originally posted by Chinkzilla
hrmmm going to willow springs in a week, where can I buy these? got a phone number or anything?
Re: Road Race Peeps- Brake Pads
Re: Re: Road Race Peeps- Brake Pads
Originally posted by sinewave
Those Porterfields that you burned up, were they the R4S's or R4's?
Originally posted by deezo
I say the same for Performance Friction pads too and they don't dust like other pads. I haven't cleaned my wheel covers in about 2 weeks and they still look pretty clean.
Re: Re: Re: Road Race Peeps- Brake Pads
Performance Friction has some great pads for a basic street application. Unfortuneately, none of their compounds suitable for track driving are available for the Maxima.
They were the R4S. I was going to try a set of R4's but someone recommended CarboTech and mentioned that Porterfield had some quality control issues. I'm sure I wouldn't burn through the R4's anywhere near as fast, but since the CarboTech's and the R4's were similar in price, I wanted to give them a shot first.
I have used the R4S for autocrossing with no problems and have given some thought to trying them out on a road course. Maybe I ought to re-think that!
Re: Re: Re: Re: Road Race Peeps- Brake Pads
You are not the first one that I have heard has had problems with the R4S on a road course. A mechanic/shop owner I know road races a 280Z and really likes the R4.
06-06-2017 02:01 PM
doctorpullit
12-12-2015 09:39 AM
HerpDerp1919
09-29-2015 02:02 PM
