A/F meter vs EGT meter
Old Jun 6, 2002 | 04:25 PM
Tanman's Avatar
To those with both the A/F meter and EGT meter, they both pretty much do the same thing: tell you if you're running rich or lean. So why have both? They look cool, but they aren't cheap, so I'm trying to figure out which to get.
Thanks,
Old Jun 6, 2002 | 04:28 PM
Jeff92se's Avatar
I'm needing a caw
Cheaper a/f meters aren't nearly as accurate as a decent EGT probe. This is what I'm gathering here on the .org. So unless you invest in an expensive a/f, I would probably forgo that one and add something else in it's place. Fuel press, oil press, oil temp, water temp or whathaveyou
Old Jun 6, 2002 | 04:33 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Go with boost and EGT. If you want another one, go with fuel pressure. If you want an even number, go with oil pressure. If you want a number divisible by 10, get a water temp gauge.
Do you see the snow ball effect? Hehehe
Old Jun 6, 2002 | 04:39 PM
Tanman's Avatar
Cool, thanks for the information. I was planning on going with an Autometer electronic A/F meter for $49, but maybe not anymore. I notice the EGT meter costs $112, so you're right it's probably more accurate. The A/F meter does look cool though
Old Jun 6, 2002 | 04:46 PM
Tanman's Avatar
I plan on putting three on the left A-pillar, one on each side of the existing gauge cluster, and three in the console.
Just kidding.. I'll just have the three on the A-pillar. I already have a boost gauge, and it looks lonely all by itself on the A-pillar.
Old Jun 6, 2002 | 05:46 PM
bullseye's Avatar
I'd go with an electric Fuel Pressure Gauge and an electric EGT Gauge, which will probably require the separate purchase of an EGT Gauge Probe, about another $100. If you get Autometer Ultra-lite gauges from Summit, that'll come to about $400 or so.
Don't get mechanical gauges for the inside of your car. These require you to run hoses/lines inside the passenger compartment. No good. If you install electrical gauges, only a thin wire runs through the passenger compartment to the back of the gauge. That's good (& safe).
Cheap A/F meters only provide a light show. They are not quick nor accurate enough to do anything but. Good A/F meters come with their own broad-band sensors, and run $400+.
If you had *good* gauges for both EGT and A/F, you would have a redundant safety system to ensure your engine does not run too lean. If you were enjoying the benefits of an *expensive* boosted engine build-up, you might feel a redundant gauge set-up was well worth the added investment...
Good luck.
Old Jun 6, 2002 | 06:15 PM
Tanman's Avatar
Thanks for the information! Lots of it too.
I plan on getting the Autometer Ultra-Lite EGT meter with probe, but the one with the probe is a mechanical gauge. The EGT without probe is listed as an electrical gauge for about $10 less. Weird?
I also plan on getting an oil pressure or temp gauge, and a tranny temp gauge.
I don't really see the need for a fuel pressure gauge. What can you tell from it, if you're leaking gas or something? Sorry.
I might also get a new boost gauge that has PSI measurements instead of bar. My Greddy boost gauge shows bar and it's hard to see how much boost you are running.
Old Jun 6, 2002 | 06:38 PM
irvine78's Avatar
Re: A/F meter vs EGT meter
Thanks,
EGT...
Old Jun 6, 2002 | 06:54 PM
matt calder's Avatar
hehe, I Have chosen the even # route just short of being divisible by 10.
Go with the EGT gauge, unless you buy a Tomei or Greddy A/F gauge.
Old Jun 6, 2002 | 06:56 PM
DAREN's Avatar
Good luck.
so who sells the good A/F guages?
Old Jun 6, 2002 | 07:15 PM
Y2KevSE's Avatar
Ooooo..... what else did you get?
Nitrous pressure, fuel pressure, EGT, and .....?
Old Jun 6, 2002 | 07:36 PM
Tanman's Avatar
I really like the look of the Autometer A/F gauge versus the dual needles on the Tomei gauge. Can't find a pic of the Greddy gauge.
Old Jun 6, 2002 | 07:38 PM
Y2KevSE's Avatar
http://boostedmaximas.com/jane97se/i...ir_fuel_gauge/
Old Jun 6, 2002 | 07:45 PM
Tanman's Avatar
Cool, thanks for the link. That's where I saw the pic of the Tomei gauge
The Greddy and Tomei look good. I still prefer the look of the Autometer, but it's not worth it if it's not accurate.
So what's a good reading on the Greddy look like? 8, 9, 10,...?
Old Jun 6, 2002 | 07:48 PM
Y2KevSE's Avatar
You will fluctuate when off boost... low 12's when boosting.
bryants95max
Oct 2, 2015 12:52 PM
JMag90
Aug 25, 2015 09:17 AM
Superbform
Aug 11, 2015 08:10 PM
Bryan H
Nov 28, 2000 10:54 PM
Shingles
Nov 14, 2000 10:48 PM
