B&M Supercooler has extra parts?
Anyone who has installed the B&M Supercooler transmission cooler, did you receive extra parts in the bag? It's sealed, but has several extra bolts, some metal rails, and 3 extra barbed hose ends. I can understand the extra barbed hose ends (different transmissions with different size fittings), but how do you know if you're supposed to use the rails or the bolts?
Thanks,
Thanks,
Re: B&M Supercooler has extra parts?
Thanks,
Thanks,
https://maxima.org/shoptalk/sub_modi...er/index.shtml
This shows the Hayden but all the stuff is pretty well applicable to the B&M. I did a complete fluid change at the same time and put in Mobil 1 Synthetic.
Jim
Re: Re: B&M Supercooler has extra parts?
Thanks for the info Jime, it is a universal cooler so I figured they included parts for different cars. Just wanted to be sure
About buying extra hose, the kit includes 4 ft of hose. According to Greg's instructions, that's the same length of hose that the Hayden provides, but most people say they still need to buy extra hose. Why is that?
I just got Don's VB mod like 3 weeks ago, and replaced the fluid then with Redline ATF. Got some more today for $9.50/bottle for the tranny cooler install.
Re: Re: Re: B&M Supercooler has extra parts?
You are ok on the ATF then, just thought I would throw that in because its the perfect time to change the fluid.
I have put my hand on it a few times just to check and it does get warm. I especially like the bypass setup for the colder climates to make sure the fluid gets warm, good feature.
Re: Re: Re: Re: B&M Supercooler has extra parts?
Originally posted by Jime
I was sure there was more hose in the B&M, all I know is that I had enough to do the job and the other write ups I have read for Hayden all said they had to buy more.
derekinthez
11-13-2022 04:00 PM
MR2 T'd
07-09-2021 05:06 AM
