What do I use to remove paint?
Old Jun 6, 2002 | 09:01 PM
Larcenist's Avatar
What can I use to remove paint from metal. I need to get paint off my exhaust and underbody of my car as well as the black rubber trimmings around my car. Whats good to use.. product to buy?
Old Jun 6, 2002 | 09:50 PM
Matt93SE's Avatar
STFU n00b!
to get it off the exhaust, lacquer thinner works great. just don't get it on your body paint.. it'll take it off too.
as for the window trim, use a pink rubber eraser (those big rectangular jobbies you used in middle school) and rub away. sounds weird, but it works. there's actually special compounds of rubber made to remove overspray sold at body supply shops, but they're quite a bit more expensive and don't work any better than a $0.39 eraser.
as for the undercarriage, I'm not sure.. I personally wouldn't worry about it.
Old Jun 7, 2002 | 10:43 AM
Larcenist's Avatar
thanks for the info. Where can i get the lacquer thinner? Would it be at home depot?
Old Jun 7, 2002 | 10:56 AM
BlackCat's Avatar
RIP '98 Maxima SE
Yep but take note that they don't seem to carry small tins of lacquer thinner.
Old Jun 7, 2002 | 11:17 AM
1MAX2NV's Avatar
Go to autozone or pep boys. Take alook at the paint prep section. They have this product called Aircraft remover or auto finish stripper. Powerfuel stuff and very nasty. You spray it on any metal painted finish and it will bubble up 15 mins later. You can then scrape it away and rinse it off with water.
Old Jun 7, 2002 | 01:26 PM
deezo's Avatar
Re: What do I use to remove paint?
My father had this problem in the past and used Brillo to remove the paint from his chrome addon's when he had his van and all he had to do was ask me first.
Use carb cleaner. I know it sounds crazy but it works. Spray it onto a cotton cloth, then rub away. Be sure to spot wash the spot and wax afterward.
Old Jun 7, 2002 | 01:27 PM
//M5'ver
Concentrated Sulphuric Acid ....
Old Jun 7, 2002 | 01:29 PM
deezo's Avatar
Or maybe hydrochloric.
Old Jun 7, 2002 | 01:31 PM
//M5'ver
Sulphuric Acid i think has a better reaction to metal compounds.. should put on a nice little show
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
