why wouldnt the bose amps work with aftermarket speakers?
Old Dec 4, 2000 | 06:28 PM
Ryan93SE's Avatar
i hooked my fosgates up to the factory amps and they were LOUD.. could this hurt the speakers or amps?
Old Dec 4, 2000 | 06:44 PM
Botos's Avatar
This is a Bad Thing. Bose does wacky proprietary stuff like use different impedence speakers and power levels. If you want to run a combination of Bose/non-Bose stuff, you really need to get the proper adapter to avoid blowing your stuff up.
Old Dec 4, 2000 | 06:49 PM
Ryan93SE's Avatar
the speaker i took out was a normal speaker ...
with a magnet on the back.... the amps or what i think they are to the side of it...
Old Dec 4, 2000 | 07:07 PM
metallic97gxe's Avatar
Master Will
Don't quote me on this but I was told that all Bose stuff in Maximas is wired in a 1 OHM load. Anybody else?
Old Dec 4, 2000 | 07:39 PM
brubenstein's Avatar
The Bose speakers (just the speaker, not the amp) are 1 ohm (I measured it). Nominal impedance for auto speakers are 4 ohms. There is no electrical reason why you can't replace the Bose drivers (raw speaker) with higher resistance speakers. It just may not sound quite right.
Old Dec 4, 2000 | 08:20 PM
Ryan93SE's Avatar
thats what i was thinking....
just cause the bose speaker was 1 ohm...why wouldnt the amp power a normal speaker.... i just dont want the speaker to fry in 6months...
the bose amp is an amp...and has no impedence...therefore i feel it should work correctly with other speakers... and if it does sound right...i think i have a bonus of watts to each speaker and therefore i dont have to buy another amp
i hope
Old Dec 6, 2000 | 04:08 PM
Micah95GLE's Avatar
Since the amp is designed to run at 1 ohm, running it at 4 ohms will yield about 1/4 of the normal wattage, so you're losing a lot. But then the sensitivity of the speakers plays a part, so you might make some of the loss back.
Old Dec 6, 2000 | 04:13 PM
Ryan93SE's Avatar
i ended up just wiring it to the speaker wires with no amp...
i will add a 4 channel later.. it sounds good but the highs break up at high volume i guess due to not enough power
Old Dec 6, 2000 | 08:05 PM
93 SE's Avatar
would the amps still work if you use aftermarket radio and speakers or is it only compatible with bose
Old Dec 6, 2000 | 09:26 PM
Ryan93SE's Avatar
they worked and will work.... but in the long run it wont
be good for them
Old Dec 7, 2000 | 09:00 AM
Maxima95GLE's Avatar
Additional Bose info on stereo, speakers, amplifiers, etc.
I found some additional info on the BOSE stereos from a BOSE engineer, and I've put in the following post. It might be useful to further explain their products.
https://maxima.org/forums/showthread...threadid=12677
jerrod99_se-l
Aug 27, 2015 08:27 PM
Mcnabb34
Aug 11, 2015 08:45 PM
PhalC1
Aug 5, 2015 02:36 PM
