sprayed for the first time
I sprayed my Nitrous for the first time the other night and all I have to say is it is AWESOME. I like it alot. I am only spraying a 50 shot for right now.
It feels really good and I am very happy with it now. 2nd gear halls a$$ now, I cant even imagine what it is like with a 100 shot. I do have some questions though.
My fuel pressure was at 56 psi or so and I am wondering if this is good for a 50 shot. Is this lean, rich, etc.
My EGT's peaked out at 760C so It seems like I am running pretty well but would like some input on this though.
Also which way do you turn the FPSS to make it go up or down. Or how does it come from the box when you first get it. Should I make it go all the way to the bottom and work my way up or what. Also when you turn it does turning it right increase or decrease the settings. I think that is about it
matt
It feels really good and I am very happy with it now. 2nd gear halls a$$ now, I cant even imagine what it is like with a 100 shot. I do have some questions though.My fuel pressure was at 56 psi or so and I am wondering if this is good for a 50 shot. Is this lean, rich, etc.
matt
Re: sprayed for the first time
matt
matt
Cool
Glad ya got it working Matt. Sorry I didn't call ya back, works been hecktic lately. Are you using a full sweep FPG? Your EGT's are a little low, so it sounds like you may be a little rich, but ideal FP is around 60-62 psi. PLEASE make sure you check your plugs, I cannot stress this enough. As far as FPSS goes, I think clockwise increase and counter clockwise decreases the amount of fuel pressure you need, but I could be wrong. I know it does take more than one turn to get results though. If you need any more help feel free to call me, I'll try and pick up next time
oh yeah, have fun!!!
Re: Cool
My bottle pressure has been around 1050 to 1100 both times that I have sprayed. So i dont think that is a factor.
What are the different ways that I can lean it out a bit. Should I be aiming for about 800C on my EGT's? That is what I have my warning light set for on my gauge. Should I change the bypass jet?
Thanks for all your responses
Does someone know what the convertion formula is for C to F? If it's what I think it is, he may actually be running lean. I may be wrong, depending on the convertion. Please make sure and gap ALL the plugs evenly please. As for leaning out (if needed), you are correct in stating that the bypass jet needs to be tweaked. Remember is bigger for leaner, smaller for richer. The adjustment on the FPSS was discussed in a good write up sometime back, try and see if the search takes you to it somewhere.
Originally posted by Y2KevSE
Hehehe... 50 shot? Wimp! p
Congrats dude! Now up it to 100!!! :naughty
I ran about the same pressure as you do when I had my 50-shot...and my plugs were PERFECT...I think that 62-63 for a 50-shot is a little high....who knows though.
you're in NC right? another sick boosted ride i need a ride in
Originally posted by Cumalot
Hey Matt, long time no talk. :
NOS huh? Thought you were a SHOW only car?
Especially slower than keving.
are you going to spray the happy gas at rockingham and what is your car running without the NOS in the 1/4
UPDATE
I checked my plugs after a Nitrous run and they are had a little bit of green tint showing on them. The green did not run all the way down the strap just near the tip. I did not see any specs or anything like that. Just a little bit of green and the rest was normal looking.
So does that mean I am running a bit lean or a bit rich? thanks
matt
matt
Re: UPDATE
matt
matt
Re: Re: UPDATE
Originally posted by BriGuyMax
you're running perfect...as long as the green/blue doesn't get all the way down to the threads...your fine...
trungg86
Sep 4, 2015 04:58 AM
jchronis2552
Aug 13, 2015 07:48 AM
