What will happen if I remove my MAF sensor from the mix?...
Old Jun 12, 2002 | 10:34 PM
02MaXiMa_GLE's Avatar
What would happen if I remove my MAF sensor & tape-out the sides so no dirt will enter it? Remove the MAF from the intake, tape it up & tie-wrap it nice & tight to the firewall or fender. But leave it plugged in. Yes, I know this sounds crazy!... but what would happen to the car's performance?
Thanks,
G
Old Jun 12, 2002 | 10:46 PM
max95q's Avatar
Re: What will happen if I remove my MAF sensor from the mix?...
Thanks,
G
Since it wouldnt read any current of air coming through to it your cars engine wouldnt run right. Thats what, so dont do it
Old Jun 12, 2002 | 11:32 PM
Does it read the air current?... or the air temperature?...
G
Old Jun 12, 2002 | 11:35 PM
buss95max's Avatar
ur car wouldnt go...it wouldnt even stay on...if you tried to go it would go into limp mode....
Old Jun 13, 2002 | 12:20 AM
Maxima_Van_WA's Avatar
IF it doesn't sense air going in, it won't know how much fuel to deliver to the injectors, thus no detonation, no turny the crany, etc
Old Jun 13, 2002 | 06:01 AM
dwapenyi's Avatar
The MAF reads the incoming air, and it tells the computer how much air is coming in, hence its name Mass Air Flow Sensor. Without it, your car will have absolutely no idea of how much air is coming in.
Don't mess with it.
DW
G
Old Jun 13, 2002 | 06:03 AM
deezo's Avatar
Don't mess with it.
Old Jun 13, 2002 | 06:46 AM
1MAX2NV's Avatar
you must be talking about the air temp sensor..
Old Jun 13, 2002 | 07:03 AM
Keven97SE
That's like saying, "If I remove the engine, would the car run?" No. The car would definitely NOT run right if you removed the MAF. It is the #1 sensor in the engine. The car would run in limp mode, very very rich and crappy power, and wouldn't rev past 2000 rpm.
Thanks,
G
The Frye
Sep 2, 2021 11:03 AM
ballerchris510
Sep 10, 2015 09:35 PM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
