HAD CAI installed today, engine light came on!!!!
my good friend at jersey city installed CAI for me today (same guy that held NE meet this past sunday) and my light came on...the car sounds so awesome and i feel the extra power especially in low end but i'm worried about this light...i see one connection on the right that is loose...don't know where it should be connected....what can i do to get this light out? what am i looking for?
Re: HAD CAI installed today, engine light came on!!!!
Make sure your MAF and air temp sensor are plugged in. Then just reset the ECU. Sometimes if you disconnect sensors while the battery is connected, you trip CEL.
URL still hasn't changed http://vbxmaxima.8m.com/ecu.html
Re: Re: HAD CAI installed today, engine light came on!!!!
on regular stock intake, two things are plugged in but we only found room for one plug in...
Re: Re: Re: HAD CAI installed today, engine light came on!!!!
Originally posted by meccanoble
there is only one thing plugged in on the right side of CAI
I couldn't fix your brakes, so I made your horn louder
Re: Re: Re: Re: HAD CAI installed today, engine light came on!!!!
I'm assuming that at the very least, the MAF is plugged in. I also hope your CAI is made for 95-96. On our cars, the CAI tube has a hole for the air temp sensor. Not sure where the 97-99's have their sensor at...
i'm going to look for the plug in, if i can't find it, i'm just going to reset ecu and see what happens....
Re: Re: Re: Re: Re: HAD CAI installed today, engine light came on!!!!
inside the PR CAI box is a sheet showing this intake works for 95-99...didnt' even know there was a difference between the 95-96 and 97-99
Re: Re: Re: Re: Re: Re: HAD CAI installed today, engine light came on!!!!
Originally posted by Yellowbrother
air temp sensor is on the bottom end of the "box" i think...lil bitty sensor...
so both snap on things should be plugged in ehhh? tomorrow morning i'll make a check (if i can wake up early ) but i seriously only remember seeing a hook up for one...car starts so the MAF sensor should be hooked up....u guys say the other one is at bottom of CAI?
My ECU cover is totally different...there are no screws holding mine, there are two plastic circles holding it and there is no imprint to screw...its like the whole thing can be pulled off or something but i'm not about to do that and break something unless yaw say its ok....why stuff gotta be so complicated for me? i have a 95...maybe mine is different....
MaximaDrvr
08-19-2015 08:20 PM
bassmann
08-03-2015 07:53 PM
