I want to order the Auto Meter Dual Guage pod from http://www.CustomMaxima.com and I want to put Voltmeter and fuel/air gauges in are they hard to do or which gauges are easiest to do I don't have boost or nitrous or anything. And where is the best place to get the gages from I want the ones with white faces
The volt meter and the clock are probably the easiest to install.
A/F ratio is not that hard either. Tranny temp is not hard either. Harder ones are like oil pressure, oil temp and EGT . Intake temp is easy to install but that gauge/sender is expensive.
thanks for the replies will the guages come w/instructions...on the volt meter I just need a + from the battery and a ground right?Originally posted by 1MAX2NV
Quote:
CLICK ME!Originally posted by metallic97gxe
you know what fellas Maxima.org members are the best!!!!!
no doubt.....
no doubt.....
no doubt.....
it took me an hour. to install the volt gauge and the air/fuel gauge.. an hour is all.Originally posted by metallic97gxe
no doubt.....
