Removing Washer Fluid Resevoir??
Old Jun 22, 2002 | 10:37 PM
thebigsadler's Avatar
Yes, I want to remove the washer fluid resevoir and all of the associated components.
Any tips or tricks I should look out for... obviously I will going through the inner fender and I will have to pull the squirters through.
Is there anyway to just move the filler part, that "neck" part that sticks up through the hole?? I might like to mount the squirters somewhere fun.. .. so if i could just move the "neck" of the washer fluid resevoir I would do that too..
thanks
jason
(and no it isnt for a charger, but something else)
Old Jun 22, 2002 | 11:18 PM
Jane97SE's Avatar
Used force to obtain Admin powers
You can just pull the neck off and you can ghetto rig a radiator hose to the windshield washer resevoir so you can still fill it up.
What is it for?
What is it for?
for... my secret... :hint: o2..
Old Jun 22, 2002 | 11:21 PM
Jane97SE's Avatar
Did you get a very expensive o2 sensor?
Old Jun 22, 2002 | 11:25 PM
what is with you hating IMs..
and yes.. it's a HUGE o2 sensor.
Old Jun 23, 2002 | 12:50 AM
chinaonnitrous1's Avatar
hmm...if you did what i did to my car in january...you wont have one...
Old Jun 23, 2002 | 08:34 AM
if it was an accident, i didn't do that..
also, jane, how did you mount your coolant on the other side of the engine bay near the battery, what secures it in place??
Old Jun 23, 2002 | 10:18 AM
Jane97SE's Avatar
The bracket came with the s/c kit.
Old Jun 23, 2002 | 11:20 AM
nvmymax2's Avatar
Jason if you are trying to mount your air compressor on that side of your engine bay, ....you know that it has already been done-huh huh!! Ok enought sarcasm, the neck does come off and you would still be able to use them if you wanted to, also I just removed my over flow resovior. You just have to remember to check your radiator fluid levels every now and then. Call me if you need help with this, I can show you some pics of mine!
Blake
Old Jun 23, 2002 | 06:04 PM
i called.. you were too cool to answer.. im trying to decifer what you said, you have no resevoir?
Old Jun 23, 2002 | 06:27 PM
gtr_rider's Avatar
192.168.1.1
look at the video
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
Need help
23
Oct 2, 2015 08:56 AM
jaydot901
Sep 29, 2015 01:18 PM
