what would happen if i removed some of my heat shields?
Old Jul 1, 2002 | 03:54 PM
Soon2BMaxed's Avatar
whenever i hit bumps my car rattles like no other so today i got under there and shook some stuff around and it seems like the heatshields are clanking together and clanking on the underbody. what would happen if i removed the heatshields past the cat (by the b-pipe) would it hurt anything? this rattling is so loud and it annoys the hell out of me.
Trevor
Old Jul 1, 2002 | 03:58 PM
Jime's Avatar
Took mine off a couple of months ago. Doesn't seem to do anything except make it quieter. I have checked after a hard run and temp above cat and pipe is lukewarm.
Old Jul 1, 2002 | 04:14 PM
sweet, thats what i wanted to hear. thanks!
Trevor
Old Jul 1, 2002 | 04:50 PM
Nealoc187's Avatar
SLOW
I've removed some of mine... no problems.
Old Jul 1, 2002 | 05:00 PM
Chunger's Avatar
My other car is a Hybrid
They bend easily... use a large screwdriver to 'reshape' them as needed.
Old Jul 1, 2002 | 05:29 PM
i tried that. car was quiet for awhile and then after a little driving they start clanking again.
Old Jul 1, 2002 | 08:41 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
be careful where you are taking the heat shields off... seems to be plastic type material last time i looked under there @ certain places...====> heat may not help there but im not sure.
Old Jul 1, 2002 | 09:04 PM
pocketrocket's Avatar
I agree with seximagtr
The heat shields are there to specifically restrict heat transfer to surrounding parts.
I deal with wiring harness routing and I know how beneficial the heat shields are. You'll be surprised how much lower the temps are thanks to the simple heat shield.
I'll also agree with Chunger, just bend them away from the point of contact that's causing the rattle.
Old Jul 1, 2002 | 09:15 PM
turbomax97's Avatar
i had a banging problem and it was bad enough to wear we just cut a 3 inch section out of the b pipe and welded it back. Cost me 20 bucks; I'd rather spend that then the cost to have wiring/ undercarriage repaired.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
carid
Sep 17, 2015 05:00 AM
DayHeyZeus
Sep 11, 2015 03:17 PM
