Vortech V1 SuperChargers and rebuild
Originally posted by BrianV
Hmm well, good luck, is mtrai going to test the guage or plug another guage into your system?
I'm going to post a new thread for automatic 4th gen SC maxima's and let's see what mods people have and what power they're making at 6pounds.
I can't think of many that will be making 230+ on 6psi with just intake and exhaust.
But my point is I should be making MORE than 6PSI, especially if Loren got 9 on a regular basis, with the exact same SC as he tells me.
IanS
Originally posted by mtrai760
Ian, I may not have a lot of time tomorrow, but I'll get the vacuum gauge to ya, gimme a call after 10am... I'll probably be in Bellevue around noon...
I'll give ya a call tomorrow.
IanS
my sig isnt my car. its phil96se's that he sold a couple weeks ago. becuz of his cams and internals his car idles at -18 on the boost guage
. when we were drivin around in it i just had to keep that has a memory for u wont be seein that very often.
Mtrai idles at -22.
Loren at -24.
Maybe it means nothing.....maybe it means something. I've asked this before, but does anyone know if -17 is normal? The nissan techs tell me it is, but now I'm starting to doubt them.
IanS
Originally posted by iansw
Strange. I idle at -17.
Mtrai idles at -22.
Loren at -24.
IanS
Mtrai idles at -22.
Loren at -24.
IanS
I didn't read back too many pages but let me throw in my 0.02
Keep your car the way it is until you're ready to convert to the V2 as others have suggested. Although you could redo the stock pulley/belt/plug the oil line/etc... why do it until you need too?
If you haven't already used a 2nd or 3rd boost gauge to check, you should.
BTW - the pulley size is printed on the edge of the pulley...
Ive got it!!!
Ian, we can pull your S/C, put it on my car, and see if it still only makes 6psi of boost, then you'll know if it's the S/C or not without spending any more money, I'm auto still, your auto, eh?
J/P
J/P
And if it only cost $300-$400 to fix the V1 and make it quieter, I'd rather have that, because V1's are supposedly more reliable, and I'd save $$$.
IanS
I highly doubt Vortech would taken a broken V1 in trade for a V2 at their $700 deal. I'd have to get the V1 fixed first.
IanS
IanS
OK, Cranman - let's compare to an Auto -
If I equal the hp of Jane97SE when she had no CatBack and the stock pulley, (Equal to me now without the MEVI on) and I have a 3.25" Pulley and only 6PSI of boost (on the Dyno in 3rd Gear, manually shifting), then something's wrong. You guys are making it too complicated.
Same hp, same boost, similar mods, much smaller pulley = problem.
Though I'm not 100% sure Jane did not have her CatBack yet. I'm 90% sure she didn't.
Although I agree with the CatBack idea, and that it will definately help, I know that's not my whole problem....ALthough a CatBack will be on order in a couple of months.
IanS
IanS
One more thing. Your car dyno'd lower than mine did NA. I had the Greddy and a Stillen intake which gave 159 fwhp. While you had the MEVI, intake, and y-pipe and that gave you 155 fwhp. Maybe your car isn't as strong out of the box. Tony(1Max2NV) had lower numbers than I did and he had a lot of mods (you can check out his dyno in the dyno forum).
Even so, my 155fwhp shouldn't make it so that I'm as far below everyone else with SC as I am. I'm missing up to 39hp, and at least 25, dpeending on how you calculate it. And of course, the 3PSI.
IanS
Originally posted by Turbo97GXE
if i remember correctly.. Jane's dyno numbers were not the average dyno numbers for a SC Auto Max.. her numbers were a tad bit higher.. i think its the special sauce kevin is putting in the gas tank at night
This has gotten too complicated.
I am going to compare to Loren's car because this is the exact same SC.
Loren got 290hp at the wheels. He has a stick and Catback. He was a little freakish, so let's say 280 for the sake of argument.
I get 231 at the wheels with the same mods without a Catback, and Auto.
Transmission and Catback does not affect PSI adversely. Loren got 9 PSI, I'm getting 6.
There is NO WAY being Auto and not having a Catback is giving me a loss off 49hp and 3PSI! (Saying Loren got 280, not 290hp, of course)
That, even being conservative with Loren's numbers, is a 21.21% loss below a stick with Catback. No way.
Also, Loren tells me he only gained +7hp with a CatBack system. He Dynoed at 283 without the CatBack.
And you guys only talk about hp, only one or two people have tried to give any explanation on the boost. -3PSI, even on the Dyno in 3rd gear, with a running start, is 1/3 less than what Loren got, and at least 2 less than others with the same Pulley and Tranny get.
While some of you have great theories, I still don't think anything that's been said explains away 3PSI and 49, up to 59, horses.
Loren agrees with me on this. He thinks I should be at 290 with the MEVi, and 255-260 without.
Anyway, I'm getting it rebuilt when I get the money. Why not? If there's nothing wrong with it, I may trade if for a V2 anyway.
IanS
IanS
Loren's dyno's are ridculous. No way a NA 4th gen with those mods makes 190.
Also I don't think 49 HP for catback and auto is too far off, it's probably like 35 or something. My car NA put fdown 180 with Stillen/CAI Hybrid, Ypipe, RT Cat, Greddy Exhaust, and that was like record breaking for a 97-99 at stillen. Wherever you all are getting your dyno's is freakish. Cheston has the same setup I have now with the 3.125 and he's making like 275. I saw a 95 with the same mods I have put down 255. I should get my friend Dennis to dyno his car, he has a SC on an auto with VB, Ypipe, Cat, greddy exhaust. I'd be surprised if he got over 230HP at stock pressure.
She also has waterinjection and stuff.
190 hp with MEVI? That's 5 speed 5th gen territory, which you are not. I got 181 with CAI, y-pipe, RT cat, and UDP, so it's more realistic to compare your car to my car.
By comparing your car to Loren's car, you're heading in the wrong direction. Not trying to be mean but be an individual, not a lemming.
Originally posted by Y2KevSE
Nope... 229 with 3.60" and GReddy cat-back ONLY.
I edited my original post.
IanS
Yeah Kev's right, don't compare your car to a 5seed.
180 is about right for a 5th gen auto with those mods.
Hoon put down 200 with intake, y, exhaust but he's a 5spd.
He did put down less torque then i did though 180 vs 185 from me.
Damn fat-fingers...I meant 290 at the wheel with the SC, I have no idea what he Dynoed NA.
IanS
IanS
I know you're not trying to be mean....never thought you were.
Any other reasons besides the VI I should compare to you and not Loren? No matter what, having a sitck doesn't give THAT much HP.
IanS
Also, why should I compare to you, Kev? I'm counting my nubmers without the MEVI activating.
IanS
IanS
Having a stick doesn't give THAT much hp? Let's see... I got 288 with my setup, jhans114 (5 speed 5th gen) got 322 with the same setup, and Daniel Chen got about 317 (5 speed 5th gen) with the same setup. So, if you had a 5 speed, you should be at where jhans114, Daniel, and MardiGrasMax are (317 with MEVI).
Without the MEVI at 10 psi, you should be in the 250-260 range (definitely less than what MardiGrasMax was getting). With MEVI, you should be around 270-280.
So I'm still missing 2-3PSI, and about 30hp. (I'm assuming 260 is about right for no MEVI, Auto, and 9PSI)
1PSI = How much HP, may be a good question. I should think a 3.25" Pulley should be giving me at least 8PSI.
IanS
face it. automagics are just weaker.
it could just be your tranny is so messed up that its not xfering the power like it should be. i know a few people with abused auto trannys that had mad bolt ons and didnt dyno high at all...
There is no true 1 psi = XX hp calculation because of marginal returns. The more boost you put in, the less power you will get per psi.
When doing the VB Mod, I made special attention to cleaning the magnets. The magnets has only a light dusting of metal shaving on them, and my tranny had never slipped.
After the VB Mod, my tranny feels especially strong. I've always been careful never to do any tranny drops, I change the fluid with Synthetic every 15k.
My tranny is as strong as an Ox.
I can't say why, but I have very good reasons now for thinking it's the SC causing the problem. The only thing that will tell for sure is for Vortech to take it apart and look.
If there is damage, I'll work it out with Loren. If not, then I'll just get it rebuilt anyway.
IanS
IanS
one note thought.. DMan did dyno high with his 2k Auto
jhans114 has a AE
jhans114 has a AE
That's why he has that extra 5 hp, right?
When he added the y-pipe, he got almost the same dyno result. I don't remember if he even went with a smaller pulley.
You got 267 WHP, that is surprisingly close to that 270 target, not to mention you have a V1 which tends to boost about 1PSI less.\
You should be around 250ish without MEVI. Well you're at 231, which is reasonable considering you have a V1 which makes that supposed 10PSI a lot closer to 8-9; not to mention your absent an exhaust and cat which has to be worth 10 WHP. Thus, take the 10 lost from the less boost and the 10 lost from the cat and exhaust and what are you left with? 230 WHP!!
We're not trying to be mean IAN, we're just trying to save you from getting a rebuild that will waste your money.
Finally, don't keep going back to this, "Then why am I only boosting 6PSI" You have given us no proof except for the possibility of a defective boost guage that you're actually making 6PSI.
I couldn't agree more then this.
Here's what I'll do:
I'll wait until I get the new boost gauge. It will only read 6PSI as well, I'm fairly confident.
If it does, this sucker's going in for a rebuild. I really would like to make it quieter anyway. I already sent Loren a mail asking him that if Vortech does find something wrong, he at least help pay for the rebuild.
If nothing's wrong, then I will pay for the entire thing.
IanS
I'll wait until my new boost guage arrives.
Who is this we're talking about and
DMan_2k or something like that? i can't remember.. he has a 2k Auto
what did he dyno before the SC..
I didn't know ppl put TC's on maxima's
ok now go find me the stock dyno...
wait he had a y pipe before the SC huh?
Stock dyno was around 250 hp I believe.
Originally posted by BlackCat
Huh? Now I have nothing to look forward to
IanS
