Fuel Pressure Gauge Installation
Old Jul 7, 2002 | 05:02 PM
The_Bomb's Avatar
I have a mechanical fuel pressure gauge and a high pressure isolator sitting in my trunk and I am waiting to install it. But the only problem is I don't seem to have some of the parts. I need to know what parts people used to tap into the fuel line and how they did it. I assume I need "T" fitting of some sort and connectors to hook the fuel lines to it. I need help fast..... Help.
Adam
Old Jul 7, 2002 | 05:46 PM
1MAX2NV's Avatar
Not many people are using the mechanical fuel pressure gauge, so you are on your own on this one.
Old Jul 7, 2002 | 09:05 PM
Ramius83
I would HIGHLY suggest using an electrical gauge, especially when it deals with fuel and it coming into the cabin......
Old Jul 8, 2002 | 08:03 AM
The_Bomb's Avatar
The high pressure isolator is used to keep fuel from coming into the cabin. It is what hooks up to the fuel line and then uses a fluid inside itself to relay the pressure. Does anyone know what parts or how to install this thing, I'm getting desperate.
Adam
Old Jul 8, 2002 | 08:11 AM
1MAX2NV's Avatar
All you need is a 1/8" NPT brass t-fitting and some brass barb fitting. You can get them from Home depot.
Adam
Old Jul 8, 2002 | 09:40 AM
The_Bomb's Avatar
Thanks, I'll run there today and check them out.
Adam
Cotozic
Jun 28, 2017 08:01 PM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
