Supercharge and Intercooler
What size should I look for, what's one that isn't going to be overkill, it's only an SC application.
Only knowledgeable posts only, thanks.
I want to do one single FMIC.
What do you guys think about Starion IC's for this sort of application?
when people do front mount intercoolers, i hear they have a drop of boost psi. i was just wondering, does having narrower pipes help keep the pressure up or am i completely on the wrong track. i rilly wanted to do this same setup next spring. sorry i answered with a question
What about an IC mounted in the battery slot and relocate the battery to the trunk? This will give you better weight distribution and it will also lose less boost since there is much less piping. I know someone on here has one mounted like that although I'm not sure who.
Re: Supercharge and Intercooler
First of all, I love your ride man. When I had my DSM I actually looked into getting a Starion FMIC. However, I was advised against it due to the fact that they are not very efficent. It might still work for a SC max depending on what PSI you plan on topping out at. If you are gonna go 10 or up, I wouldn't suggest the Starion. Check out http://www.roadraceengineering.com/intercoolers.htm for some options. There are a million others, just a place to get started.
with the IC you lose like at most 1 psi. but thats not really the point of why he (and i) are putting on the intercooler.. its more of the longevity of the motor that i am particularly concerned about. its hotter than hell here in the desert with 105+ outside temps, you must think that the compression of the air inside the car and under the hood must be much warmer.. so by adding the cooler, we lose some pressure. so what. but the engine is getting denser and (some-what) cooler air.
what should be more beneficial to a boosted max in hot temperatures is an oil cooler....
IC and oil cooler are both ideal. but if you cant afford the new piping.. oil cooler is the way to go....
brian. dont forget to run water wetter in your radiator.
the pressure loss shouldnt worry anyone, the power you lose from the pressure loss you will gain with the IC, i would recomment a sidemount(mazda or dsm) instead of a front mount, but if you do go with a front mount i wouldnt go with the starion there would be way too much piping cause of the way it is setup, use 2.25in from the vortech to the IC, and 2.5 from the IC to the TB.
i would recommend an intercooler setup like either of these. just my .02
http://www.roadraceengineering.com/p...0x10-39-15.jpg
http://www.roadraceengineering.com/p...c-sameside.jpg
-Dummy/Dumbkid
-Dummy/Dumbkid
This one looks nice.
Should I leave the end cap config like this, have both come from the top like the one on the right, or have them both run straight through the bottom like this:
http://www.roadraceengineering.com/p...-39-39-low.jpg
The piping will go straight down from the blower, across and then have make a couple bends to get back up into the engine bay.
To Anton, there's no point in trying to even out the weight distro in our cars. More weight in the back of the car slows us down more then in the front, not to mention puts less weight on the front tires which means less traction. If it was a RWD car I'd definately do it, but packing weight in my trunk is a no-no. Plus there's plenty of room for the piping to swing up in front of and to the left of the battery.
Finally, do you think 10x20 will fit (too big, possibly too small?)
Not too much, the pipe out of the blower isn't too bad.
You mayt have to shave the bumper a little bit, and the pipe going to the throttle body requires some bending.
Nothing too rough, $250-$500 for aluminum mandrel bent fabrication is my guess.
$250-$500...that's alot.
Originally posted by Y2KevSE
Ask max'n out about his boost lost with the IC.
We got a special guy from vortech to check it all out and pressure test everything.
But for the question, Size, well on here it seems to be debated to much, pipeing should be mandrel bent, i like the spearco intercoolers they claim and seem to be backed up as only .25 psi drop. Putting an air/air intercooler in the engine compartment is dumb, air/water intercooler would be awsome but would have to be custom built just like the air to air. With the air to air, you might want a new raditor why? cuz if you don't there is clearance problems for the piping back out of the intercooler.
Brian, why don't you email Nigel (turbo97se) or Turbymax (matthel) and see what size intercoolers they are using/where they got them from?
someone give me some sizes for an IC that'll fit without having to buy a new radiator, at this time I don't want to replace the radiator.
Originally posted by max'n out
Any air to air intercooler will need some cutting or a new rad...Reason is simple, the piping back in. There is a cross member that you can mount the intercooler that also has the rad on it...I think I said that right...But the bottom line is if you put it out front, you can either not change the rad (me) and run the pipe just a about a quarter of an inch under the car or start cuting and changing the rad.
So once again, how about sizes? 20"x10" ok, and what style connectors, both bottom straight connectors?
i would only go with one where both outlets exit to the left like the first picture. the second picture would require too much piping. 20x10 should fit, it might require some cuttin of the bumper support and maybe trimming behind the bumper cover but it should fit.
Dumbkid that doesn't make sense. The SC is on the left, the TB is on the right, it would require a lot more piping to do it with both exits on the same side.
I'm going to do it your way, I don't mind cutting/shaving the bumper a bit, but I'm not in the mood (or wanna spend the money) to replace/modify the radiator.
As for the guy with the temp drop q...I can't give you the numbers but I'll give you the hand
...Meaning b4 you'd burn your hand after about an hour by touching the pipe, now out of the intercooler anywhere b4 the tb, it's cool to the touch...Engine runs much much better overall.
Originally posted by Dummy
i was under the impression that you were going keep using the stock SC to TB piping, if you are not and are going to do all custom piping then yes it would require less piping to have an outlet/inlet on each side.
How would he run an intercooler if he was going to use stock piping???
23x8, yeah email me pics brian@brianv.net
Also, what brand IC and where did you get it, and for how much?
have piping fo from vortech straight down and over a lil to inlet of intercooler, and and have piping exit intercooler travel left and go strait up into stock sc to tb piping....simple.
That's way too much unnecessary piping, the goal is to install it with the minimal amount of pressure loss. Also, that would require the pipe coming down from the SC and the pipe coming up from the IC to be near each other. There would be some heat transfer from the real hot pipe to the not as hot pipe (equals - NO NO)
FMIC Pics
They're not that detailed, but if you go to my homepage, you 'll see how my FMIC set-up looks. I had to do it custom and we did have to cut 2 notches out of the metal bumper frame on either side so the piping would fit through... hope it helps.
Deac
Deac
i am aware of that, i thought you wanted to keep the stock piping... thats the only reason i suggested it.
yea... hi... how are you. I had an intercooler on the Maxima with the Vortech supercharger. I looked nice, but was way too small for the CFM I was pushing. I have since replaced it with a strait pipe and it works phonenomial. You have to realize, the supercharger doesn't really heat up the air to a level at which it's going to be detrimental to the engine. So all you really have to do is avoid getting the air any hotter. I didn't like how the stock kit (no offense to Stillen, becuase it's a perfect kit when no cutting is necessary) runs right over top of the exhaust manifold and right behind the radiator. That heats the pipe up to the point that I can't even touch it. So what'd I do? Rerouted the piping away from that. Now I have what you could call, a front mount bypass pipe. You can use an intercooler on it, but it's unnecessary. Boost drops a few PSI with my set up, you may want to think about doing a 3.33" pulley. If you DO get an intercooler, make sure you get the right size. A DSM 178 core is a good size one. But the set up I have right now with the piping that's just routed away from the engine bay, works GREAT. If I ever do put an intercooler back in there, it's for show. This is my experience with it, take it for what it's worth
t6378tp
Sep 29, 2018 04:27 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
