white build up around my battery terminals
Re: white build up around my battery terminals
Originally posted by vinny1978
should i be concerned?
Lick it!...
j/k..dont even...wear some GLOVES..and clean it off with baking soda...and COKE does work...so just use that..clean it up..and if you go to your local auto parts store you can buy the cloth rings that go under thoes...and the grease to prevent all this. That gunk is corrosive and bad for you!
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
Re: Re: white build up around my battery terminals
Originally posted by mb1
I believe Coke should do the trick. Also you can buy those little cloth things that slip on top of the terminal and prevent the corrosion.
COKE....never would have believed it if I didn't see it with my own eyes! it works!!!
![EEK!](https://maxima.org/forums/images/smilies/eek.gif)
You can also use a battery terminal cleaner (wires on the inside of this gadget) to remove tough stains/rust/corrision.
Another way to prevent corrosion is to add those red/black or green/red battery terminal rings. They're little foam pieces that cost about a buck at any parts store.
Re: Re: Re: white build up around my battery terminals
Dave
04-16-2020 05:15 AM
bigfrank
10-01-2015 12:51 PM
