2nd Group Deal (Japan) 50-50
Re: Re: Re: John you have mail
Originally posted by 96_vqmax
John i received my kit already,but still no sign of my VI,i though you said 3-6 day after your supplier receive it on the 7th,it's been 10 day seen you last post and i have not hear any thing from you,pls email me for any update plssss,
thanx!
thanx!
Hope you have a wonderful week,
John
Originally posted by Nismo
hey john, I couldt get a hold of you on AIM so I just want to know wahts the update on my VI? I believe my 2nd payment is due end of this month or early dec. Im the one from Merced, CA
-John
Re: Re: Re: Re: John you have mail
Originally posted by maximamoose
John, what is the status with the pre-assembled kits? Did Harlan get you our switches? Thanks!
Matt
Matt
-John
thanx!
thanx!
-John
Originally posted by Mr Cranman
You are correct the VI should be shipping out the 1st week of december sometime. So, the 2nd half is due at the end of this month or beginning of next month.
-John
-John
Whats the estimated date for my install kit arriving? would it come by the time the VI gets here? thanks
-John
John,did the kit come with the relay,do we really need it,cause mine did not come with the relay,why do we need the relay for?thanx!
Iilac
Originally posted by Iilac
Yeah, John, my kit didn't come with the relay either. Do we need it?
Iilac
Iilac
Kits
About the kits I didn't include relay because they were causing a lot of trouble with several people and every VI that I've installed I haven't used it and haven't had any problem Takes away the guess work on the the wiring and what is causing the problem...so I decided not to include it because it was causing more headaches and problems for most people.
Sorry about the late response my daughter has been in the Hospital for 3 days starting Tuesday and I didn't have any access to a computer until now.
-John
-John
Re: Kits
-John
-John
color wire on harlan switch
anyone know the polarity on the harlan switch?like red (+),small black inside the 3 wires in the rubber sleeve(?),green (input from tach)and the bigger black wire alone (is this the - output to the control solenoid)thanx!
Originally posted by Ramius83
Red wire is positive
Green wire is tach wire
Black wire inside harness is ground
Black wire outside of harness is switched ground for solenoid
thanx,do you hook your to the relay?
I don't have a VI, but I have the Harlan window switch, which is the same as the RPM switch just with another RPM point to turn "something" off. But I assume you hook it up to the relay.
Re: Re: Re: Kits
Yep got it and am sending you a response now. Hope your enjoying the VI
John
John
Matt
upper gasket
Hi john,i wonder if you have any upper gasket(14033-38U00) o ring(14515-40F00) in stock,or can you order 1 of each for me,next time when you order your VI from your supplier.I just want to have one spare just in case,do you thing that any nissan dealer can order them if they had the part #.Thanx!
Re: color wire on harlan switch
Red positibe
Small black Negative
Green RPM signal
And the bigger black wire goes to ground the Dawes Device
Re: Re: Re: Re: Kits
john, do you have any word on when my VI should arrive? just curious. I think I am going to make an appt with the speed shop to install it. Thanks
Matt
Matt
-John
Hey John, can you please let me know when My payment has been received? thanks
-John
Re: upper gasket
I hear you alway nice to have a replacement gaskets.-John
Re: Re: upper gasket
You can try to order it from a Nissan on dealer but every Nissan dealer I've gone to just say that it isn't in there system so they can't order it for me. I'm thinking of getting a cover..so when I do...I'll order those parts for you.
-John
Hasn't shipped yet...they should be shipping sometime this week. He was in a business trip in Toyko, so just got back and is getting everything together.
-John
-John
Matt
John, it's Matt again. I am just trying to see when I might expect the VI and kit? Thanks
Matt
Matt
Hope that helps and have a wonderful Christmas if you don't hear from me sooner,
John
Originally posted by 96SE5Spd
Has anybody heard anything, about their intake.
yes. John's supplier went on vacation. click on the previous page, and you'll see where he told me that. how long have you been waiting now
I knew that he had gone on a business trip, I e-mailed John and still haven't gotten a reply, usually he is quick to respond so I was just seeing if anybody had heard anything since the 18th. I sent the rest of my money in about a month ago.
