2nd Group Deal (Japan) 50-50
Re: VI Group Deal
Originally posted by AceFace
Hey Does anyone know if this deal is still on.
Have a great day,
John
Sent people emails on what was going on that have sent me stuff. Just wanted to let everybody know that I had contacted the GM guys and they said they didn't have them in stock when I had ordered the 9 I ordered on February 19th...ended up calling them and they said it shipped and should be here no later than the 11th of March...gave me a tracking number and it hit my city yesterday but didn't recieve it, so hopefully I'll have it Monday/Tuesday and get the orders out to you guys so you can install them next weekend. Sorry about wait guys and thanks for the patience.
Have a great weekend,
John
John
John
John
Got the parts yesterday
Just wanted to let you guys know I got it yesterday and am shipping today. Was going to look for the adpator at auto zone, checkers, or pep boys. If I can't find the adpator's I'll just include two wire butts that you can stick in it if I can't find the adaptor...just electrical tape up.
Because I don't want to keep you guys waiting.
Should have it Saturday, because it is 2-3 days.
-John
Because I don't want to keep you guys waiting.Should have it Saturday, because it is 2-3 days.
-John
Re: Got the parts yesterday
-John
-John
Re: Re: Got the parts yesterday
Originally posted by deezo
What part is everyone looking for John? Is it the connector for the GM Solenoid?
Yep, that is what we are looking for. Haven't found one successfully yet, and didn't know the part number from GM to order it, but putting in 2 wire butts sit pretty snug. but I would like to find the clip to clip in there, but places I've gone don't have them in stock
Hope that answers your questions
John
Originally posted by BBaker025
I installed mine and it works fine! The 2 wire butts hold it in very securly and its a good connection.
Shipped out the kits
So shipped out the kits. I'll try to get you a picture. But to give you an idea the vacuum switch has an adaptor that clips in kinda like how your spark plugs have the plastic thing that plugs into it, and to get to your spark plug you have to unplug the plastic thing that snaps in and then your able to pull it out (of course when you unscrew it) Anyway there is supposed to be a plasic clip to attach the vacuum switch to wires for the power and the switched ground from the RPM switch...but because I can't find a clip I just put 2 wire butts in one for the positive and one for negative and it fits perfectly. You'll understand when you see it.
I went ahead and already put them in so you know what I meant when you get the kit.
I'll get pictures as soon as I can hopefully that clearned it up and didn't make it any muddier (is that a word?)
-John
I went ahead and already put them in so you know what I meant when you get the kit.I'll get pictures as soon as I can hopefully that clearned it up and didn't make it any muddier (is that a word?)
-John
Originally posted by Chebosto
so you're still selling these eh? wow. that's great to hear Cranman!
what's your turn around time for everything (VI w/ installation kit) or are you not doing that any more?
I'm still doing it and even if I stop if someone was to PM me or email me I would still be willing to hook them up...so I guess basically to answer your question I'll be doing this until there is no one interested any more!!!
-John
correct VI?
A while ago I heard that there was another VI being sold that didn't work for our car, can anyone confirm this? If so what is the easiest way to tell the two apart from each other? My roomate said that he remember something about one having a circular intake runner and the other having an oval one...?
Yup its been 5 months since I've ordered my VI. Oh well, I'm just glad that everything is working out finally. Assuming I get my VI by monday or so, I'll try to see if I can get a dyno or at least some g-tech results by the end of next week.
Re: correct VI?
-John
I got my VI install kit. Now what's what? I know which is the RPM switch and which is the vaccum cylinder. Whats the rest of the stuff?
Here is a pic of the install kit
http://www.joemutt.com/zumble/VI/VI_install_kit.jpg
Vacuum tubing (determine were your going to place things in the engine compartment and cut vacuum tubing to lengths you need), Put the "T" in the fuel pressure vacuum tube then from the "T" put the vacuuming tubing to one side of the vacuum (bigger side) then the smaller side put vacuum tube from that to the side of the vacuum switch that doesn't have that sponge stuff on it...then from the sponge stuff take that off and put rest of the vacuum tube to the actuator on the VI. Hope that makes since.
If you still need help I can see if I can get a picture of everything put together,
John
And here is the link to the install again if needed http://www.vanillaice.com/webmasters/hype/mrc/mevi.htm
Thanks John! I'm not 100% sure. But I'm sure I'll get a better idea when I lay the stuff out around the car. I'm not doing the install myself anyway.
But I just want an idea incase the installer has any problems. Thanks again. =)
ZuM
But I just want an idea incase the installer has any problems. Thanks again. =)ZuM
Best way to do this...color coded the wires. So red goes to postitive on battery terminal...and positive on vacuum swith which is either side (doesn't really matter) of the vacuum switch goes to the positive on the battery terminal also. Black is negative wire for RPM switch...can ground it anywhere you want. The Green wire is the for the RPM signal from the rpm switch use the wire tap to tap into the coil. And the white wire goes from the RPM switch and to the other side of the vacuum switch to ground it to flip it over. That should take care of the wiring.
John
John
Originally posted by A-Ron Max
Just got mine today too. A picture of everything put together would be pretty helpful. Thanks!
Because a picture helps explain everything a lot better.
-John
Have mine most of the way installed, mechanic says that I need a 'check valve' to connect to the vacuum canister. Anyone else have this problem with the install? I figured that everything we needed was included with the installation kit.
Aaron,
96_vqmax is right. The canister john gave us is the NAPA one. The check valve is supposed to be built in.
-John
Originally posted by Krash513
Has anyone heard from John lately?
I havent seem him on or posting.......guess im getting anxious for my VI
Hope that helps and I'm guessing you sent me an email so I'll double check on that when I get the time,
John
received my kit but having trouble
I received my kit two days ago. Thanks John. However I am having trouble installing the VI. There is a tube that runs from my EVAP to the manifold but on the VI the fitting is the wrong size. Is this right? I have a 98. Also there was a vacuum hose leading to the intake manifold right after the TB and right on top but on the VI there is no fitting. Should I leave this vacuum tube disconnected? Your help is appreciated.
Re: received my kit but having trouble
Hope that helps,
John
Re: Re: received my kit but having trouble
You can leave that one vacuum tube disconnected. About the one being the wrong size I haven't really heard of that...but if the tube is too big just zip tie it down or just get an adaptor at like checker's auto, but I don't know exactly how it isn't fitting. If you could take a picture that would help...or maybe someone that has installed in on a 98 and up might be able to answer your question a little better.
Hope that helps,
John
Hope that helps,
John
Re: Re: Re: received my kit but having trouble
Originally posted by PIP
John, tried to reach you by email, about my MEVI. Did you see the gd on page 43 5speed swap, about the VI's? Would like to know whats going. Has anyone heard from John? Robert "PIP"
Guys, please be patient with the guys doing the MEVI GD's. It takes time for these things to hit the US. John is not a crook so just give him time. Everyone that has a VI had to wait 6 weeks or more to get them in hand.
Please be patient!
Please be patient!
Please be patient!
Please be patient!
no one has posted over a month already, so i figured i would.....and it looks like john hasn't been online for almost 2months...anyone know what the update is, i sent john an email 2weeks ago....usually he responds by a week, but so far nothing...and no one is posting so I'm wondering if everyone got there's or what's the deal, etc.
Thanks!
-Vlad
Thanks!
-Vlad
