4th gen - gauging interest +6hp/+9tq for $100
Old Dec 23, 2003 | 06:38 AM
BEJAY1's Avatar
Conecarver
Phenolic Intake Manifold and Throttle Body spacers (gaskets) made by Outlaw Engineering.
http://www.outlawengineering.com
No joke here. I'm trying to get 20+ 4th gen buyers lined up for OE to develop and test a set on the 95-99 Maxima. They said they've had dozens of requests for the SR20DE and nearly no interest in the VQ or VE engine.
They said they usually see slightly better gains on 6cyl vs 4cyl designs. For instance (according to their graphs and my research)
Acura/Honda 3.5L +4.5%hp / +4.3%tq
Mitsubishi 3.0L +1.7%hp / +3.5%tq
Ford/Mazda 2.5L +6.1%hp / + 8.8%tq
Taking an average should give us like +6fwhp / + 9fwtq. Even at half that gain I think it's worth $100 in parts.
Here's a set they did for the Honda/Acura folks
Please reply here if you're interested so I can start a count.
Thanks to Pat Rucker in the 3rd gen forums for some ideas. Sorry Don @ Mobiletek if I'm stealing your idea.
Old Dec 23, 2003 | 07:24 AM
MaxPerformanceSE's Avatar
How much $$ are we looking at?
edited: Sorry, I wasn't reading well enough the first time around.
Old Dec 23, 2003 | 08:31 AM
infinitiblast's Avatar
What purpose do these serve? What exactly makes them...make you gain power.
Edit- i looked on their site.........looks like a decent product. If you could get it under 100 bucks that would be better though if you ask me.
Old Dec 23, 2003 | 10:36 AM
BEJAY1's Avatar
Conecarver
The spacers reduce air intake temps and prevent heat soak from the engine up the intake path. Very similar to icing down the intake between drag runs.
The TB spacer helps reduce our 180deg. coolant from heating the intake system from the top down. This is similar to our TB coolant bypass mod except you can still run it in winter. I'm thinking you could do both of these together.
The same 3 examples above reduced temps by an average of 27deg-44degF. That's equal to 4hp-13.5hp depending on who's calculations you believe.
Old Dec 23, 2003 | 10:55 AM
MAXimumHP's Avatar
I'd consider getting a set of these.
Old Dec 23, 2003 | 11:04 AM
mzmtg's Avatar
Minister of Silly Walks
Me too.
Old Dec 23, 2003 | 11:21 AM
plurco's Avatar
Originally Posted by mzmtg
Me too.
seems like you and I have talked about this huh?
Old Dec 23, 2003 | 11:50 AM
Liquid_pjear's Avatar
I would definetly be in for at least one set. Maybe as many as three
Old Dec 23, 2003 | 11:52 AM
1MAX2NV's Avatar
Is it possible to slip these gaskets in without completely removing the upper intake manifold?
Old Dec 23, 2003 | 11:54 AM
MrEous's Avatar
^ Jeff™
...A friend and I were talking about this months ago. If what he and I are working on falls through then I may be in on this.
I used to be a part of the Ford 2.5 community...so I am familiar with Phenolic Intake Spacers. Gains have definitely been shown. Go to www.probetalk.com and do a search.
Old Dec 23, 2003 | 12:12 PM
Y2KSESteve's Avatar
I'd be in for a set.
Old Dec 23, 2003 | 12:43 PM
Kehops's Avatar
I'd buy one
Old Dec 23, 2003 | 12:52 PM
dmontzsta's Avatar
Ford Only.
I know these REALLY help the stang guys. I would be up for a set depending on the price, I was thinking about this along with Aaron92se a while ago for the VE, but the problem was our ignition coils in the back, if you raise the intake, then you have to get longer coils correct?
Old Dec 23, 2003 | 01:17 PM
Aaron92SE's Avatar
NWP Engineering.com
Or shave our coil packs so they don't sit higher. Most of these kits are going to raise the manifold by 1/4" to 3/8". Not THAT much, but still, you will have to shave the coil pack to make sure it makes a solid connection to the plug.
Old Dec 23, 2003 | 01:47 PM
athlon omega's Avatar
I'd be interested as well.
Old Dec 23, 2003 | 02:32 PM
Dave B's Avatar
Not DAVEB the parts guy
I'm interested too, but what about:
1) the EGR tube that's connected to the back of the intake manifold on the 4th gen. How do you overcome that problem?
2) the two rear support arms on the 4th gen intake manifold? I gues you don't have to use them, but why did Nissan put them on in the first place?
3) there may be a clearance issue with the MEVI equiped cars. The MEVI sits a lot higher than the USIM and the clearance is tight against the hood. Hell, the stock underhood cover on the US-Maxima is made to fit the MEVI (it's already cut out for it). Adding another 1/4"-3/8" in height may cause hitting on hard shifts and wheelhop.
4) there may be a rear coil pack issue.
Dave
Old Dec 23, 2003 | 03:15 PM
BEJAY1's Avatar
Conecarver
Dave
Good points Dave. My rubber manifold gasket looked to be about 3/16" thick so this would only move things 1/16" higher. I think the 3rd gen's have a slimmer gasket so they may have more to worry about. Maybe the MEVI folks will need poly engine mounts or raise/rake their hood slightly. I was looking that doing that anyway this spring to help underhood cooling.
Old Dec 23, 2003 | 05:14 PM
Aaron92SE's Avatar
NWP Engineering.com
The EGR tube will be somewhat of a problem. Pat (MadMax024) (VE 5spd) did this. He removed his rear manifold support plates and hasn't used them in years. As for the EGR tube, he had a little problem getting it to fit on, but he got it. I dunno how, since it's 1/4" higher. It's hard to attach when you are completely stock. But he said he did it.
Old Dec 23, 2003 | 06:53 PM
stephenlc's Avatar
I would be interested.
Old Dec 23, 2003 | 07:37 PM
ch13f's Avatar
Seems interesting, I'm just curious about the amount of time it would take for the installation. 100$ in parts sounds great but if you pair that with more than a couple hours of labor ... Assuming it isn't a bad install job, then I would most likely be in.
Old Dec 23, 2003 | 08:54 PM
brianw's Avatar
I'd be interested, pending addressing of fitment issues for the EGR, coil packs, etc.
Old Dec 24, 2003 | 06:29 AM
Maximum96's Avatar
Im definetly in, if the fitment with coils and egr is not a problem...
Old Dec 24, 2003 | 10:55 AM
I30tMikeD's Avatar
Fit fittment problems on the above items is solved I would buy in a heart beat. It's almost impossinle to find any more inexpensive NA mods that give results.
Old Dec 24, 2003 | 11:16 AM
RI-Max's Avatar
i'll be down if its a easy bolt on
Old Dec 24, 2003 | 04:03 PM
khott2003's Avatar
I'm in if all clearance issues work out (including MEVI possibilities).
Old Dec 24, 2003 | 04:29 PM
krismax's Avatar
Father of the 00 VI
me too
Old Dec 24, 2003 | 04:43 PM
vipervadim's Avatar
I like Maximas
I'd buy this in a heartbeat!
drifters in japan also use this type of gaskets to keep temps down while bouncing off the rev limiter in second, hehe
need to find out about those fitment issues..
thanks for possible new mod
-Vadim
Old Dec 24, 2003 | 05:26 PM
toofastmax97's Avatar
That's a great mod that's proven to make power, im definetly down.
Old Dec 24, 2003 | 07:52 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
I am down for a set if it fits without any fitment issues pertaining to the MEVI.
Old Dec 24, 2003 | 07:53 PM
RastaManMax's Avatar
If there are no fitment issues, I will be purchasing.
Old Dec 24, 2003 | 07:58 PM
kingrukus's Avatar
no more maxima...
Once again, if these fit with no issues, and are proven to make power, I will definitely be buying them.
Old Dec 24, 2003 | 09:03 PM
Jason R's Avatar
aka UNCDooD
yep, me too. even though I don't have an MEVI..
YET.
Old Dec 25, 2003 | 10:08 PM
Maxtank's Avatar
For those concerned with hood clearence, you can put washers in the mounts to sit the engine lower, it's something the honda guys do, not sure if it would work, but it's a thought.
i'll be in on this once I see VQ gains
Old Dec 25, 2003 | 10:50 PM
speedymax99's Avatar
well if it work , i want one
Old Dec 25, 2003 | 11:14 PM
EZEMaxima's Avatar
I want one if it would have no clearance problem with the MEVI installed. Does this kit even work with the MEVI (fit and function)?
My MEVI is on it's way........
Thanks Eric
Old Dec 26, 2003 | 04:30 AM
LiquidNine's Avatar
I'd be interested. Plus, it would give me more incentive to pull my intake manifold for a good cleaning.
-Aaron
Old Dec 26, 2003 | 07:58 AM
krismax's Avatar
Father of the 00 VI
Id just want one for the intake manifold ,because i have the pathfinder TB and the gasket woudnt work on it and it wouldnt be needed anyways because there is no coolant going thru the TB.
Remember one thing the hondas with vetec do not have a EGR systemso the egr tubes may be a problem on our cars but sombody is going to have to find out.
Old Dec 26, 2003 | 11:30 AM
kenji's Avatar
uh... what everyone else said
Old Dec 26, 2003 | 05:39 PM
bluA32's Avatar
あおい A32
me too..
Old Dec 26, 2003 | 08:34 PM
Lo-Tse's Avatar
These parts are not that expensive and if they can really produce the gain that's you proposed it is a solid deal.
Pardon my ignorance, how can these spacers lower the intake temperature - they are really thin?!?
Lo-TSe
