4th Gen carbon fiber hoods $400. shipped!!! $310. for locals. Need 20 people.
Old May 2, 2004 | 07:25 PM
  #241
Ant96GLE's Avatar
Originally Posted by Maximum96
Just installed my hood, fitment is 99% perfect.I did not have to shave the latch any but i did have to cut about a centimeter on the underside of the hood where the latch is. Also you will have to cut for the winshield nozzles. Excellent quality. Hey MAX420, did u make a rectangle hole to put the windshield nozzles in??how??
Edit: Also, if u want to use the heat absorber thing (underneath the hood), u will have to drill the holes.
I installed mine yesterday. The fitment was perfect other than the latch... which was no problem other than shaving down the guides for it.. it only needed about 1/4" to be cut off. For the windshield nozzles, I used a large drill bit and then with a file, I shaved it down to the shape needed.
Old May 3, 2004 | 06:06 AM
  #242
Angelr34's Avatar
Originally Posted by MAX420
Sorry for all the posts, took some pics..... the last pic on the page shows the part of the latch that needs to be trimmed.
www.cardomain.com/id/ymeofcr
Hmmm can some take a picture of the part you have to shave on the latch i couldnt tell what part it was in your pic max420
Old May 3, 2004 | 02:12 PM
  #243
Taken2DaMax's Avatar
Go outside to your car and look at the latch. It's the bent lip portion on the latch.
Old May 4, 2004 | 06:34 AM
  #244
1MAX2NV's Avatar
What's the guide that you shaved down? Is it on the hood part? or is it at the latching assembly? Is it the same part Maximum96 shaved? Someone please take a picture
Old May 4, 2004 | 07:07 AM
  #245
MAX420's Avatar
Hey, 1MAX2NV, go back to my link .... i circled the part that needs to be shaved down. More clear now, hope that helps.
Old May 4, 2004 | 11:43 AM
  #246
Maximum96's Avatar
check out my www! i just put pics up on page 2, i show where i shaved by the hood latch,
Question: The skeleton is not glued onto the Hood, at high speeds it shakes alot, i think it should be gleus onto the hood like the factory hood, because the CF if very flexible, i also have the pic of the skeleton.
Old May 4, 2004 | 11:47 AM
  #247
1MAX2NV's Avatar
Are you talking about the silver part? Where is bolted to the CF hood?
Old May 4, 2004 | 11:48 AM
  #248
1MAX2NV's Avatar
I think other people shaved a different part?
Old May 4, 2004 | 12:13 PM
  #249
Maximum96's Avatar
Yes, u can tell where i shaved it on the pic cause it would not open...i did not shave the other part on the car like the others did, but i can see y u would do that cause the hood will not close, i just banged it in very little, i might shave it later to be on the safe side
Old May 4, 2004 | 12:19 PM
  #250
Ant96GLE's Avatar
The problem is the latch that actually locks down on the hood itself, isnt long enough. Whats happening is the guides on the latch part on the car, is hitting on the top part of the latch on the hood... if that makes any sense. What you need to do is shave off about 1/4 of an inch off the latch on the car. It looks like a small flap on the very tip of it.
Close your hood and watch it as it comes down. The small flaps are hitting the top of the latch on the hood.
Old May 4, 2004 | 01:35 PM
  #251
chicago max98's Avatar
got mine yesterday
Old May 4, 2004 | 02:13 PM
  #252
Flava_24/7's Avatar
Boosted Panda
Make sure you guys use hood pins.
I know their ugly but they are needed.
Whats this hood weigh?
Old May 6, 2004 | 12:35 PM
  #253
Got the hood today and installing it. Just a question for the people that have the cf hood installed already or people that recieved them, is it necessary to have the insulation cover on the bottom of the hood?
Old May 6, 2004 | 08:30 PM
  #254
Angelr34's Avatar
my hoods expected arrival date : today
what happened today : nothing
i think ima cry
Old May 7, 2004 | 06:11 AM
  #255
Maximum96's Avatar
i did not put the insulater yet but i am planning to real soon, u will have to drill tiny holes though...i dont want to take a chance with the heat messing up my Beautyfull hood.
Old May 7, 2004 | 07:47 AM
  #256
1MAX2NV's Avatar
ARRGGGHHHH!!! DHL lost my hood. It's suppose to be here on 04/30/2004.
Old May 7, 2004 | 05:13 PM
  #257
Angelr34's Avatar
ooooo nooooo mine is 2 days late
ima start praying now
Old May 8, 2004 | 10:01 AM
  #258
EZEMaxima's Avatar
No need to shave anything on your latch, you just need to readjust your factory latch upwards so the hood will close properly. That was always the case with most of the CF hoods that me and my friends has installed lately.
Old May 8, 2004 | 01:34 PM
  #259
Crap i'm in trouble. I ended up getting impatient with the latch. So i cut the grille to make it fit. I should of done this instead. But that's not my biggest problem.
Do any of you have any fittment problems getting all four screws into the hood? If so, how did you solve it?
Old May 8, 2004 | 04:24 PM
  #260
Maximum96's Avatar
yes it was a tight fit for all four screws but it can be done, try putting one side then another dont screw it all the way in till u have all 4 screws in the hood, do it slowly, u dont want 2 strip anything
EDIT: if u have help it is 10x easier
Old May 8, 2004 | 09:44 PM
  #261
EZEMaxima's Avatar
If you haven't fitted the hood on your car, you should prethread the bolts to hood while its off. Most of the time, this will clean out dirt stuck in the threads of the nut within the hood during manufacturing. Then go ahead and install the hood with a help from a friend or maybe your g/f or wife.....
Old May 10, 2004 | 09:09 PM
  #262
Angelr34's Avatar
mine is 4 days late still waiting and praying
Old May 12, 2004 | 03:33 PM
  #263
Angelr34's Avatar
now 7 days late
maxmojo wheres my hood
Old May 12, 2004 | 04:07 PM
  #264
MaxMoJo's Avatar
Former Sponsor
Originally Posted by Angelr34
now 7 days late
I contacted DHL, one of their "tracking specialists" will contact me by 5pm tomorrow to let me know what's going on.
Old May 12, 2004 | 07:00 PM
  #265
1MAX2NV's Avatar
WHY ME??? ARRRGGHHHH....Tonight I opened up the package and I was ready to install this bad boy with the help of Jason (Cutlr7). One corner of the hood was bent. It looks like someone dropped it. Anyway, I emailed Harry and hopefully I can get this resolved ASAP. Now my stock hood is off and I need to get the car ready for SEMA IAS by next week.
Old May 15, 2004 | 08:31 AM
  #266
Angelr34's Avatar
hey maxmojo you talk to this dumbass shipping company bout our hoods ?
i think mine just dissapeared into the twilight zone
Old Jun 2, 2004 | 06:48 AM
  #267
1MAX2NV's Avatar
My replacement hood arrived and it's perfect. I want to thank Maxmojo (Harry) for great customer service. He returned my email the same day and promptly resolved the situation within two days.
Old Jun 2, 2004 | 09:42 AM
  #268
MaxMoJo's Avatar
Former Sponsor
Thank you. I am very happy that it worked out for you. Unfortunately it did not work out so well for Angelr34. But on the plus side, he will make some money out of it as the hood was insured for more than he paid for it. I am trying to figure out what is going to happen to your damaged hood. If you don't mind, please hold onto it for the time being.
Old Jun 2, 2004 | 01:58 PM
  #269
98fiveSpeed's Avatar
is it too late to get in on this?
...Sorry.. didnt read all of the 9 pages
Old Jul 29, 2009 | 11:44 PM
  #270
CowTownCriminal's Avatar
im on that instantly if you got spots.
Old Jul 30, 2009 | 04:41 AM
  #271
Flava_24/7's Avatar
Boosted Panda
You need to learn to read, this thread is 5 years old.
Do you really think this deal is still going on?
Old Aug 1, 2009 | 09:48 PM
  #272
chrome91's Avatar
lol fail
Old Aug 2, 2009 | 01:19 AM
  #273
Leo_Koneval's Avatar
Only 5 years?
The real question my friend is.......... why not????????????????????????? haha
Just kidding just kidding I love your car by the way! Flava you are THE man.
95Maxi
Aug 25, 2015 08:01 PM
Team STILLEN
Aug 10, 2015 04:29 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
