Intro pricing/GD on Lower Tie Bars for 89-03
Old Jun 19, 2004 | 10:44 PM
  #161
volkl77's Avatar
Well... One day later and this lil gem makes a significant difference in the way the front end feels and performs. Tighter, stiffer , quicker steering response. All positive.
Matt did the install Friday afternoon. The bar fit just the way it should. The job took about 40 minutes with pauses for pictures.
The left control arm had to come off because of the Auto transmission, but I had figured that would be the case before the install. There is just no way to get a socket and torque wrench/breaker bar/ratchet on that one bolt without dropping the arm. I knew this having done the Energy bushings a couple of weeks ago. No surprises there.
Thanks again Matt... Great work!
Cheers!
Old Jun 20, 2004 | 06:50 AM
  #162
Matt93SE's Avatar
STFU n00b!
HNDA ETR, I'm not sure on the cattman headers on the 5 gen. I sent a 4th gen bar to a guy and it was close but didn't fit. the 5th gens have the cat under the engine right where the bar goes, so there's tons of room down there, but I can't make any promises on fittment. If you'd like to try one out, I can send it to you and give you a full refund minus shipping if it doens't fit..
David, were the instructions I sent you sufficient? Let me know and I'll post them here.
Old Jun 20, 2004 | 07:03 AM
  #163
volkl77's Avatar
Matt...
Check your email!
And the short answer is Yes.
Old Jun 20, 2004 | 07:11 PM
  #164
Matt93SE's Avatar
STFU n00b!
Okay.. well here's the install instructions, with pics..
It's really not difficult at all- just a pain if you've got an auto. but once you have it on, you'll be glad you did.
http://www.mattblehm.com/ltb_install.html
Old Jun 20, 2004 | 08:57 PM
  #165
VQuick's Avatar
Chassis Freak
Originally Posted by Matt93SE
pics here:
http://www.mattblehm.com/HSS_images/...r/4th_gen_LTB/
I'll do some install instructions tomorrow or something.
MAN look at that underbody in those pictures—NO RUST. I envy you Texas guys and your immaculate underbodies. Then again, my VQ and I breathe air much cleaner than Houston's smog so I guess I can't complain.
Matt, the write-up looks good. Cool cool.
PS, what's the deal with the bracket/cupped washers? Is it really completely unnecessary, or does the LTB render it unnecessary? Why did Nissan put it there?
Old Jun 21, 2004 | 04:44 AM
  #166
Matt93SE's Avatar
STFU n00b!
The only thing that I can tell of that washer is that it's used more for "containment" than as a regular washer.
There's a rubber bushing behind there that bolts the front subframe to the rest of the car's unibody. In the case that bushing fails, that cupped washer will make sure the subframe doesn't fall off and go skidding down the street when you hit a major bump. my Lower tie bar will also do the same thing, as there are two bars welded off that corner- so if the subframe bushings fail, it will be held onto the car by the tie bar itself.
Old Jun 22, 2004 | 03:03 PM
  #167
SupaMaxima's Avatar
Energy Suspension Bushings
Matt,
So is there a lower control arm bushing for the 2002 max manufactured by energy suspension, or is it the same as the 4th gen?
Old Jun 22, 2004 | 09:44 PM
  #168
Matt93SE's Avatar
STFU n00b!
I'm guessing the front bushing is the same on the 5th as it is on the 4th... they also use that bushing on the Altima, 2nd Gen Max, 3rd gen Max, and Stanza.
Old Jun 23, 2004 | 09:03 AM
  #169
MaXaZoR's Avatar
So this mod will not work with Cattman Headers for a 4 gen maxima
Old Jun 23, 2004 | 09:40 AM
  #170
Brad92SE's Avatar
Got mine today. I have yet to put it on, but it looks great! Thanks Matt!
Old Jun 23, 2004 | 10:03 AM
  #171
Matt93SE's Avatar
STFU n00b!
Not in current form. I'm working with a guy to help me modify the design so that it will fit.
Old Jun 23, 2004 | 03:23 PM
  #172
doublea's Avatar
Got my SS Lower Tie Bar this morning, as usual I cant wait to install so it will go in first thing in the morning.
Thanks Matt
AA
Old Jun 23, 2004 | 09:34 PM
  #173
TEEdotMAX's Avatar
Hey Matt thanks for the bar... I just got mine this morning & can't wait to bolt it up!!! so what's the deal w/ the bushings... which ones exactly do i need?? i saw www.courtesyparts.com selling the energy bushings, but they're for 4th gens. can somebody confirm if the 4th gen & 5th gen bushings are the same?
Old Jun 24, 2004 | 06:56 AM
  #174
doublea's Avatar
Hey Matt, you suggest that the autotragic owner should upgrade the bushing, where can we get those bushing, I'll be waiting for the install until I have the bushing.
Thanks for helping.
Cheers
Old Jun 24, 2004 | 06:57 AM
  #175
Matt93SE's Avatar
STFU n00b!
It *should* be the 4th gen control arm bushing set. As I said, I'm pretty sure they're the same bushing up front, but I haven't done an install on them yet to confirm that. I'll need to pull a control arm off a 5th gen and do the swap myself before I can say that for 100% fact.
Old Jun 24, 2004 | 12:38 PM
  #176
doublea's Avatar
Hey Matt, I just order a 4th gen control arm bushing set from Courtesy we will know soon enough if they fit the 5th gen, I should get the bushing in a week or so.
Thanks for the infos
AA
Old Jun 24, 2004 | 03:32 PM
  #177
irish44j's Avatar
retired moderator
but we are ok with OEM bushings, for those of us with 5-speeds? I want to put the bar on Saturday, but only if it's ok to use the current bushings
Old Jun 24, 2004 | 09:00 PM
  #178
Matt93SE's Avatar
STFU n00b!
Sure, you'll be fine with the OE bushings on there.
Just be sure to have the car resting on the ground before you torque the front nuts down, as otherwise you'll preload the rubber bushings and when you drop the car, you'll end up tearing them in short time...
so just be sure to leave them loose until you drop the car to the ground.
(and yes, this is mentioned in the service manual, only in fewer words.)
Old Jun 25, 2004 | 10:12 PM
  #179
E55AMG2's Avatar
Wat
Matt, sent payment.
Old Jun 26, 2004 | 10:29 PM
  #180
SupaMaxima's Avatar
Matt,
I really screwed up on the LTB install for the 5th generation max on my friends car. He said he was going to sue me if I didn't fix it. Well, j/k he didn't say that but I'm sure it he's going to chew my head off. He's a set of problems I ran into.
1) First of all I messed up the threading for one of the rear bolts for the control arm. This bolt is one of two that holds the rear part of the control arm for the 5th gen. The thread is so ****ED up that bolt doesn't completely go in. There's about .75 inches of the bolt still sticking out. How can I repair it? Can I use a dremel to clear out the thread and then use a thread repair kit? There's a picture below.
2) The bar touches the heat shield of the y-pipe. Can I safely bend the heat shield?
3) Also, I noticed that the car vibrates when I come to a complete stop. Is this due to the fact that the bar touches the y-pipe?
4) It is impossible to tighten the 27mm nut on the automatic after lowering the car. I am going to get the poly bushings. But in the mean time, there's a rubbing noise when coming to a stop and accerating. Could this be because I torqued the 27mm nut before lowering the car?
Thanks Matt. This is probably the worst case LTB install ever.
Old Jun 26, 2004 | 11:00 PM
  #181
SupaMaxima's Avatar
Originally Posted by SupaMaxima
Matt,
Here's the picture:
http://www.cardomain.com/memberpage/634178
Old Jun 27, 2004 | 05:56 AM
  #182
Matt93SE's Avatar
STFU n00b!
the thread is a 14x1.5mm I believe.. Ithose bolts are easy to strip for some reason- I've done about five of them over all of my installs. pull the old bolt out and replace it. then use a tap and cut the threads through the hole again. when you put the new bolt in, but a dab of anti-sieze on it. should get you fixed up.
I'd say 99% of the noises you're having is from the y pipe rubbing the heat shield. when I installed this thing on a 2k1 and a 2k3, there was at least 1/4" of clearance on the heat shield.. I would take a look at your engine mounts and see what condition they're in.
The noises I've heard form the 27mm nuts not being tight are usually creaking noises when you stop and accelerate.
Old Jun 28, 2004 | 10:23 PM
  #183
volkl77's Avatar
Hiya Matt...
Stage II bar is still working like a charm here. Added the Cattman/Progress bar last week. Dang thing is on rails now! Even with the oem struts/springs
Illumina kit arrived. Finally. Will install when I can... next week maybe.
WSP Stage 1 & 2 SFC's next??? Or would you like to hook up and re-invent the wheel? I have a few ideas, even one for a rear tie bar system that just might work....
Know much/tried out the Vogtland springs?
Cheers!
Old Jun 29, 2004 | 01:42 PM
  #184
Matt93SE's Avatar
STFU n00b!
Well, I'm kinda under a "non-compete agreement" with warpspeed on the subframes.. Since I helped them prototype their stage I and II subframes on my car, we are under the agreement that I don't try to copy their designs or whatever... We each sell products that are different enough and we can both make a few bucks, so I'm not too interested in trying to compete with them..
As for the other stuff, run the ideas by me via email, or let me know when you can stop by and we'll crawl under the car again and play around.
Vogtland springs? I know knothing. :shrug:
Old Jun 29, 2004 | 06:31 PM
  #185
VQuick's Avatar
Chassis Freak
OK, today I loosened and re-tightened the rear (control arm, 22mm) bolts. When I finally got the bar on after the fitment issues, I tightened the right side rear bolt all the way with the car jacked up. Matt, you said this would destroy the bushing in no time flat.
So today I loosened that bolt (with the car on the ground) and it didn't seem that tight. I retightened it, about "hand tight" with a 1/2" drive socket (about 10" long). I don't have a 1/2" drive torque wrench, but about how tight should these bolts be? I was surprised when I loosened the right bolt with a breaker bar because it wasn't especially tight. Any guidelines? Thanks.
Old Jun 29, 2004 | 08:14 PM
  #186
volkl77's Avatar
Hey Masaccio!
Dont sweat it on the rear control arm bushing. Its basically a big lump of rubber held in a "pocket" by the triangular plate with the three bolts. The end of the control arm rotates freely in that bushing. You won't hurt that bushing no matter when you tighten it up, so long as you get it properly positioned before tightening. Its pretty hard to screw that one up...
The FRONT on the other hand ...If you are running OEM bushings you need to tighten the front two 27mm bolts with the car on the ground and level. Roll it back and forth a bit to settle it before torquing it down. If you had an auto it would complicate things a bit because of clearance issues... not something you 5sp guys have to deal with. You need to do it this way with an OEM bushing because the nut locks the bushing inner shaft against the "gusset". Once tight it will not freely rotate. If not positioned correctly the bushing will be pre-loaded and tear itself up when the suspension moves.
All the big 22mm and 27mm front bolts are torqued to between approx. 85-105 ftlbs. Think a 1/4 turn tighter than a wheel lug nut. That should get you in the ballpark.
Pm me if you need any help...
Cheers!
Old Jun 30, 2004 | 08:26 AM
  #187
VQuick's Avatar
Chassis Freak
Doh! I got them confused. Jeez, I'm coming off like a complete doofus on this thread. Today I'll do the same thing for the front bolts. Thanks for the info, volkl.
Old Jun 30, 2004 | 01:01 PM
  #188
Matt93SE's Avatar
STFU n00b!
Yeah, what Volkl77 said.
All the torque specs and stuff are listed on the instruction page for the lower tie bar:
Old Jun 30, 2004 | 07:43 PM
  #189
volkl77's Avatar
Yeah, what Matt said! Thought you were busy workin Matt.. Figured I take one for you.
Cheers!
Old Jun 30, 2004 | 07:46 PM
  #190
Matt93SE's Avatar
STFU n00b!
I'm sure you've seen the weather lately.. I'm welding between downpours..
should be finished with the next batch tomorrow, if I can stay dry for about 6 hours.
Old Jun 30, 2004 | 08:34 PM
  #191
98I30t's Avatar
I did a couple searches, and I couldn't locate a online store that sold the energy suspension bushings for the maxima, if someone could enlighten me.
And I wanted to say that, although I don't have Matt's bar on yet, it looks superb, glad a couple people out there are trying to keep the cool parts for us coming. Still waiting to install the lower bar, and tein basic coil-over, works wearing the **** outta me
Old Jun 30, 2004 | 08:47 PM
  #192
volkl77's Avatar
Go here
Click the 95-99 Maxima link on the left. At the top of the page you will see the Energy link.
Cheers!
Old Jul 1, 2004 | 03:24 PM
  #193
98I30t's Avatar
Much oblidged good sir, much oblidged
Old Jul 2, 2004 | 08:26 AM
  #194
Matt93SE's Avatar
STFU n00b!
I have two sets in the garage...
Last time I talked to Courtesy, they had about 40 sets in stock.. I'm sure it's quite a bit less than that now, since I've ordered four and I know I've sent at least half a dozen more people to them in the last two weeks...
(maybe I should be on commission at Courtesy? )
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
