GD: $90 Shipped Motostorm UDP Pulley Paypal Preferred
Old Mar 3, 2005 | 07:51 AM
  #361
maxspeed96CT's Avatar
The original VQ...
Im still in, as long as this happens soon, cause im gona blow my money ..
Old Mar 4, 2005 | 05:41 AM
  #362
abci30's Avatar
oh noes!!!!1111
i'm going to have to pull out for now since i don't have the car anymore.
Old Mar 4, 2005 | 07:13 AM
  #363
GodFather's Avatar
Made in Taiwan
Originally Posted by KaZ
Not to say you're completely wrong with that statement, but I'd read this White Paper by Dinan (BMW Performance Tuner) about "Power Pullies" (i.e. underdrives). Now this is in relation to an Inline6, and we have a V, which tends to be better balanced, but you still run risks similar to this article with Underdrive Pullies as they have "normally" removed the rubber isolation ring from the pulley which acts as a Harmonic Dampener. I'm not trying to say they're bad, I'm buying one myself, and I have one on my 2002 Dodge Ram, and had on on my '91 Twin Turbo 300ZX... but just wanted you to know the facts before making statements like the one you made above...
Underdrive Pulley "Free" power that is lost due to ROTATIONAL MASS. They work the same way as a a lightented flywheel... they don't MAKE power, they free it... BUT, what an underdrive pulley does that a lightened flywheel does not is remove some harmonic balancing from the rotational assembly (pulley, crank, pistons, rods, flywheel, clutch & pressure plate).
Dinan "Power Pulley" White Paper
that harmonic balacing from the pulleys gets removed for a fact. that's totally true on most american vehicles. luckily, our vq's harmonic balacing damper is not removed along with the pulley. our engine was said to be internally balanced. this design eases up the trouble we might encounter when replacing pulleys. of course this isn't the main reason nissan did that. nissan proves its japanese automotive technology advances once again by eliminating the harmonic balancer dampers. come on man, some gm engines are still using push-rods today. the heck with that, these japanese guys are superior in the automotive technology, and we can't top that for a fact.
so mad-max is totally correct if harmonic dampers is your only issue to prove him wrong.
Old Mar 4, 2005 | 07:43 AM
  #364
KaZ's Avatar
KaZ
Well there is a rubber ring in our Crank Pulley... I know this for a fact because mine seperated a short while ago and I had to replace it (thankfully I was able to find a used stock one, as I didn't want to drop the $200 for an Unorthodox Pulley). So there IS a harmonic dampener designed into the pulley... but I agree, the engine is fairly well internally balanced, especially being a V engine... but there is still some dampening done by the stock pulley... I just wanted to make individuals aware, that there "IS" a remote chance for increased engine wear when running an underdrive pulley... but on a V engine it is much less of a risk than an inline engine...
Old Mar 4, 2005 | 07:58 AM
  #365
GodFather's Avatar
Made in Taiwan
dude, that rubber is a seal. this harmonic discussion had been brought up long ago in many other threads. other guys talked enough about this issue. our harmonic damper isn't needed because of internal balancing. nissan makes these cars for easy modifications. guys with vq engines only encounter a oil leak problem. if your harmonic theory holds true for our car, then after the pulley installation, the engine will vibrate and worse, even wobble. but no one had reported such problems. i saw it on video about the dampers in a chevy engine rebuild. they also did the udp, and having to put on the new dampers. well, we don't have that to worry about.
anyways, don't miss out on this good deal.
Old Mar 4, 2005 | 08:07 AM
  #366
KaZ's Avatar
KaZ
DUDE, no take a LOOK at your pulley... I'm not talking about the rubber BEHIND it... there are TWO metal discs that are BOUND together by a rubber RING, i.e. a harmonic BALANCER. Please go look at what you're talking about before you start preaching...
When mine fell apart, as they can, the alternator/ac compressor belt ring/disc came OFF the rest of the crank pulley... the inner section, and the power steering ring/disc were still bolted to the block... the rubber between them deteriorated and allowed the rings/discs to seperate. THIS is a HARMONIC BALANCER. I'm not talking about a simple rubber oil seal that is contain "behind" the crank pulley on the crank shaft...
And I'm still buying one, I simply wanted to let people know the facts... that yes, there is a harmonic balancer contained in the stock pulley, and yes there is a SMALL risk in changing to a none harmonicly balanced underdrive pulley, but its not that big a deal... but it still exists...
I've got the two rings/discs sitting at home... you want a photo for proof? Just take a look at any Maxima with some mileage on it... if you look at the crank pulley, inside the outer ring between it and the center of the pulley, you'll see an area with some stress deterioration... looks like any other piece of rubber that has aged (ball joint, steering rack boot, etc) and it will have stress cracks in the rubber... that area of rubber is the Harmonic Balancer. It looks a little different on all cars, but it normally exists in some shape or form on EVERY engine currently in production... Nissan 300ZX VG30DE(TT) engines have them, Dodge V8s have them, pretty much every engine has one... they just look a little different. Some manufacturers take more care in balancing their engines than others (hence your Chevy example), but even Nissan puts a balancer on its engines...
Old Mar 4, 2005 | 08:09 AM
  #367
illmortal's Avatar
Well if no one can prove that this UDP can actually cause more engine wear/tear then I'm getting it still...
Old Mar 4, 2005 | 08:15 AM
  #368
KaZ's Avatar
KaZ
I'm not trying to steer anyone away from it... I just didn't want people to think that there is NO danger at all with using an underdrive pulley... there is a small amount of risk, just like using any other aftermarket part... =) But this is still a killer deal, and I'm definitely buying one...
Old Mar 4, 2005 | 08:43 AM
  #369
GodFather's Avatar
Made in Taiwan
well, now i think i am mis-informed by the old guys who did the pulley talk in the past. they all pointed out that our VQ's come with a built in harmonic balancer. replacing the pulleys, we don't have to worry about the dampers at all. i went down to take a look at all 4 of my maxima's pulleys. it seems like my 95 pulley is a little different than the 97 pulley. it's really similar, but 95 pulley looks bulkier. but it could be just too dirty. i dont know anymore. however, besides oil seal leak, there are no other problems i heard about replacing pulleys in this car.
Old Mar 4, 2005 | 10:00 AM
  #370
zx2max's Avatar
1. Makavelisk 2003
2. joosdawg 1999
3. joosdawg 1995
4. Dubbya 1996
5. illmortal 1997
6. mad-max98 1998
7. upstatemax 2001
8. IWNTMORHP!! 2002
9. cyu1 1995
10.asianmusketeer 1995
11.scopium 2001
12.96GreenMax 1996
13.maxspeed96ct 1999
14.maximariceboi 1999
15.celica 2003
16.goodhead 1996
17.WaydeMAX 1998
18. 99NJMAX 1999
19. Sentinal 1998
20. 4DRSpeed 1995
21. cyu1 1996
22. tdogg169 2002
23. crazcajun 2003
24. Nazca 1999
25. Eckohb 1997
26. Puppetmaster 2002
27. Imxelite 2003
28. Mr.Duck 1999
29. komax 2000
30. PhillyDonut 1998
31. mrseed 1997
32. Bladerunr 2003
33. RichP23 2000
34. 1CrabbyMax 1998
35. rchun08 2002
36. abci30 1998
37. KaZ 1997
38. zx2max 1997
Old Mar 4, 2005 | 10:02 AM
  #371
IWNTMORHP!!'s Avatar
CAN YOU PUT IT ON THE WALL?
Ok...i am anxious and getting the itch...my question is for anyone who has replaced their pulley on an 02. question is, did you do it yourself, and if so, is it a backyard project or should a professional do it. my buddys shop lists 1.2hrs to do the job, but he didn't give me too many details regarding the steps involved, so i am just looking for a little insight. thanks
Old Mar 4, 2005 | 10:04 AM
  #372
Zipp028's Avatar
So, from all this who has had problems with an aftermarket pulley? I have only heard people talking about some one who has had a problem with it. I ram yet to hear anyone say they had a problem with the pully. All I hear is the he said she said. So who has had problems? They seem to be rare..
Old Mar 4, 2005 | 12:02 PM
  #373
GodFather's Avatar
Made in Taiwan
it's not a backyard job, you'll have to get someone with a high torque powertool to install it.
Old Mar 4, 2005 | 12:13 PM
  #374
makavelisk's Avatar
There are write ups on how to do this with or without an impact wrench. Its not a hard job to do, the belts are the PIA.
Old Mar 4, 2005 | 02:01 PM
  #375
joosdawg's Avatar
i say its a backyard job
Old Mar 4, 2005 | 04:41 PM
  #376
Dubbya's Avatar
VK56 Inside
I have read the write up's for the 4th gen install and it seems pretty easy. I am going to attempt "the backyard job."
Old Mar 4, 2005 | 06:37 PM
  #377
KaZ's Avatar
KaZ
To break my bolt loose on the crank, I had to have a friend put it in 5th, and stand on the brakes with his foot, then a buddy of mine and I yanked on the bolt with a pipe slid OVER a breaker bar... and it BARELY came loose... I broke a 3/8 to 1/2 adapter while I was at it. I tried a 90ft/lb impact, and then a friend brought a beefier snap on impact, and it still wouldn't move... finally got it loose with the breaker bar as I described. Its not a 1 man operation, that's for sure... and I've have NO idea how to suggest to get it off with an automatic trans (you can't "lock" the transmission with an automatic by putting it in gear like you can a manual trans, you'd probably have to drop the starter and have someone hold a screwdriver in the teeth of the torque plate keeping it in place while you attempted to loosen the crank bolt).
Old Mar 4, 2005 | 08:34 PM
  #378
Xmax's Avatar
Well according to Haynes Repair manual page 2B-15 you would use a chain strap wrench to hold onto the crank pulley and using a breaker bar to loosen the nut.
Old Mar 4, 2005 | 09:01 PM
  #379
The original VQ...
To break my bolt loose on the crank, I had to have a friend put it in 5th, and stand on the brakes with his foot, \ (you can't "lock" the transmission with an automatic by putting it in gear like you can a manual trans, you'd probably have to drop the starter and have someone hold a screwdriver in the teeth of the torque plate keeping it in place while you attempted to loosen the crank bolt).
With my 5spd, the pulley would still turn when it was in gear during the install, was i doing someting wrong?
Old Mar 4, 2005 | 09:19 PM
  #380
eckohb's Avatar
what if i have a high torque power tool in my backyard?
Old Mar 7, 2005 | 09:41 AM
  #381
KaZ's Avatar
KaZ
Were you going it yourself? The maxima is an open diff up front... if one wheel is off the ground, that wheel turns... i.e. the one you took off to get access to the crank pulley. =) That's why I had a friend of mine sitting in the car with his foot on the brake, to lock both wheels in place so I could torque against them. Brakes being locked and the car in gear, locked the drivetrain in position. Otherwise, the engine will just roll over as you attend to torque it off.
Old Mar 7, 2005 | 09:43 AM
  #382
KaZ's Avatar
KaZ
It might work... my friend's snap on was like a 210ft/lb cordless impact...
Picture:
Specs:
Stock # CT3850
Name Impact Wrench, Cordless, 18 Volt, 1/2" Drive (U.S.)
Price** $469.95
Square Drive, inches 1/2
Tightening Torque, ft. lbs. (N•m) 210 (284)
Free Speed, rpm 1,950
Blows per Minute 2,400
Motor/Battery Voltage 18VDC
Battery Type Nickel-cadmium
Battery Life 600 cycles
Charge Time approx. 45 minutes
Length, inches (mm) 9.5 (241)
Weight, lbs. (kg) 6.5 (2.95) with battery
Battery CTB3185
Battery Charger CTC318 or CTC328
And it still wouldn't budge... so... unless your stuff is stronger than that...
Old Mar 8, 2005 | 04:46 AM
  #383
Ok guys...just an update, well, not really. more just checkin in. Brett got back to me and said they do not have a definite date on delivery but they are aware of the interest and don't want to let anyone down. please hang tight. I know everyone is getting the bug again, but spring for most of us is a ways off still, so be patient. We will have them as soon as I get the word from Brett. Once the delivery is confirmed then then I will post payment arrangements/instuctions. Thanks guys and thanks again mak!
Old Mar 8, 2005 | 07:20 AM
  #384
Dubbya's Avatar
VK56 Inside
I am definately gonna hang in there on this deal. Hope everyone else does too!
Old Mar 8, 2005 | 09:36 AM
  #385
makavelisk's Avatar
Sure thing Iwntmorhp....I dont care if it takes them a few months Im still getting this.
Old Mar 8, 2005 | 03:31 PM
  #386
Mr.Duck's Avatar
hey guys i gotta back out, found a better deal on a used one
Old Mar 9, 2005 | 11:20 PM
  #387
eckohb's Avatar
im out of this too. i was hoping to have it before track time in april, but even if it does pop up, oh well. im going to use this money towards more beneficial mods this summer.
Old Mar 10, 2005 | 06:25 AM
  #388
please remove your name from the list and keep it updated...please. thanks for your help.
Old Mar 10, 2005 | 07:12 AM
  #389
GodFather's Avatar
Made in Taiwan
hey morphy, please ask brett sandstorm to see approximately when the pulleys will start to sell. i'm debating whether to get the ebay pulleys or not. it's about the same thing but cost a little bit less. however, it still seems to me that this pulley is a bit lighter. anyways, i need to know which one comes first now since i just got the mevi put on, and i want to regain some of my mid range power. pulley needs to come in asap!!!
Old Mar 10, 2005 | 07:49 AM
  #390
He sent me an email the other day and didn't have a definitive answer, which wasn't great news, but said he would update me as soon as he had more info on arrival date. I would be careful with the ebay pulleys...oil rings and stuff could cause some problems, but if you feel comfortable with the product, like any ebay purchase, weigh your options. I was afraid ppl would start getting the bug and bailing for other deals or other mods...I hope this doesn't become a trend. I let Brett know ppl were getting restless, so they are aware that the pressure is on them to get em done. I am sure they are moving it as fast as they can. All I can say is that I am sure it will be worth the wait. Thanks again guys! Hang in there.
Old Mar 10, 2005 | 07:54 AM
  #391
RichP23's Avatar
Thanks for keeping us updated.
I would like to get it sooner than later, but I have no problem waiting.
As long as I don't sell the Max before then, my name will stay on the list.
Old Mar 10, 2005 | 08:25 AM
  #392
makavelisk's Avatar
*******UPDATED LIST********
1. Makavelisk 2003
2. joosdawg 1999
3. joosdawg 1995
4. Dubbya 1996
5. illmortal 1997
6. mad-max98 1998
7. upstatemax 2001
8. IWNTMORHP!! 2002
9. cyu1 1995
11.scopium 2001
12.96GreenMax 1996
15.celica 2003
16.goodhead 1996
17.WaydeMAX 1998
18. 99NJMAX 1999
19. Sentinal 1998
20. 4DRSpeed 1995
21. cyu1 1996
22. tdogg169 2002
23. crazcajun 2003
24. Nazca 1999
25. Puppetmaster 2002
26. Imxelite 2003
27. komax 2000
28. PhillyDonut 1998
29. mrseed 1997
30. Bladerunr 2003
31. RichP23 2000
32. 1CrabbyMax 1998
33. rchun08 2002
34. abci30 1998
35. KaZ 1997
36. zx2max 1997
Old Mar 10, 2005 | 08:27 AM
  #393
makavelisk's Avatar
They need to move their ***** along
I havent spent any money on my car lately and my tax return is burning a whole in my pocket.
Old Mar 10, 2005 | 08:52 AM
  #394
Mr.Duck's Avatar
illmortal, check out the RVM UDP threadin the general forums, very interesting. Well i got my motostorm udp for 60 shipped, including belts, so yea... hehe enjoy it guys! hopefully you guys get a kick *** deal for having 36 ppl, i just couldnt wait anymore!
Old Mar 10, 2005 | 11:40 AM
  #395
makavelisk's Avatar
How did you get the motostorm for that cheap???
Old Mar 10, 2005 | 11:48 AM
  #396
RichP23's Avatar
He bought it used.
Old Mar 10, 2005 | 12:27 PM
  #397
GoalieKeg's Avatar
I'm in.
1. Makavelisk 2003
2. joosdawg 1999
3. joosdawg 1995
4. Dubbya 1996
5. illmortal 1997
6. mad-max98 1998
7. upstatemax 2001
8. IWNTMORHP!! 2002
9. cyu1 1995
11.scopium 2001
12.96GreenMax 1996
15.celica 2003
16.goodhead 1996
17.WaydeMAX 1998
18. 99NJMAX 1999
19. Sentinal 1998
20. 4DRSpeed 1995
21. cyu1 1996
22. tdogg169 2002
23. crazcajun 2003
24. Nazca 1999
26. Imxelite 2003
27. komax 2000
29. mrseed 1997
30. Bladerunr 2003
31. RichP23 2000
32. 1CrabbyMax 1998
33. rchun08 2002
34. abci30 1998
35. KaZ 1997
36. zx2max 1997
37. Goaliekeg 1998
Old Mar 10, 2005 | 07:24 PM
  #398
Wheelie King's Avatar
Add me to the list.
1. Makavelisk 2003
2. joosdawg 1999
3. joosdawg 1995
4. Dubbya 1996
5. illmortal 1997
6. mad-max98 1998
7. upstatemax 2001
8. IWNTMORHP!! 2002
9. cyu1 1995
11.scopium 2001
12.96GreenMax 1996
15.celica 2003
16.goodhead 1996
17.WaydeMAX 1998
18. 99NJMAX 1999
19. Sentinal 1998
20. 4DRSpeed 1995
21. cyu1 1996
22. tdogg169 2002
23. crazcajun 2003
24. Nazca 1999
26. Imxelite 2003
27. komax 2000
29. mrseed 1997
30. Bladerunr 2003
31. RichP23 2000
32. 1CrabbyMax 1998
33. rchun08 2002
34. abci30 1998
35. KaZ 1997
36. zx2max 1997
37. Goaliekeg 1998
38. Wheelie King 1997
Old Mar 10, 2005 | 08:07 PM
  #399
Jason R's Avatar
aka UNCDooD
can I get in on this thing too?
Old Mar 10, 2005 | 09:20 PM
  #400
GoalieKeg's Avatar
Copy and paste the list and put your name in there.
