GD: D2 Racing 36 Way Adjustable Full Coilovers $825 shipped
Old Aug 25, 2004 | 02:10 PM
  #41
Momaxima's Avatar
what im guessing is the first shipment will be ordered by the 31st, and there will be another shipment 2-3 weeks later for same price only till the 7th of september
Old Aug 25, 2004 | 02:11 PM
  #42
Momaxima's Avatar
i have a newb question, what do you mean by 'rebuilding the strut'? is that only for coilovers?
Old Aug 25, 2004 | 04:17 PM
  #43
BEJAY1's Avatar
Conecarver
It applies to non-coilovers also. Higher quality cartridges can be opened, reworked, and then sealed again. That allows you to change valves, replace seals & fluid, etc. as it wears out.
Old Aug 25, 2004 | 05:25 PM
  #44
Momaxima's Avatar
But these should last the lifetime of the car no?
Old Aug 25, 2004 | 07:10 PM
  #45
Sin's Avatar
Sin
The shocks/struts should last about 2-3 years of optimal performance. After that, you'll lose enough dampening to feel it. Then again, at $100 per rebuild of each of four, that's only $400 for a for all intents and purposes, a new coil over setup. 2-3 years is just an average. It all depends on the road conditions (potholes), miles, weather, etc.
Old Aug 25, 2004 | 07:39 PM
  #46
UrbanImport's Avatar
What are the spring rates (front/rear) on the A32 coilovers, how much camber adjustability is there in the pillow ball mounts, and can different spring rates be ordered through this group deal or does the group deal include only the default spring rate?
The spring rates are 9KF/7KR. You can get any spring rate you would like with this buy. I believe the plates adjust close to 3 deg..
Originally Posted by Greeneyes
ok so if we put our order before the 31st we can still get them for $825 shipped??? I want in.... if so
Correct. Give me a call 919-383-4605 or shoot me an email.
Originally Posted by RichSpidizzy
I probably can't purchase until next summer
what's the regular price going to be?
We should have our dealer program and national advertising going by next summer so expect to pay around $1000.
Old Aug 25, 2004 | 09:29 PM
  #47
Maximus_95's Avatar
ok one question. how is the ride, compared to the tein basic's? are these d2's any good? if they are, i will buy one!
Old Aug 25, 2004 | 11:32 PM
  #48
Sin's Avatar
Sin
Hi Mike, I'm the guy that called earlier today regarding things like spring rate. At about 503 lb/in front and 391 lb/in rear which is 9kf and 7kf, I'm a little concerned that that will be more spring rate than I want. I"m sure you don't literally mean that I "can get any spring rate". Could you please list the available spring rates?
Old Aug 26, 2004 | 12:39 AM
  #49
Momaxima's Avatar
I would also like to know available spring rates, if you could either post them on the thread or pm me that would be great. Thanks
Old Aug 26, 2004 | 06:49 AM
  #50
Larrio's Avatar
The Definitive AE Master
if it makes you guys feel any better, the spring rates for the A2's are at 9kg-F/6kg-R. So the default spring rate for the D2's are relatively close to that.
Old Aug 26, 2004 | 09:51 AM
  #51
foodmanry's Avatar
Da Roller Coaster!
I just put in an order, Can't wait to get my suspension replaced...going for the more stock feel of a 7/5 spring rate.
Larry, you going to have RPM install yours? I am thinking of going with them.
Old Aug 26, 2004 | 09:54 AM
  #52
RichSpidizzy's Avatar
7/5 is what I want, or maybe 6/5
(eventually )
Old Aug 26, 2004 | 10:02 AM
  #53
foodmanry's Avatar
Da Roller Coaster!
(eventually )
I'll let you know how the ride is when I get them installed.
Old Aug 26, 2004 | 02:35 PM
  #54
The spring rates go in 1kg/mm incriments. The most common ones are:
5k (280 lb)
6k (336 lb)
7k (392 lb)
8k (448 lb)
9k (594 lb)
10k (559 lb)
Old Aug 26, 2004 | 02:59 PM
  #55
Sin's Avatar
Sin
These are the most comon ones. However, are these the only ones available? Optimally, I would like spring rates of around 500 lb/inch front, and 350 lb/inch rear. I wouldn't so much mind going up to 7kg/mm or 392 lb/inch for the rear springs, but for the front, from 448-594 is a HUGE jump.
Old Aug 26, 2004 | 04:32 PM
  #56
Mad-MAX_SE's Avatar
Still kickin'
I think he switched the 9k and 10k
9k would be about 559lb, and the 10 would be 594lb...
Old Aug 26, 2004 | 06:20 PM
  #57
Larrio's Avatar
i do all my work at TET now (andy aka slammed95's company)
for more complex work such as clutch or tranny I go to Tony, a certified nissan master tech (roy aka hnda_etr's friend)
can't wait till i get these
Old Aug 26, 2004 | 06:24 PM
  #58
Momaxima's Avatar
Placed my order today. Anticipation!
Old Aug 26, 2004 | 11:51 PM
  #59
PharoNDmist's Avatar
I'd be interested in set
Old Aug 27, 2004 | 01:12 AM
  #60
TEEdotMAX's Avatar
this is such a noob question but what's the deal w/ spring rates... the higher u go the stiffer the ride right?? what is the spring rate on tein s-techs??
Old Aug 27, 2004 | 01:23 AM
  #61
steven88's Avatar
Need A Light?
I would also like to know.....if I go with a lower spring rate than default, will it effect how well the coilover will handle? I am thinking of maybe getting a softer spring rate since evrybody says it rides very similiar to stock. But I don't want the coilover to handle like **** u know?
UrbanImport, can I still order a different spring rate? Or did you already place the order with default spring rates?
Old Aug 27, 2004 | 07:04 AM
  #62
Nealoc187's Avatar
SLOW
1kg/mm = about 56 lb/inch so 10kg/mm = about 559 and 9kg/mm = 504... he meant 504 not 594.
here's what he meant:
5k (280 lb)
6k (336 lb)
7k (392 lb)
8k (448 lb)
9k (504 lb)
10k (559) lb
Old Aug 27, 2004 | 01:30 PM
  #63
Momaxima's Avatar
I would like to know how the dampening is on these coilovers, I talked to a friend and he said that the dampening wasn't very good on D2s...i.e. very bouncy ride. Anyone can vouch for that? He is a big suspension guy so I would like to know your guys' opinions.
Old Aug 30, 2004 | 01:08 PM
  #64
steven88's Avatar
Need A Light?
any news on the progress of the gD?
Old Aug 30, 2004 | 02:45 PM
  #65
Ammi's Avatar
350 Detroit Muscle
how many people ordered these so far?
Old Aug 31, 2004 | 03:20 AM
  #66
Momaxima's Avatar
they charged my card on 8/30/04 if that helps.
Old Aug 31, 2004 | 08:05 AM
  #67
tko507's Avatar
Any D2 Racing Coilover for 2004 Maxima SE?
Old Aug 31, 2004 | 10:05 AM
  #68
Sorry for not getting back to everyone sooner. The group buy is closed, I have put in the order with D2. We had one customer cancel so there is one more set of 00+ Maxima available if anyone wants it. The order is being put together right now and should ship from D2 shortly.
Momaxima- what kind of car does your friend have? We have sold over 200 sets of D2s across the board and not had any complaints about the dampening.
Old Aug 31, 2004 | 01:26 PM
  #69
Greeneyes's Avatar
So I cant get in on this price after today?? I thought it went till the 7?? I'm sorry I shouldve called earlier but just didnt get a chance. Well let me know.
Old Aug 31, 2004 | 02:26 PM
  #70
Momaxima's Avatar
Hey Mike, he has an eagle talon awd turbo. I think he called you about an application for talons, but yeah he said that. Only 1 opinion though, do you have any customer feedback?
Old Sep 1, 2004 | 02:40 PM
  #71
Greeneyes's Avatar
So whats going on Can I still get in on this or No?? On a previous post you said that this wold end the 7 is that still true??
Old Sep 1, 2004 | 04:28 PM
  #72
Momaxima's Avatar
he said this group deal wil go on till the 7th, he placed the first order already, and he will be placing another order in 2-3weeks; this is what i gathered from the thread. You should call him, he's open till after 5pm too.
Old Sep 2, 2004 | 04:44 PM
  #73
Greeneyes, I have some extra sets on the way. Give me a call ASAP to reserve a set for the same price. thanks!
919-383-4605
Old Sep 3, 2004 | 06:45 AM
  #74
Ammi's Avatar
350 Detroit Muscle
Ok so you still have few sets available?
Old Sep 3, 2004 | 11:47 AM
  #75
I have one more available that hasn't been reserved. After that they will be on the next shipment.
Old Sep 3, 2004 | 03:29 PM
  #76
Momaxima's Avatar
Hey Mike, hows the progress on the first order? Air shipped or on UPS ground yet? please keep us updated
Old Sep 6, 2004 | 08:25 PM
  #77
Greeneyes's Avatar
Just put my order in today!!! I cant wait till they get here!!
Old Sep 7, 2004 | 07:32 PM
  #78
The first order is on the way via air mail. We should see it by the end of the week.
Old Sep 8, 2004 | 02:53 AM
  #79
Turbo95Max's Avatar
Turtle turtle... Moderator
UrbanImport
i PMed you about gettin in on this deal or the next one. let me kno. thanks
Old Sep 8, 2004 | 05:42 AM
  #80
Ammi's Avatar
350 Detroit Muscle
Did someone buy the last set left?
