VQ 30 and 35 4th and 5th gen Stainless Steel Clutch lines !!
Old Mar 24, 2005 | 09:10 AM
  #401
derrick's Avatar
hey guys, i'm back from ny, but i am behind on shipments. I sincerely apologize to those that have been waiting for over a week! This is not normally how I run business, but a combination with overselling and me being out of town put me behind. I am picking up my order today and will be shipping out all lines either with today's mail or tomorrow's mail.
Also this deal is still on!
Old Mar 28, 2005 | 08:37 AM
  #402
derrick's Avatar
The last batch of shipments went out a few days ago, hopefully everyone got theirs! Next batch going out today guys, thank you for the patience as I am now catching up on the orders!
Old Mar 28, 2005 | 09:22 PM
  #403
Broaner's Avatar
2060lbs and falling...
I finally drove with mine installed. I have no stock to compare to but it feels great. Thanks again.
Old Mar 29, 2005 | 09:08 AM
  #404
steven88's Avatar
Need A Light?
Derrick did you receive my payment? Hopefully you can get it to me by Friday so I can iinstall it
steven88@mindspring.com
Old Mar 29, 2005 | 09:40 AM
  #405
steven88's Avatar
Need A Light?
btw...I would like to know what fluids you guys are using? this is for a 2k2 6spd just for reference....
I am leaning towards the Valvoline Synthetic brake fluid....I have a big 1 liter bottle sitting at home...but the thing is...I opened it 1yr ago but it has been capped off since then...its still got ALOT of fluid left...anybody know if this is still useful or should I just buy new one?
If it isn't useful....then do you think its still useful that I pour this in and flush out all the old stock fluid using this 1yr old Valvoline syn? I heard that brake fluid is bad if it's not been sealed and capped off becuz of moisture....
Old Mar 30, 2005 | 09:58 AM
  #406
Fork's Avatar
Maximaler Experte
Still waiting for mine... but I got my fingers x'ed.
Old Mar 30, 2005 | 10:31 AM
  #407
way2fast95's Avatar
Got mine yesterday!
steven88, sweet ride! I wanna 5th gen now. As soon as I pay a car off I always want a new one.
Old Mar 31, 2005 | 11:42 PM
  #408
steven88's Avatar
Need A Light?
Derrick did you get my payment? my account shows that it cleared yesterday (the 30th)......let me know if you got it or not....
Old Apr 3, 2005 | 10:44 PM
  #409
steven88's Avatar
Need A Light?
bumpity bump bump.....anybody home? derrick did you receive my payment?
Old Apr 5, 2005 | 12:08 PM
  #410
steven88's Avatar
Need A Light?
got my SS clutch line today...thanks derrick! i thought something went wrong for a sec there....
Old Apr 5, 2005 | 01:06 PM
  #411
way2fast95's Avatar
Can someone pm me a link to the write up for this, I can't find it, I found a right up in the stickies for replacing one of the lines, but I don't know if this is the right one and I can't hardly see the pics any way.
Old Apr 5, 2005 | 01:11 PM
  #412
steven88's Avatar
Need A Light?
http://www.motorvate.ca/mvp.php/803
try that website....it only tells you how to bleed the clutch lines...not replace them.....but even a chimp can figure out how to replace the line....its right dead smack in yer face if u remove the intake snorkel
Old Apr 13, 2005 | 07:59 PM
  #413
aznsap's Avatar
how long is this deal good for?
Old Apr 15, 2005 | 06:58 PM
  #414
derrick's Avatar
aznsap hi, the deal will stay good for as long as there is a serious amount of interest. thank you!
Old Apr 17, 2005 | 07:16 PM
  #415
aznsap's Avatar
hey cool. i paypal'd you on april 15. thanks derrick.
Old Apr 18, 2005 | 09:57 PM
  #416
VQuick's Avatar
Chassis Freak
Hello everyone, I was one of the first people in on this deal (thanks, derrick!) and I installed my clutch line in November. I don't drive my Max nearly as much as most people and I actually put it away for 3.5 months this winter. About two weeks ago I finally brought it out for the season so I've driven with the new clutch line for about six weeks total.
Anyway, I just wanted to warn everyone, at least those with 4th gens, about a potential problem. This problem is NOT Technafit's or derrick's fault, it was totally my fault. When I installed the clutch line, I reused the stock flow-through bolt that attaches to the slave cylinder (which is right on top of the tranny). It looked like the bolt that Technafit supplied (which has a larger head) would be much harder to tighten due to the ridiculously tight space you have to work in for that bolt. So I figured the OEM bolt would work fine. And it appeared to work fine for six weeks of driving.
Today while driving my clutch went out without warning. All that happened was fluid suddenly started leaking out of the aforementioned bolt so I lost my clutch. My clutch pedal hit the floor and stayed there as I was trying to accelerate from a stop. There was no way to get the car in gear with the engine running unless I wanted to risk damaging my tranny and jam it into gear without clutch (which I wasn't about to do). I was able to push the car to a parking spot and do what I should have done in November—USE THE BOLT THAT TECHNAFIT SUPPLIES!
The OEM bolt has a 12mm head and is much longer than the Technifit bolt, which has a 9/16" head and is threaded all the way to the bottom, unlike OEM. Once you get the right angle, it's actually quite easy to get a crescent wrench in to tighten the new bolt, but you have to use the open end, not the box end. Be sure to use the copper crush washers and torque the bolt down to 14 ft-lbs, that's spec. (It's not really very tight.) When I originally tightened down the OEM bolt I had to get it really tight because it would leak otherwise. This is because the banjo connection on the stainless line is thinner/shorter than the banjo connection on the rubber line. Thus, if you try to use the OEM bolt with the SS line, the bolt won't tighen far enough because I think it's hitting the bottom of its socket in the slave cylinder.
Just a few hours later my car is back up and driveable. Thanks to Broaner for helping me out tonight.
Old Apr 19, 2005 | 10:07 AM
  #417
Broaner's Avatar
No prob. It was at least 50% my fault that we used the OEM one so I owe it to ya.
Old Apr 21, 2005 | 04:25 PM
  #418
derrick's Avatar
great info vquick and broaner, i hope everyone read that!!! use the bolt supplied!
Old Apr 24, 2005 | 08:27 AM
  #419
Max1man's Avatar
I'll be PayPaling you on Wed. Derrick. This is a great deal and my brother, Jar, bought one from ya and is happy soooooo.
One note to that guy talking about Syn fluid in the clutch line. With this SS line it's probably alright but with the rubbers..HELL no. That's why Im replacing the line with the SS now cuz the Silicone has started eating the rubber and it leaks a tad where the crimped on connectors are. One note about Syn (DOT5) fluid, as I understand it, does not generate nearly as much compression as 3/4 fluids. The clutch pedal will feel nowhere NEAR as stiff as it does with the 3/4 fluids. If you gotta have Syn...IMHO, stick with 5.1 (at least it's not silicone based).
Old Apr 28, 2005 | 10:22 AM
  #420
aznsap's Avatar
I still haven't received my clutch line yet!
Old Apr 29, 2005 | 09:50 PM
  #421
derrick's Avatar
hey andrew i pmed you your tracking info
Old May 1, 2005 | 09:08 AM
  #422
Max1man's Avatar
You've got PayPal. Like I said in the notes, I'm not stressed on time so take care of the younguns giving you hell first
Old May 9, 2005 | 06:38 PM
  #423
japmaxSE's Avatar
Go Get a Life!
Whats da Deal Derick it's been two weeks now. I PM'd you I havn't heard from you since. where's my SS clutch line.
Old May 10, 2005 | 12:34 PM
  #424
japmaxSE's Avatar
Go Get a Life!
I FINNALY RECiVED MY ITEM BUT YOU GOTTA NOTIFY ME WHEN YOU RECIVE MY PAYMENT AND SENDING MY ITEM IT'S ONLY Courteous THAT YOU DO .
Old May 10, 2005 | 01:37 PM
  #425
Max1man's Avatar
Geez..some people just have no patience! It's 25$ for chrissake!!!!!!
Man..don't even sweat mine. Get to it when you can. When it arrives I'll be happily surprised for the day.
Old May 10, 2005 | 07:38 PM
  #426
GodFather's Avatar
Made in Taiwan
is the deal still on? tried many ways to contact derrick, but no answers yet.
i need one quick. hopefully an answer will chime soon...
Old May 10, 2005 | 08:30 PM
  #427
GodFather's Avatar
Made in Taiwan
sent 30 bucks to you through paypal, trying to get the kit soon. in desperate need.
thanks...
Old May 11, 2005 | 12:24 PM
  #428
derrick's Avatar
cyu1 your kit is going out within 1 day i'll priority mail it to you since it seems like you need it real bad (i imed you back but you were gone that day)
japmax please chill out. i sent your line out after i received your payment (and i also had the automated label printing program email you your tracking #) and despite my repeated attempts to contact you your email system blocked each and every one of my messages as well as the message with tracking #. Check your email system's "spam" settings, because it was not letting my mail through.
Old May 11, 2005 | 01:41 PM
  #429
japmaxSE's Avatar
Go Get a Life!
I'm not mad, in fact I'm a very patient person I just didn't hear from you at all you should have Pm'd me on the ORG. I know your verey reputable, I was just a little worried, no biggie. I do have it and it's exactly what I hoped for so Thanks...
Old May 11, 2005 | 06:37 PM
  #430
GodFather's Avatar
Made in Taiwan
thanks derrick, you're a good man.
Old May 12, 2005 | 01:17 PM
  #431
Max1man's Avatar
Hey I just got my shipping confirmation! Thanks for a great experience Derrick. You've got my
Old May 14, 2005 | 10:56 AM
  #432
GodFather's Avatar
Made in Taiwan
thanx derrick, got the clutch lines today. they looked great. i appreciate your help.
Old May 14, 2005 | 09:30 PM
  #433
derrick's Avatar
no problem cyu1, hopefully you can get your car up and running now!
Old May 16, 2005 | 05:37 PM
  #434
inspiredbykev's Avatar
You should thank my D***
Sent Paypal payment.
Old May 16, 2005 | 05:46 PM
  #435
Max1man's Avatar
Just got mine today! Thanks again sir
Old May 17, 2005 | 10:03 AM
  #436
derrick's Avatar
You are welcome max1man, enjoy it!
Old May 17, 2005 | 07:37 PM
  #437
GodFather's Avatar
Made in Taiwan
got it installed. dude, it feels great. engagement is much crispier than before. loving it. this is surely a good deal derrick. keep up the good work
Old May 18, 2005 | 07:44 PM
  #438
Let me know when it ships out.
Old May 19, 2005 | 05:55 AM
  #439
Max1man's Avatar
+1 Got mine installed and loving it! Great product D..thanks again.
Old May 19, 2005 | 12:20 PM
  #440
CheshireCat76's Avatar
Paypal payment sent
