Ksport 2005 Drift Season KickOff Special. $740 shipped!
Old May 21, 2005 | 05:19 PM
  #241
Studio718's Avatar
wondering if this $740 GD is still good? I just got a 4th gen and looked here kinda late..PM me plz for that I dont check the threads 2 often.
Old May 22, 2005 | 11:00 AM
  #242
choray911's Avatar
The Crazy Azz Cracka
Jinsu check pay pal!! Hook me up!!!!
Old May 22, 2005 | 12:13 PM
  #243
jinsu's Avatar
order is being processed. Thank you for your business!
Old May 22, 2005 | 04:58 PM
  #244
Maximeltman's Avatar
Jinsu, check paypal, just ordered mine.
Old May 22, 2005 | 08:54 PM
  #245
Jason R's Avatar
aka UNCDooD
I should be ordering my set tomorrow or tuesday.
Old May 23, 2005 | 01:35 AM
  #246
maxxpower's Avatar
I have a 2000 and want to order these COs. I'm just confused as to what i need in addition to mount these on my car(something about a rear mount). And where can I get it? My friend said he would be able to install as long as I had all the parts. Thanks in advance.
Old May 23, 2005 | 04:44 AM
  #247
jinsu's Avatar
it's a rubber piece that you take off your stock rear suspension.
Old May 23, 2005 | 06:26 AM
  #248
nismotek's Avatar
You can get the rubber upper mount from the stock rear struts, or buy them from Nissan. I'm not sure about the cost, though.
Old May 23, 2005 | 07:57 AM
  #249
Nathan's Avatar
Can someone post a picture of this rear rubber piece or circle the part in the picture above? I currently have a Ground Control/Koni setup and I'm not sure if I have this part installed right now, since I sold my entire stock suspension.
Old May 23, 2005 | 01:28 PM
  #250
d00df00d's Avatar
Old enuf to pick his own gears
Payment sent!
Old May 23, 2005 | 01:40 PM
  #251
Spaniard's Avatar
I just talked to a Nissan Dealership. Apparently, this is not a gasket but the actual Strut mount... Where the strut connects to the car...
The parts rep said he didnt think it would be possible to to install a strut without it and that I almost for sure still have it. So Im counting on that being the case, especially since ....-- they are $56.00 EACH...
EDIT: So I guess the question should be asked - has ANYONE found that they needed to buy this part or that it wasnt on the car anymore?
Old May 23, 2005 | 02:41 PM
  #252
jinsu's Avatar
For anyone that have ordered in the past 3-4 days. If you would like to wait for our main shippment to clear the port on 6/15 then i can offer a $30 discount for ppl that are not in a hurry to get their kits. let me know asap on what you want to do.
Old May 23, 2005 | 03:27 PM
  #253
maxxpower's Avatar
payment sent!!
Old May 23, 2005 | 03:55 PM
  #254
IgS's Avatar
IgS
im very interested
what are the softest spring rates that i can order?
Old May 23, 2005 | 05:51 PM
  #255
jinsu's Avatar
you can go -2kg from the default rate but ksport will not gurantee the kit will have a good ride. Ksport engineers have tried all settings and designed the best combination. If you feel confidentenough that you know more about suspension and the inner working of ksport then order whatever you feel like to. But I would not recommend it.
Old May 23, 2005 | 06:35 PM
  #256
IgS's Avatar
IgS
im not a suspension guru, so i will go with whats recommended, but what do you mean not a good ride??
Old May 23, 2005 | 06:38 PM
  #257
jinsu's Avatar
a mismatched spring/shock suspension will give harsh, bouncy and unpredicatble turning and weight transfer.
Old May 23, 2005 | 08:43 PM
  #258
Nathan's Avatar
This is true. Guys, you should just stick with the given spring rates, or buy an extra set of springs with lower spring rates from jinsu.
Old May 23, 2005 | 09:13 PM
  #259
IgS's Avatar
IgS
oo ok, how much are the extra springs with the -2kg?
Old May 23, 2005 | 09:25 PM
  #260
krismax's Avatar
Father of the 00 VI
I just put comptech springs on my RSX and each spring i believe was a diffferent weight because the cars weight is diff all the way around are these done like this ?
And also my max right now weighs around 2600lbs by the time i order these itr will prob be low 2500's. Shouldnt i need a tottaly diff spring rate setup than say a 3100lb maxima?
Thanks just curious because my car has H&R 's and tokico blues and my car rides higher than stock even with H&R drop
Old May 23, 2005 | 09:51 PM
  #261
d00df00d's Avatar
AFAIK, no one's even researched the Max extensively enough to be able to work out a setup with different spring rates all around.
You could probably get away with lower spring rates. Keep in mind, though, that these coilovers probably won't sit hugely higher than normal if your car is light. If they do, you can just lower them.
Old May 23, 2005 | 11:54 PM
  #262
upstatemax's Avatar
you can have a good ride on different spring rates other than what KSport chose....
I have the same spring rates as KSport and they are borderline too stiff for daily driving, however, the car takes turns like never before... if I could do it over again I would have gone a step softer for better daily driving.
the trick is to match the front and rear properly. KSport chose those spring rates for the best cornering and handling, not comfort...
Old May 24, 2005 | 12:05 AM
  #263
d00df00d's Avatar
True.... but then they valved the shocks for maximum control with those spring rates and the weight of the car, and good comfort naturally follows from that. They did put handling first and comfort second, but at least you end up with a balance.
Old May 24, 2005 | 04:46 AM
  #264
jinsu's Avatar
If comfort is your first priority on the list when u look for suspensions, then you should never considered a competition coilover like ksport to begin with.
Spring matching take extensive knowledge in suspension and the car and isn't an easy job for most average joes out there. So i would recommend to go with the default rate that ksport sends out.
Old May 24, 2005 | 11:04 AM
  #265
Maximam's Avatar
How do I know which springs are which spring rate? They have no markings that I can see.
Old May 24, 2005 | 11:52 AM
  #266
jinsu's Avatar
you just have to trust us! I am not eactly sure on how u tell which one is which. Ksport can better answer this question. You can just ask them by im or calling
Old May 24, 2005 | 06:51 PM
  #267
Spaniard's Avatar
Payment sent!!!!! I DONT want the cheaper price with slower shipping... In fact I can hardly wait 2 weeks!! Thanks Jinsu for this awesome deal!
Old May 24, 2005 | 07:17 PM
  #268
d00df00d's Avatar
Jinsu, I take it there are some troubles with shipping from the factory and you guys are gonna have to expedite shipping on some orders just to be able to fill them. I work at an Internet-based retailer so I feel your pain! Let me assure you though, if I get my order promptly and it works out as well as I think it will, you can be damn sure I'll do my part to help make sure K-Sport gets the publicity it deserves.
Agreed, Spaniard?
Old May 24, 2005 | 07:25 PM
  #269
Spaniard's Avatar
Fully agreed..!
If I get these in 15 days I would be glad to replace my TIRERACK sticker with a K-SPORT sticker and sing the virtues of these coilovers as I decimate the competition in time trials this season ...
Old May 24, 2005 | 08:00 PM
  #270
Jason R's Avatar
aka UNCDooD
How long will I have to wait if I order a set tomorrow?
Old May 24, 2005 | 11:09 PM
  #271
Mr.Duck's Avatar
hell i have had great customer service from ksport, and i have done a lot to get their name out there... and i think a lot of you can vouch for that one
Old May 25, 2005 | 04:31 AM
  #272
jinsu's Avatar
10-15days.
Thanks for all your support! Jinsu Trading LLC has offically become the Best Ksport Dealer in May 2005! We could not done it without you guys. Thank you once again! Keep the orders coming!!
Old May 25, 2005 | 05:58 AM
  #273
Nathan's Avatar
10-15days.
Thanks for all your support! Jinsu Trading LLC has offically became the Best Ksport Dealer in May 2005! We would not done it without you guys. Thank you once again! Keep the orders coming!!
Wei, congrats!
I'm hoping to receive my set before this weekend so I can show all the Toronto guys this Sunday at our big monthly meet. If others want them I'll send them your way.
Old May 25, 2005 | 08:56 AM
  #274
Spaniard's Avatar
Congrats JinsuPower!
Hey, I know im being a bit high-maintenance, but can you give me a quick post confirming that you got my paypal? Thanks and sorry to be needy...
Old May 25, 2005 | 10:33 AM
  #275
d00df00d's Avatar
Me too please!
Old May 25, 2005 | 10:57 AM
  #276
Mr.Duck's Avatar
needy bastards.... haha i remember when i was going crazy like you guys
Old May 25, 2005 | 12:46 PM
  #277
jinsu's Avatar
all your orders have been processed!!! THERE YOU HAVE IT!
Old May 25, 2005 | 01:01 PM
  #278
d00df00d's Avatar
Thanks Jinsu
Old May 25, 2005 | 02:19 PM
  #279
Jason R's Avatar
aka UNCDooD
I can't wait for these to get here.
Old May 25, 2005 | 02:28 PM
  #280
Spaniard's Avatar
