Cattman Y-Pipe GD Coming Soon!
Originally Posted by neroup5
nov 4th cant get here fast enough.
I don't think we'll have as many as I'd like built by then, but hopefully we can get started by the 4th - if not, it will be the next week. Too soon to start making installation appointments.
Brian C Catts
Cattman Performance
Originally Posted by Stewpid
Need to know shipping price to Toronto area before confirming "for sure"
US Postal Service will get it there in 4-10 days for $33, 3-5 days for $48 - fully insured. UPS, FedEx, etc. may be cheaper on the front end, but by the time you pay the hidden brokerage and other fees at delivery, you'll pay more. Many of our Canadian customers insist on USPS after getting dinged by the private carriers (they even charge a fee for collecting the fees!).
No matter how they arrive you'll have to pay GST/PST on the declared value, but that's all there is to it with a USPS shipment.
Brian C Catts
Cattman Performance
]FOR SURE (Please Confirm):
1. SixxOne... Cali Spec/ 00
2. 2k3max2nv
3. neroup5... FED/ 2000
4. bigfy39... Cali/ 2000
5. dennisuello... Cali/ 2000
6. sublimer... Cali/ 2001
7. gennady7... Cali/ 2000
8. NismoGTR... ???/ 2002
9. NYPD-Arnold... Cali/ 2001
10. Stewpid... FED/ 2000
11. Lex3015... Cali/ 2000
12. TrojanMan2116... Cali/ 2001
13. HitmanAngel2k3... FED/ 2003
14. Rocket1991... FED/ 2000
15. 03maxima1... ???/ 2003
16. vervaak... Cali/ 2000
17. waytoostock00... Cali/ 2000
18. Woo Cho... FED/ 2000
19. Ephraim... FED/ 2000
20. MaximusMorpheus 2003
21. dasd_clipper...cali/1999
22. custommaximaSE..... FED/2000
BTW, how can u tell if u had FED/CALI ? I guess I'm Fed?
2. 2k3max2nv
2. 2k3max2nv
2. 2k3max2nv
See drawing on first page.
Just a reminder that the only years where the emissions types matters is 1999 or 2000. If you have a 95-98 or an 01-03 (and 04 I35s), the emissions system has no effect on the Cattman y-pipe you buy.
Brian C Catts
Cattman Performance
This is a nice offer...thank you.
2. 2k3max2nv
21. Eric Holmes Cali/2000
Interested:
1. 2kmaxinblack... FED/ 2000
2. SpeedyMaxima...FED/ 1997
3. 2kVQboodah... Cali/ 2000
4. ABS... ???/ 2002
5. Stalldaworld... ???/ 2003
6. MaxPol74... 2003? FED
By the way, I have a warpspeed Y-pipe and I have never been quite satisfied with its performance. First, the exhaust hanger bracket is not welded to the pipe but is a piece of metal attached to an exhaust clamp. Second, the flange of the Y-pipe that mates with the catalytic converter is not flat because they flared the pipe and simply left the flange loose...I'm guessing these two eccentricities were engineered to compensate for bending irregularities in the pipe itself that would otherwise compromise installation. Incidentally, because of the ~3mm or so of flared pipe protruding into the mating area of the flanges, it is almost impossible to get a good flat seal on the flange gasket. Unfortunately, all of this results in a very sloppy install that is not solid and is prone to leaking.
There are also two additional unpleasant consequences I have noticed from this: 1)the y-pipe will sometimes come into contact with the frame crossmember that sits just before the catalytic converter unless I really wrench on the hanger contraption. Still although it doesn't sound like I have bees in a can, there is a buzzing vibration that I feel between 1000-1200 rpms which reappears again at 1600-2100rpms. Many people wouldn't notice, but I do. I have tried numerous times to remedy this by loosening the exhaust and manipulating it into different positions, but to no avail the buzz feeling still continues. One other caveat of the Warpspeed Y-pipe is that the O2 sensor bungs were not mounted at the appropriate angle for clearance around parts of the undercarriage...it fits, but just barely. And, as someone already mentioned, an aluminized pipe for $200 does not compare to a stainless steel pipe for around $300. I hope the Cattman Y-pipe alleviates my headaches.
Brian, do you happen to have any pictures that show how your Y-pipe hanger looks when it is installed.
2. 2k3max2nv
Interested:
4. ABS... ???/ 2002
This list is really useful - I wouldn't have estimated the proportions correctly at all - more 99-01 CA/NLEV y-pipes and fewer 95-98 y-pipes than I would have expected.
As far as the review of the other y-pipe brand, couldn't have said it better myself. None of the issues you mention are present on the Cattman y-pipe, that's not how we design parts.
Here's a picture of our YG5CA pipe (for 99-01 CA/NLEV Maximas and I30s). I'll point out three features - 1) the welded hanger that come up over the flex, 2) all of the extra-thick 3/8" flanges are welded on (floppy flanges = warping and bad seals), and most importantly 3) the 2-1 merge collector that our pipes feature is unique, and a major source of the Cattman performance advantage. Also note the installation kit that is included with the pipe, rather than an extra charge.
Brian C Catts
Cattman Performance
Brian C Catts
Cattman Performance
2. 2k3max2nv
Interested:
4. ABS... ???/ 2002
2. 2k3max2nv
Interested:
4. ABS... ???/ 2002
2. 2k3max2nv
Interested:
4. ABS... ???/ 2002
7. brian02max... FED/2002
2. 2k3max2nv
Interested:
4. ABS... ???/ 2002
2. 2k3max2nv
22. BudVlad Cali/2001
Interested:
4. ABS... ???/ 2002
7. brian02max... FED/2002[/QUOTE]
2. 2k3max2nv
Interested:
4. ABS... ???/ 2002
2. 2k3max2nv
23. cutommaximaSE FED/2000
Interested:
4. ABS... ???/ 2002
2. 2k3max2nv
Interested:
4. ABS... ???/ 2002
Please don't flame me. It's been a while since I've been here.
I'm very interested in the Cattman Y-Pipe. I've been staring at Cattman's website since I joined maxima.org. Here' the common question...
What kind of gains will I see or butt feel with my stock muffler and stock cat. system? 01' SE Auto and I have a Franken Mid Pipe with POP charger for intake.
Thanks,
Ollie
Thanks,
Ollie
Originally Posted by yOoOoo
Im down for 01 fed but how much would the total would be ??
Brian C Catts
Cattman Performance
the s+h cost sounds reasonable, i want it!!!
2. 2k3max2nv
24. 2kVQboodah... Cali/ 2000
Interested:
3. ABS... ???/ 2002
4. Stalldaworld... ???/ 2003
5. MaxPol74... 2003? FED
6. brian02max... FED/2002
2. 2k3max2nv
Interested:
3. ABS... ???/ 2002
2. 2k3max2nv
8. NismoGTR... / 2002
15. 03maxima1... / 2003
Interested:
3. ABS... / 2002
4. Stalldaworld... / 2003
5. MaxPol74... FED/ 2003
7. BudVlad... Cali/ 2001
8. SC2K1... Cali/ 2001
9. Ollie... Cali/ 2001
10. yOoOoo... Cali/ 2001
P.S. I fixed the list a little. Please add yourself if I haven't added you.
Thanks,
Ollie
Thanks,
Ollie
I just ordered HS headers, 560 shipped. 3x
i have a cattman y on my 02, its a beautiful piece, and with just an intake i put down 218 WHP, 228 WTQ. it works!
Originally Posted by Stalldaworld
headers will cost you 3 times the money including a bish of an install. lots of people dont wana spend the extra cash for something that will lend a pretty low cost to horseporwer % gain.
Count me in, fellas, and, also, a special thanks to Brian for sending the decals to me at my request
Here is the revised list:
2. 2k3max2nv
25. MFLCON... / 2002
Interested:
3. ABS... / 2002
Here is the revised list:1. SixxOne... Cali Spec/ 00
2. 2k3max2nv
Interested:
3. ABS... / 2002
Originally Posted by FASSTER
Doesnt the headers for the 3.5 come with a Y-pipe? If so then why buy just this then,other than money issues compared to headers.?
Thanx,Charles
Thanx,Charles
EDIT:
Please re-read your post. No where in this post did someone mention 3.5 headers for sale or post 3.5 headers information. You can simply click the "Post New Topic" button and create your own header thread. Or you could be even smarter and give a search through a few pages, and find your answer yourself
. Or, you could donate $20+ to the forum (which keeps things running smooth), and do a search using the "Search" tab
. Or you could use a last resort of Google to find your answer
. It doesn't seem too difficult, does it? A little brain power and a little thought never hurt anyone.
Originally Posted by Gennady7
Any idea how soon it will start? the GD i mean
We'll kick the deal off early next week if my welder gets enough done between now and then. I'll announce timing and price on this thread and then its done, we'll start a new one for the group deal.
Brian C Catts
Cattman Performance
Originally Posted by IceY2K1
2001s are CALI-spec.
2. 2k3max2nv
13. HitmanAngel2k3... CALI/ 2001
Interested:
4. ABS... ???/ 2002
