AMSOIL Synthetic Lubricants
Old Apr 9, 2011 | 10:43 PM
  #801
Champ2433's Avatar
Need a quote for 5 quarts of Amsoil GL-4 75w-90 synthetic gear oil to 06812
Old Apr 10, 2011 | 06:35 AM
  #802
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
This is a great product and I sell a lot of it to our members. Sent you a PM with the cost and ordering info. Thx
Old May 5, 2011 | 04:32 PM
  #803
In addition to having great lubricants for your car, AMSOIL offers a complete line of premium synthetic lubricants for powersports, recreational, and other outdoor equipment: Boats, RVs, jet skis, motorcycles, ATV's, lawn and garden equipment, etc. The same benefits AMSOIL brings to your cars: better performance, increased longevity, highest possible fuel economy, and more also apply to these other applications.
Visit my website at www.lubedealer.com/lonestarlubes or send me a PM for a personalized quote. Thx!
Old May 9, 2011 | 03:08 PM
  #804
zenjia 03merlot's Avatar
hi, could i get a quote for 3qts of GL-4 for an '03 6speed, plus could I add (1)AMSOIL EAA-74 air filter; (1) Wix 24823 cabin air filter?
do you have an EAA air filter and cabin air filter for a 2003 Saab 9-5 3.0v6?
shipped to 94707?
thanks
Old May 9, 2011 | 06:28 PM
  #805
shipped to 94707?
thanks
Sent you a PM with pricing for the manual trans gear oil, EaA and Wix Cabin Filter.
Concerning the Saab, the only air filter I can get for it would be a Mann filter. The cabin filter is not available through AMSOIL.
Pls let me know if I can help. Thx
Old May 10, 2011 | 12:08 PM
  #806
paypal sent, thanks ed!
Old May 15, 2011 | 11:06 AM
  #807
Lawtown's Avatar
Hey, may I have a quote for 5 quarts of AMSOIL Synthetic GL-4 75w-90 Gear Oil shipped to 01841. Thanks in advance!
Old May 15, 2011 | 04:43 PM
  #808
Sent you a PM with the cost and ordering info. Pls let me know if I can help. Thx
Old May 19, 2011 | 07:14 PM
  #809
skweaky's Avatar
5 quarts gl4 75w90 shipped to 36420? Not sure if you check here or email faster so i tried both.
Old May 19, 2011 | 07:16 PM
  #810
Sent you an e-mail with the cost and ordering info. Pls let me know if I can help. Thx
Old May 31, 2011 | 07:13 PM
  #811
AMSOIL introduces Z-ROD™ Synthetic Motor Oil, a premium lubricant with a high zinc, high phosphorous content. This oil is specially engineered for classic and high-performance vehicles. It features a high-zinc formulation to prevent wear on flat-tappet camshafts and other critical engine components, along with a proprietary blend of rust and corrosion inhibitors for added protection during long-term storage.
Protects Flat-Tappet Cams
The lifters and cam lobes on flat-tappet camshafts common to classic and high performance vehicles slide rapidly against one another, producing high friction and heat. The friction between the two components can eventually wear down the cam and affect valve operation, ultimately resulting in lost engine power and reduced efficiency. In addition, these areas are splash-lubricated rather than pressure lubricated like other areas of the engine, which adds extra strain on anti-wear additives like the zinc and phosphorus in zinc dialkyldithiophosphate (ZDDP).
AMSOIL Z-ROD Synthetic Motor Oil is formulated with high levels of ZDDP to protect flat-tappet cams, lifters, rockers and other areas susceptible to wear. Its high-zinc, high-phosphorus formulation provides the extra wear protection these critical splash-lubricated components require.
Provides Long-Term Protection from Rust & Corrosion
AMSOIL Z-ROD Synthetic Motor Oil is formulated with a unique blend of rust and corrosion inhibitors to ensure maximum protection during long-term storage. To prove its effectiveness, AMSOIL submitted Z-ROD Synthetic Motor Oil to the Standard Test Method for Rust Protection in the Humidity Cabinet (ASTM D-1748). This test evaluates the rust-preventative properties of oil under high-humidity conditions, similar to those faced by a covered hot rod in a damp garage. The metal coupon treated with AMSOIL Z-ROD Synthetic Motor Oil showed no signs of oxidation after 192 hours, while the coupon treated with a leading competitor’s product failed the test after 24 hours.
APPLICATIONS
AMSOIL Z-ROD Synthetic Motor Oil is recommended for older or modified engines requiring either 10W-30 or 20W-50 motor oil. Z-ROD Synthetic Motor Oil meets API SL and earlier specifications, allowing for increased levels of anti-wear additives. ZDDP levels in Z-ROD Synthetic Motor Oil exceed the limits of API SM and newer specifications.
COMPATIBILITY
AMSOIL Z-ROD Synthetic Motor Oils are compatible with conventional and other synthetic motor oils. Mixing AMSOIL Z-ROD Synthetic Motor Oils with other oils, however, will shorten the oil’s life expectancy and reduce the performance benefits. Aftermarket oil additives are not recommended for use with AMSOIL Z-ROD Synthetic Motor Oils.
SERVICE LIFE
Because engines in classic cars, hot rods and other performance vehicles are generally modified, a universal oil drain interval recommendation for these applications cannot be given. Responsibility for determining the drain interval duration rests with the owner. As a general service guideline, the maximum drain interval for Z-ROD Synthetic Motor Oil should not exceed 5,000 miles or one year, whichever comes first. In heavily modified engines (e.g. forced induction, nitrous) the maximum drain interval should not exceed 3,000 miles or one year, whichever comes first.
Please send PM or e-mail for pricing. Pls include zip code or state of residence so I can determine applicable taxes and shipping rates. Thx
Old May 31, 2011 | 07:47 PM
  #812
nhb04tl's Avatar
i need a quote on 5 quarts of 5w20
Old Jun 1, 2011 | 07:45 PM
  #813
How long do you intend to leave the oil in service? Change oil per OEM's recommendations, run it for a full 7500 miles or more; or extend the intervals out beyond 10K? Reason I ask is because AMSOIL offers 3 families of passenger car engine oils, each formulated (and priced) for the the length of service the user is most comfortable with. Also, pls send your zip code or state of residence so I can determine correct sales tax and shipping amounts.
Thx
Old Jun 12, 2011 | 03:47 PM
  #814
AMSOIL Expands the Signature Series Line.
AMSOIL 0W-20 (ASM), 5W-30 (ASL) and 10W-30 (ATM) Synthetic Motor Oils join AMSOIL Signature Series 0W-30 to round out the new Signature Series line. Signature Series 0W-30 is now identified by product code AZO. Product code SSO will be discontinued and is only available while supplies last.
In addition to being reformulated to meet the latest API SN Resource Conserving and ILSAC GF-5 industry specifications, the new Signature Series line features all-new packaging and represents the very best motor oils AMSOIL has to offer, allowing motorists to take advantage of maximum extended drain intervals. In the interest of consistency and clarity within the Signature Series line, all four motor oils are recommended for drain intervals of up to 25,000 miles/one year, whichever comes first (15,000 miles/one year in severe service conditions).
The new Signature Series line is replacing the previous formulations of the AMSOIL top-tier oils as inventories dictate; orders will be filled with the older formulations and packaging until inventory is depleted, which may occur at varying times for each viscosity.
Pls send PM for current pricing.
Old Jun 25, 2011 | 06:47 AM
  #815
Here's a link to some good informational video's on AMSOIL lubricants being used in various applications: http://www.amsoil.com/video/AMSOIL_I...es_Videos.aspx
There's also a good video on synthetic oil basics and it explains what differentiates AMSOIL products from those offered by other lubricant manufacturers.
Pls send me a PM or e-mail for additional information, questions and/or a personalized quote. No order too big, no order too small.
Old Jun 26, 2011 | 08:44 AM
  #816
stocked out max's Avatar
may i have a quote for a 2k maxima WIX - Cabin Air Filter Part # 24823 shipped to 11735
Thank you in advance
Old Jun 26, 2011 | 04:54 PM
  #817
Sent you a PM with the price and ordering info. Pls let me know if I can help. Thx
Old Jul 17, 2011 | 06:20 PM
  #818
Looking for a motor oil with a high zinc content? AMSOIL Z-rod features a high-zinc formulation to prevent wear on flat-tappet camshafts and other critical engine components. It also contains a proprietary blend of rust and corrosion inhibitors for added protection during long-term storage. Meets API SL and earlier specifications. Pls send PM for pricing.
Old Jul 19, 2011 | 09:47 AM
  #819
aackshun's Avatar
Got mah oil!
Old Jul 21, 2011 | 11:00 AM
  #820
NABU6's Avatar
Hello - 5 quarts of Amsoil Xl 5w-30 oil with one WIX 51356 Oil Filter shipped to zip 10460.
Old Jul 21, 2011 | 06:35 PM
  #821
Thanks for your inquiry...great oil and filter combo. Sent you a PM with the cost and ordering info. Pls let me know if I can help.
Old Aug 7, 2011 | 05:54 PM
  #822
5w-20 has just added to the Signature Series line-up! So now AMSOIL's top-tier motor oil comes in 0w-20, 5w-20, 0w-30, 5w-30 and 10w-30. All five of these motor oils are recommended for drain intervals of up to 25,000 miles/one year, whichever comes first (15,000 miles/one year in severe service conditions).
As many of you know, AMSOIL recently reformulated the XL line and it is now recommended for up to 10,000 miles or 6-months of use (or longer if specified by the OEM or on vehicles with oil life monitoring systems)
AMSOIL "Original Equipment" (OE) engine oil was recently introduced and it is recommended to be changed in accordance with the vehicle manufacturer's recommendations. OE is designed for the person who wants to upgrade to a premium synthetic oil, but who is not quite ready to step up to AMSOIL's more premium, long drain oils. AMSOIL OE offers both performance and incredible value.
AMSOIL also makes premium oils, transmission fluids, gear lubricants and fuel additives for most applications: Diesel oils, power sports, motorcycles, two cycle, boats, scooters, etc. Full line of AMSOIL, WIX, Mann and Donaldson filters (oil, air, fuel, cabin, transmission, etc) available for most all applications. NGK plugs, Trico wiper blades, Mothers car care products available too.
Pls send PM for more information and price quote.
Old Aug 9, 2011 | 04:52 AM
  #823
StevieB's Avatar
4 quarts GL-4 synthetic 75W90 shipped to 12919 please, thanks.
Old Aug 9, 2011 | 07:15 PM
  #824
Sent you a PM with the cost and ordering info...pls let me know if I can help. Thanks!
Old Aug 12, 2011 | 04:26 AM
  #825
dnice02's Avatar
3 quarts of amsoil 75w90 GL-4 shipped to 29440. Thanks
Old Aug 12, 2011 | 05:56 AM
  #826
5KyL1N3's Avatar
Price for 5 quarts of 75-90 gl-4 to 80130 please.
Thanks!
Old Aug 12, 2011 | 09:45 AM
  #827
vw3819's Avatar
Hello, how much for 3 quarts GL-4 manual transmission MTGQT shipped to 65401? Also how fast could my order be filled? Thank you for your time.
-peace-
Old Aug 12, 2011 | 06:20 PM
  #828
PM's sent to dnice02, 5KyL1N3 and vw3819 with the cost and ordering information. This is a fantastic product...I sell a bunch of it to our members and the feedback is outstanding.
Vw-you asked how long to fill the order. Once I receive payment, I will process the order (get it into AMSOIL's system) immediately. I have all products shipped directly to the customer from the nearest AMSOIL Product Center. This assures you of the freshest products, widest selection, prompt delivery and it essentially cuts shipping costs in half. I'm not pushing old stock like some dealers do. Dnice02, your oil will be shipped from the AMSOIL Product Center in Orlando, and 5KyL1N3 and vw3819 your oil will be shipped from the AMSOIL Product Center in Wichita. Service is very good...I can't guarantee it, but orders usually go out the same day I process them and UPS delivery to most locations is usually within a couple business days...
Pls let me know if I can help. Thanks
Old Aug 22, 2011 | 06:39 PM
  #829
Thanks again for your orders...glad to help!
Old Aug 29, 2011 | 10:54 AM
  #830
Weimar Ben's Avatar
Helicopters! Money!!!
Price quote for a gallon and 2 quarts of ASL1G-EA (5w-30), shipped to 97123.
Old Aug 29, 2011 | 05:41 PM
  #831
Great product! Sent you a PM with the cost and ordering information. Pls let me know if I can help. thx
Old Sep 5, 2011 | 12:49 AM
  #832
HandsonMaxima.'s Avatar
A few years ago you helped me get some oils for my maxima i needed, I remember that and 3 years later I'm a returning customer!
taking my questions to PM though.
Old Sep 5, 2011 | 06:25 PM
  #833
Great! Sending you a PM with the cost and ordering info. I think you'll find the service to be just as good as the last time you ordered. Let me know when you're ready. Thx!
Old Sep 8, 2011 | 03:56 PM
  #834
Let me know if I can help with any product AMSOIL offers...premium quality synthetic motor oils, GL-4 and Automatic transmission fluids, premium long life filters iincluding a complete product line from Wix and Mann, NGK plugs, Trico blades and more.
Old Sep 18, 2011 | 09:43 AM
  #835
ajm8127's Avatar
Ed,
Can you get me a cartridge of GLC? I need to replace a wheel bearing and I figure I might as well repack the bearing I bought with good grease. ZIP is 15071. According to the Amsoil site, the product code is GLCCR-EA.
Thanks,
Tony
Old Sep 18, 2011 | 05:47 PM
  #836
Originally Posted by ajm8127
Ed,
Thanks,
Tony
Tony,
Yes, I can get that product. I've used it myself for wheel bearings and it works great. Sending you a PM with the cost. Thx, Ed
Old Sep 21, 2011 | 04:29 PM
  #837
carlosr's Avatar
looking for a quote for 6 quarts of atf fluid to 10453 for a 04 maxima speed auto (matic k) tx.
Old Sep 24, 2011 | 06:20 AM
  #838
Excellent product...you'll be very happy with the performance. Sent you a PM with the cost and ordering info. Let me know if you have any other questions. Thx
Old Sep 26, 2011 | 03:55 PM
  #839
Get your car ready for fall/winter...excellent time to do preventative maintenance with premiere quality synthetic lubricants. Pls send PM for personalized price quote.
Old Oct 10, 2011 | 06:00 PM
  #840
Ray, Thanks for the PM. Sent you the cost and ordering information for the oil, ATF and filters. These are great products...you'll be very pleased with the performance. Pls let me know when you're ready! thx
