HID Plug and Play Kits $160 SHIPPED Head Lights, Fog Lights!
Also, our connectors are the same size as there halogen counter parts
You'll be seein them before you know it partner
Yes, we do stock slim ballast. The price is an added $30 per kit. Yellow, that allow for better vision in the fog / snow. In the rain, 6000k does the same as the yellow.
Just Bulbs
Operatic,
This sounds like a great deal! I am looking for some stock replacement bulbs for my 02 Maxima. I have HIDs but am a little confused with all the lingo (D2R, D3R, etc.) I would like to keep a fairly stock look perhaps a little bit more blue, what bulbs do you suggest?
Thanks,
Drew
Thanks,
Drew
So I mounted my HH Yellow kit into my retrofitted IS300 projectors yesterday. Since the lense on the fog projectors is yellow and these bulbs are custom color yellow as well, the outcome is a fluorescent-esque lime color. Definately not the DEEP yellow, BRIGHTER than halogen color I was looking for. How much for just 2 PURE WHITE 9006 bulbs shipped to Chicago, IL 60634?
and yes, I let them warm up before making final decisions..... also I am aware of a burn-in period, but I can tell theres a lime-ish tint to it...
Operatic,
Thanks,
Drew
Thanks,
Drew
Hit you back partner
Lookin good partner
should i get single or bi
i know my 01 max requires the bi, and know that i can use the single. I know this is based on opinion, but what might be a deciding factor to get either one? also what is the current price for either set? thank you in advance
Hit you back
Hit you back also
In a 4th gen, you need only the H3 bulbs. H3c's are for 5th gen and 6th gen
If you do a lot of late late night driving (late PM early AM) then Bi-xenons are great just for that added security it gives you. But for everything else, single xenon works awesome
$130 shipped for a single xenon kit
$270 shipped for a bi-xenon kit
Hit you back also
Hey operatic, do you have any 9006 kits w/ shields on the bulbs? and will all I need is new harnesses if I wanna switch kit to a car with a different bulb size?
Depends on your application. If you have the high and low beams on separate bulbs be it from the factory or by aftermarket projector headlamps, then no. If you have the high and low beams on the same bulb, then a single xenon kit will eliminate your high beams.
Sorry, we do not have any 9006 kits with shields. Also, if you want to switch the kit over to a different car that uses a different bulb size, you would need a new bulb and sometimes a new harness.
Sent you a PM
Sent you a PM
Out of curiosity...
a) How much for a H11 and a 9005 for a Ford Edge? Do you carry the relays that this vehicle would need?
b) How much for a 9005 and 9006 for a Trailblazer SS. Do you also carry the DRL killer for GM vehicles?
BTW, I am only interested in 4150k, 5000k, maybe 6000k
Out of curiosity...
9005 is $130 shipped
we also carry the harness required for the vehicle
b) 9005 is $130 shipped
9006 is $130 shipped
also, for the Trailblazer SS, as for the DRL, we have always advised customers to this site to help them with disabling the DRL.
http://www.lightsout.org/disable.html#GMgen
