HID Plug and Play Kits $160 SHIPPED Head Lights, Fog Lights!
Old Jan 2, 2009 | 06:10 AM
  #1641
SLOW2KMAX's Avatar
Pm sent
Old Jan 2, 2009 | 07:18 PM
  #1642
operatic's Avatar
Former Sponsor
Originally Posted by Kryogen
HI, I bought a h3 fog kit 6000k a couple of months ago and today I noticed that the right bulb is dead(why?). Could I get another one under warranty?
Thx
JF Desrosiers
Sent you a PM
Originally Posted by GigEmAgs07
sent you a PM, operatic.
Hit you back!
Originally Posted by Revs2Hard
Im going to buy some on the 10th, can I still get the H3 3k foglights for $130?
Would you guys price match for a Pink H4 plug and play set? There for my headlights.
Sent you a PM also
Old Jan 3, 2009 | 03:37 PM
  #1643
MaxVQ5spd's Avatar
Originally Posted by operatic
......you can wire in an in-line diode from the high to low beam and it will keep the low beams on when the high beams are on.
I installed my 9004 bixenon 6000k kit and it works and looks great. I also did the inline diode, but the high and low beam capsules are not on at the same time. I bought a KYO harness (http://www.racinglab.com/kyoplheduwih.html) and modified it with the diode (to avoid modifying your harness or the one on the car). I have done this before and can see that the diode is in correctly as the driving lights are on when on bright (they are wired to go off on bright from the factory). Could the relays be wired in such a way as to cutoff the low beams when the high beams are active (this is my best guess at this point)? Any suggestions?
Old Jan 5, 2009 | 06:28 PM
  #1644
MoeBelikeMax's Avatar
When putting in the hid in my fogs and headlights would it be a good idea to buy a headlight plug and play Wire Harness??????????
Old Jan 5, 2009 | 10:09 PM
  #1645
operatic's Avatar
Former Sponsor
It sounds like you want two things. But from what I gather from reading it, if you do not want the low beams to be on with the high beams, remove the inline diode from the KYO harness.
You would need just the Plug and Play for the fog lights is all
Old Jan 6, 2009 | 07:36 AM
  #1646
operatic's Avatar
Former Sponsor
up for some HIDs!
Old Jan 6, 2009 | 10:01 AM
  #1647
MaxVQ5spd's Avatar
No, I just want the high and low beams to be on at the same time. I wired in a diode and that did not work. Since I wired in the diode before it plugs into the HID harness I was wondering if that could be why it did not work correctly? Is there some place on the HID harness I should wire it in that would work?
Like I said above, I know the diode is sending the signal to low and high beams because the driving lights are staying on when on high beam (the low beams are not staying on).
The only thing I can figure is that the low beam relay (on the HID harness) is kicking off irrespective of the diode. So my question is: where on the HID harness do I install the diode to make this work? Thanks.
Old Jan 6, 2009 | 09:16 PM
  #1648
Uptown Maxima's Avatar
Aye operatic...
I'm interested in some replacement bulbs for my 04 Maxima. I recently replaced them with 10,000K bulbs which looked nice but with a noticeable drop in visibility. I have factory HID's but I wanna get a nice color a bright white with a slight purple tint. Not that deep blue or purple color that screams fast and furious or please officer pull me over... Any suggestions ???
Old Jan 8, 2009 | 06:52 AM
  #1649
operatic's Avatar
Former Sponsor
The only thing that is boggling me is that is exactly how we do, we've just bought a small extension harness like your KYO and put the diode in there. So thats why I am not sure why its not working. On top of that I do not have a Maxima to try this out on. We've mainly done it for Mustangs and F-Series and Ram trucks. So I am actually at a loss as to what to tell you.
Originally Posted by Uptown Maxima
Aye operatic...
I cannot vouch for other HID bulbs but as for our own, there is not a huge light output difference between 4300k and 12000k. To illustrate my point, here is a comparison picture of the two on the same car. 12000k left - 4300k right
But for the most part I'd actually suggest 10,000k for a bluish white with a slight hint of purple, but that is what you already have :/
Old Jan 8, 2009 | 12:03 PM
  #1650
operatic's Avatar
Former Sponsor
up up up
Old Jan 8, 2009 | 03:36 PM
  #1651
MaxVQ5spd's Avatar
The only thing that is boggling me is that is exactly how we do, we've just bought a small extension harness like your KYO and put the diode in there. So thats why I am not sure why its not working. On top of that I do not have a Maxima to try this out on. We've mainly done it for Mustangs and F-Series and Ram trucks. So I am actually at a loss as to what to tell you./
Yea, it should work. I'm happy with the kit either way though. I'll keep fiddling with it and let you know if I figure it out. I appreciate your willingness to help. Thanks.
Old Jan 8, 2009 | 04:09 PM
  #1652
Coolsaber57's Avatar
Did you hook it up correctly? Direction-wise I mean.
Old Jan 8, 2009 | 08:06 PM
  #1653
MaxVQ5spd's Avatar
Yea. I've done this a couple of times before. Plus, you can tell you got it right because the driving lights will stay on when you're on high beam. However, my bright is not working on the driver side now (with the diode out). I disconnected and reconnected it and it still didn't work. Then I switched the bulbs from side to side and the problem stayed on the driver side. I think I may have a bad high beam ballast. Not sure if this diode thing caused the problem or not. I've PM'd Operatic about a solution.
Old Jan 9, 2009 | 09:41 AM
  #1654
Ankit69's Avatar
Here you go. Also the $130 shipped price is for 4300k-12000k colors with 35w ballast and for 50w ballast its an added $15 to the price.
We don't carry halogen bulbs. But our 3000k bulbs are pretty yellow if that is what you want. About as yellow if not more than the Lexus fog lights you normally see.
sorry for bringing up an old post but what (k) are the bulbs in the top pic? 6000, 8000, or 10k?
Old Jan 9, 2009 | 08:01 PM
  #1655
Revs2Hard's Avatar
BARF
payment sent for 35w pink H4's and 50w yellow H3's.
Old Jan 9, 2009 | 09:32 PM
  #1656
operatic's Avatar
Former Sponsor
They are 4300k QB they are $150 shipped for a kit or $80 shipped for a pair of bulbs.
you'll be seeing your order shortly
Old Jan 10, 2009 | 09:38 AM
  #1657
321VQ35MAX's Avatar
I want my fog lights in my 03 to look as yellow as the Lexus IS300/GS400 factory fog lights. What is my best option??
Old Jan 10, 2009 | 09:10 PM
  #1658
Revs2Hard's Avatar
BARF
^ 3k H3 HID kit
Old Jan 11, 2009 | 08:03 AM
  #1659
operatic's Avatar
Former Sponsor
Just like Revs2Hard said, H3 3k. But so you know, you will have to modify your fog light housing to fit a regular H3 HID bulb. This just involves sticking a screwdriver into your fog light housing and pushing the metal cut off plate forward a bit to fit the H3 HID bulb.
Old Jan 11, 2009 | 05:30 PM
  #1660
operatic's Avatar
Former Sponsor
up up up
Old Jan 12, 2009 | 08:14 PM
  #1661
Revs2Hard's Avatar
BARF
Did mine ship out yet?
Old Jan 13, 2009 | 06:44 AM
  #1662
operatic's Avatar
Former Sponsor
PMd you
Old Jan 14, 2009 | 07:06 AM
  #1663
operatic's Avatar
Former Sponsor
All PMs replied too
Old Jan 14, 2009 | 06:18 PM
  #1664
Revs2Hard's Avatar
BARF
I sent you two pm's and my money was sent last thursday night. Just wondering whats up?
Old Jan 15, 2009 | 06:42 AM
  #1665
operatic's Avatar
Former Sponsor
Hey partner, you ordered custom colors, so they take around 9-13 business days before they get to your door step. We'll keep you updated though.
Old Jan 15, 2009 | 11:27 PM
  #1666
Revs2Hard's Avatar
BARF
^ you guys are awesome +++ trader ratings for you vary soon.
Old Jan 16, 2009 | 07:15 AM
  #1667
operatic's Avatar
Former Sponsor
up for some HIDs
Old Jan 17, 2009 | 09:10 PM
  #1668
operatic's Avatar
Former Sponsor
up up up
Old Jan 18, 2009 | 08:11 PM
  #1669
operatic's Avatar
Former Sponsor
Bringing it up for some HIDs!!!!
Old Jan 19, 2009 | 03:40 PM
  #1670
Holty's Avatar
are these any brighter than the factory xenons in a 2004 maxima sl? or is this sale more for guys who don't already have HID's from the factory? sorry for the newb type question.
Old Jan 20, 2009 | 09:05 PM
  #1671
operatic's Avatar
Former Sponsor
If you have factory HIDs, the best we can do is get you replacement bulbs in different colors. As for them being brighter, they would be the same brightness.
But as for your fog lights, we can make em even brighter than your factory HID low beams as we have 50w ballast. For reference value, your OEM ballast are 35w.
Old Jan 21, 2009 | 12:43 PM
  #1672
Holty's Avatar
thanks for the reply. I want the 50w ballasts, but need to know if they are digital? also will i have to modify my housing at all for them to fit?
Old Jan 21, 2009 | 04:43 PM
  #1673
QNO_A32's Avatar
iTrader repped. ill be putting these in soon. i already modified the housing. nothing a trip to home depot motorsports couldnt fix. i didnt want to mess with the shield so i made spacers...pics to come.
Old Jan 21, 2009 | 09:28 PM
  #1674
operatic's Avatar
Former Sponsor
Yes they are digital like all of our ballast. And you will not have modify your housing to have them fit
Haha, Home Depot motorsports :P I love it
Old Jan 21, 2009 | 10:35 PM
  #1675
shyheim07's Avatar
I wants some h3s for the foggies..but I want them wired to a separte switch...can you tell me how I can do that, or is it even an option?
Old Jan 22, 2009 | 10:19 PM
  #1676
operatic's Avatar
Former Sponsor
You sure can, buy a toggle switch at an auto parts store and hook that up to our relay harness.
Old Jan 23, 2009 | 06:57 AM
  #1677
operatic's Avatar
Former Sponsor
up up up
Old Jan 24, 2009 | 09:17 PM
  #1678
operatic's Avatar
Former Sponsor
Bringin it up
Old Jan 25, 2009 | 08:43 PM
  #1679
operatic's Avatar
Former Sponsor
bumpin it up!
Old Jan 26, 2009 | 10:55 AM
  #1680
maximanigel's Avatar
can someone please post pics of an actual 03 max with the custom yellow color installed in the fogs? and how hard was it do to? thank you
