Gropu Deal on Grille-Tech for 89-94, and 2K - 2K3 !
Originally posted by Triple8Sol
Kloogy, I heard that Grille-Tech is going to make one for the 02-03 main grille. If that's true, any word on when we might be seeing it? And will it match the lower valence grille exactly? I'm waiting on that, so I can make sure it all matches, and then I'll probably pick them all up at once.
Question For Kloggy
Question...How is $49 a group deal price. Not for nothin, but I got my grill from them and just told them I was a MAxima.Org member and they shipped it to me for $49 dollars. If you talked to someone over at grille-tech don't you think they should have given you a better price then $49? I mean heck, if you are getting them all this business I would think they would sell it a little cheaper.
Re: Question For Kloggy
Re: Re: Question For Kloggy
Originally posted by soundmike
That's what makes it a group deal, otherwise IIRC the grill costs $70. Even on E-Bay it doesn't go that low.
Well I got my grille today. I bought it used, no instructions included. It looks fairly straightforward, but I had a couple questions for those that have purchased it new.
How many zipties came with the grille?
How many zipties did you use to install it, and where did you put them?
Thanks for your help!
Originally posted by Freaknificent
is the deal still on? i need that grilll
btw with a dark gray 3rd gen max, silver or black grille?
Sorry, I should've been more specific. I have a 2002 SE, which has the two split grilles on the lower valence.
So going back to my original questions: How many zipties came with the grilles? How many did you use to install it, and where did you put them?
I'm not sure how many - more than I needed. I put 3 on each side.
2 on the top of each grille and 1 in the middle of each grill. I got the silver ones so I took some silver model paint (w/black mixed in to tone it down) an touched up the zip pieces showing.
Hint: best to run the zip tie from inside of the grill to out and back in the grill so only the smallest piece shows outside the car and make sure you have the tie flipped to the correct side to pull through tight.
Shaydz
Originally posted by kloogy
Still waiting on the main grille.. Im not sure if I will like it. But I will keep you guys posted !
If I don't do a main grille, I'll at least paint it body color!
Kloogy did they ask you for any input for designing the main grille? I would really like to see one that would fit in between the bars on the stock grille. The gunmetal color matches my new gunmetal rims
I don't really like the ones that replace the whole thing. It leaves you with a huge mesh opening on our 02-03's...
i am very impressed with the insert for my 89. the zip ties are pretty gay but other than that it only took a little brain power to get around using them. all in all i probably invested 2 hours going to the store, cutting with the dremel, glueing and ending up with a pretty damn tight grille.
justin
justin
James92SE
142
Jan 2, 2024 09:23 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
