Fog Light Bulb Wattage??
Hey all, Ive got stock fogs in and im wondering how high i can go with voltage for a new set. I found some 55's and also some 100's. Can I use the 100's? I know the 55's work. Any info appreciated...
-Steve
-Steve
Re: Fog Light Bulb Wattage??
-Steve
-Steve
hmm didnt think of that. Yeah i guess if they got hot enough, a puddle or rain or something could cause shock cooling. I'll just stick to the stock ones, even though they suck
What about using the headlight type bulbs in there? Is this possible, if I modify the housings, etc?
I have no idea about using a headlight bulb. I would guess it would be possible, anything is possible. I am not the lighting expert so I am not about to give advice on that.
Not only do you have to be concerned with possibly melting your fogs, especially the lenses, with a 100 watt bulb,but the greater problem lies with overloading the relay and/or wiring!!! The fogs use an H3 type bulb.
Hope this helps!
Hope this helps!
Re: Re: Fog Light Bulb Wattage??
Originally posted by I30tMikeD
From what I have read, going with high watt bulb may cause your housing to crack. The bulbs will heat up the housing significantly enough that if you dive through a puddle of something the cold water will cause them to crack. I have heard of this happening many times.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
