2001 i30 rides harsh
Old Mar 30, 2003 | 06:29 AM
suzook's Avatar
hey guys,i just sold my 92 legend,and picked up a 2001 i30.i have to say this car rides like crap compared to the old leg.is this how these cars ride or should i have the shocks checked out.it rides very harsh.the car only has 35000 miles on it.any input on people with the same car,let me know.thanks.btw its not a t model
Old Mar 30, 2003 | 01:07 PM
JSpecMax's Avatar
Re: 2001 i30 rides harsh
Check your tire pressures. Anything above 40 will ride harsh. If you run about 36ish all around, you should be fine. The shocks should be fine, unless the car was in an accident or something like that. But check the pressures, I have an 01' i30 with a newly installed set of eibachs, and it still doesnt ride harsh. Only over bumps at speeds above 45 does it feel any rougher than stock.
Old Mar 30, 2003 | 03:07 PM
I30tMikeD's Avatar
Re: Re: 2001 i30 rides harsh
Told you the ride would not be too rough. The benefits far outweigh the costs don't you think??
Old Mar 30, 2003 | 07:22 PM
JSpecMax's Avatar
Re: Re: Re: 2001 i30 rides harsh
100% true. Thanks again for recommending changing the springs, it was a good learning experience as well as a great investment. When you did yours, did they vibrate a little when braking at first? Or at like 71mph? just curious...
Old Mar 30, 2003 | 08:48 PM
I30tMikeD's Avatar
Re: Re: Re: Re: 2001 i30 rides harsh
I did mine close to a year ago. No vibrations of any sort. Only thing I ran into was squeaking in very cold temps due to the fact that I did not wrap my coils.
Make sure you retighten all your strut bolts after a few hundred miles, they can have a tendency to come loose at first. Maybe realigning and balancing your tires may help the vibration, although the balance should not have changed.
Old Mar 31, 2003 | 01:24 PM
JSpecMax's Avatar
Re: Re: Re: Re: Re: 2001 i30 rides harsh
Are you talking about the strut tower bolts? Cause the rears are a HUGE pain to get to. I tightened em to about where they were at stock. Im goin for my alignment on wed. btw.
Old Mar 31, 2003 | 02:19 PM
I30tMikeD's Avatar
Re: Re: Re: Re: Re: Re: 2001 i30 rides harsh
Yhea, I don't know about the your car, but it can't be much different than my I30. Just have to remove the trunk carpet. It takes a bit of reaching into the truck, but nothing that can't be done in 20 minutes or less.
They most likely will be fine, but I know of a couple people who's bolts got loose and caused some bad noises. Mine were fine.
Old Apr 3, 2003 | 08:26 AM
Burton069's Avatar
Just wondering, how much did you pay?
Old Apr 3, 2003 | 11:25 AM
suzook's Avatar
i paid 19k.from an infiniti dealer.does your car ride a bit harsh?it feels a bit cheap to me.i know its just a max,but i would have expected a more solid feeling when hitting potholes.anyway other than that i love the car.
Old Apr 3, 2003 | 11:41 AM
Burton069's Avatar
Well my father has your model I30 (not the T) and it is a little smoother than my car. I honestly don't notice a huge difference between our cars. Maybe you have to get used to it. Definately check the tire pressure.
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
uttadms31
Sep 30, 2015 05:24 AM
Tmax78
Sep 25, 2015 09:07 PM
